Go to Post I say: Chutes & Ladders in FRC 2008! - petek [more]
Unread 03-11-2005, 17:29
Andrew Blair's Avatar
FRC #0306 (CRT)
2003 User Byte
I need to get a var. byte on a 2003 stamp brain onto the user byte allowed that's sent back to the OI. It's from an analog sensor. the problem is, when I move the little jumper to user mode so I can see the byte(the one thats set in default to show p1_y value) and I press the oi switch till I get to the byte, it flashes " 0.0.03", then moves onto the next byte, team number I think.
ELSE        'User Mode is ON
    OUT8    = sensor1.BIT0    ' Set ouput bits to display pressure
    OUT9    = sensor1.BIT1
    OUT10   = sensor1.BIT2
    OUT11   = sensor1.BIT3
    OUT12   = sensor1.BIT4
    OUT13   = sensor1.BIT5
    OUT14   = sensor1.BIT6
    OUT15   = sensor1.BIT7
My other question is, how do wire in analog sensors into the 2003 brain? It uses a standard parrallel connector for analog inputs. My sensor is the texas instuments pressure transducer given to us a few years ago. Its got three wires though, and the pinout only calls for an input and a ground. Do I just solder two in, like a pot?
-Sir Francis Bacon
-Albert Einstein
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
The Science Channel to broadcast FIRST documentary Andy Baker General Forum 49 01-03-2004 14:03
Reputation Level suggestions Brandon Martus CD Forum Support 42 10-01-2004 08:58
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
