Go to Post there's no time like week 5 to learn programming :D - dcarr [more]
Unread 22-10-2005, 13:56
Umm Errr...
Re: IFI Loader Reloaded
What info can you give me on how the code loading scheme works? I heard that it is based off of some Microchip reference implementation. You obviously figured it out in order to write this. I am curious.
1139 Alumni
Unread 22-10-2005, 14:39
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
The PIC on the RC has a bootloader on it. There's read/write commands as well as a few other things. The IFI bootloader is a slightly modified version of the one put out by Microchip. Matt Fowler (FRC team #312) sent me a whitepaper on the IFI bootloader. The Microchip bootloader has the same protocol and both share most of their commands. For documentation on the Microchip bootloader, look for AN851 on their website.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 03-11-2005, 19:33
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
I haven't used it yet, so it may have this feature... but in case it doesn't.
It'd be nice to have a feature to disconnect from the COM port. This way, if you are using another terminal program you don't have to close it in order to be able to use that port.
Unread 03-11-2005, 20:04
Where can I get a binary?
Unread 03-11-2005, 20:51
Electrical Engineer
AKA: Phil Baltar
FRC #1351
It's been awhile since I've been in that part of the code, but I'm pretty sure that it does. The port is normally free. When the program wants it, it'll open the port, then close it when it's done.
I posted a link to a Windows binary a few posts back. I've had trouble making it work, so your milage may vary. It was compiled with Visual Studio, and didn't give any error (it obviously compiled), but it has problems with the serial port. When the program opens the port, it seems to crash. I haven't found the problem though, because if I run that same binary on WINE (windows emulator for linux), it works fine. I don't have access to another windows compiler though. I'd be great if someone came up with a binary for me though.
Version: 3.12
Unread 03-11-2005, 23:49
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Originally Posted by sciguy125
...I don't have access to another windows compiler though. ...
Have you tried the Digital Mars compiler?
http://www.digitalmars.com/
Unread 04-11-2005, 11:48
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
I'll give it a shot sometime over the weekend. I have a few different compilers... if I get one to work, I'll post it.
Unread 04-11-2005, 23:38
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
The default microchip loader will also load and unload binaries from the controller, but this is a nice update.
However, this will probably not be able to update the master code, at least not in its original format.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 05-08-2007, 00:57
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Firstly, yes I know this thread is like two years old but..
I was wondering if you continued work on finishing ifiloader reloaded..
Does it work with the 8722 chip?
Can you email me the whitepaper on the bootloader?
Thanks
Unread 06-08-2007, 10:55
Electrical Engineer
AKA: Phil Baltar
FRC #1351
Thanks
The response from my team wasn't as good as I thought it would be. I pretty much just stopped working on it.
Version: 3.12
Unread 06-08-2007, 11:03
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
I would suggest you to add to the tags a word from the programmer, so he knows what program is on the RC at the moment.
Great work!
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 07-08-2007, 00:07
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
Oh, sorry to here about the lack of enthusiasm imo i think its a great project
IFI Loader and PROG button Dave... Programming 3 20-02-2005 12:03
Does the new IFI Loader work with the old Firmware? gnormhurst Programming 2 17-01-2005 20:11
Um... IFI Loader Ryan M. Programming 3 14-01-2005 21:15
IFI Loader Doc's Raven_Writer Programming 0 21-01-2004 17:53
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
