Go to Post I am a geek and proud of it. - +()c|D [more]
Unread 04-11-2005, 07:53
Re: Additional field coils around motors
Dave is the closest thus far, the motors already have a magnetic structure designed in. Trying to add to that will likely not result in an increase in performance. However, under another rule, solenoids are not allowed. See also the robot allowed parts flowchart.
Unread 04-11-2005, 08:14
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
True. But it's not the result, but more the intent that bothers me.
Unread 04-11-2005, 09:20
Unread 04-11-2005, 09:31
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I believe that Jack is concerned about the collective state of mind of a team that encourages them to bend the rule in this manner.
I'm not sure that it's unhealthy to try to push the limits, to exploit loopholes and to generally make life a mess for the inspectors and rule-makers. It's occasionally a little frustrating for those officials, but ultimately, it's mostly harmless. If the inspector or rule-maker says "no", it's final, no matter how much effort you put into it; by bending the rules, you take the risk you will find yourself in that situation. (Now, I should point out that decisions to live on the cutting edge should be undertaken with the consent of the team as a whole. If it's a small group within the team that risks the team's success on a dubiously legal enterprise, which is eventually rejected at a competition, all hell might rightly break loose in that team's pit; just leave the inspectors out of it.)
Unread 04-11-2005, 09:47
I think that is important to note that winning teams have won without bending the rules. GP allows you to go ask, investigate and take pictures. Learn from others when you have the chance.
Unread 04-11-2005, 12:15
Dave.Norton Dave.Norton is offline
FRC #1157
Dave.Norton is an unknown quantity at this point
[quote=Tristan Lall]I'm not sure that it's unhealthy to try to push the limits, to exploit loopholes and to generally make life a mess for the inspectors and rule-makers.QUOTE]
Agreed. Limits are imposed by both man and nature. Understanding those limits and attempting to push past them is the basis of creativity. Railing against them is unproductive, which is to say lets have fun with the ideas.
Unread 04-11-2005, 13:21
accepting the limits of nature? Im not too sure about this
many times it wasnt nature, it was our understanding that was flawed.
Several years ago 2.8k modems were the best you could get, because Nyquist said that is the fastest that data can be transmitted on a phoneline with a 3,000 Hz bandwidth
but now we have 56k modems, on those phonelines with the same 3kHz bandwidth
nature folded on that one and gave in. Sometimes it pays to keep railing :^)
also, sometimes when you sit and ponder ways to cheat, you come up with a good idea that is not cheating - unrestricted brainstorming!
Unread 04-11-2005, 15:38
FRC #1157
[quote=KenWittlief]accepting the limits of nature? Im not too sure about this many times it wasnt nature, it was our understanding that was flawed.
QUOTE]
You misunderstand, what I said was complaining about the rule is unproductive. Railing: "to revile or scold in harsh, insolent , or abusive language" (from Merriam-Webster). What I was suggesting is that "out of the box" thinking is valued, and would like to encourage it.
Unread 04-11-2005, 16:14
occra 23.
AKA: ryo
None #1481
even if ignoring legality and spirit, i htink cooling the motor would be a much better way to 'boost' performance. a simple way we used and was effective (for our OCCRA robot) 2 years ago was to have tubes connecting the exhaust ports from the pneumatic cylinders to blow into the motor endbell. (we used our cylinders almost continuously that year and fans are not legal in occra or we didnt have any available... dont remmebr which) but as a concept it worked well. but then again from last year we learned how to make a more efficient drivetrain with much less friction and got a more 'easy on the controls' driver and havent burned a single motor since.
Unread 04-11-2005, 17:23
Gdeaver Gdeaver is offline
FRC #1640
This thread points out the Tim Allen mentality as applied to robotics. More power. However, with with the reality of the ever increasing cost of energy, the wise conservation and application of power makes more sense. A KOP trans with dual cims has a considerable amount of power. The use of this power in design and strategy will probably yield better results than trying to add more power.
Unread 05-11-2005, 03:06
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
I'm not really interested in trying this, just wondeing how other people saw it, glad I could stir up more than one point of view. Personally, with as common as 4 and 6 motor drive trains are now, I thing that transmission development is probably the next big area that can be developed, even more so than it is.
last year there was talk of robots killing batteries in a single match... Something like this wouldnt help matters much, but its fun to think about.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Unread 05-11-2005, 11:07
well, no... actually motors with super magnets would be lighter and smaller for the same amount of torque or HP output
and a motor with a smaller armature will have less internal (rotational) inertia, which means it will accelerate faster and have a better response curve, allowing it to be used with tighter PID control loops.
Using a better motor gives you several benefits => advantages. Only problem so far is that FIRST understands this completely, and they have kept motor modification and substition off the table of options.
But that doesnt mean we cant talk about it :^)
BTW, controlling a motors field strength, buy using field coils instead of permanant magnets is a better way to control the motors speed and torque. With a strong field the motor will run slow and have lots of torque. With a weak field the motor will run faster, but have less torque.
Unread 05-11-2005, 11:45
This has been an issue since the beginning of time. Some teams are proud of it and some teams recognize the liability. You won't find many one match robots in finals.
Unread 05-11-2005, 12:35
I second what Al said. With the total current limits imposed on the robot (by the rules and the main breaker) and with the 12V battery a bot can pull approx 2HP from the battery continuously
that is a LOT of power! A healthy 18 yr old male can put out about 1/3 HP continuously for 2 minutes, therefore the power available to your bot is the same as having six young men exherting themselves to their full capacity.
If your bot is expending that much power for the entire 2 minute match then something is seriously wrong with the design of the machine. Most of that energy would have to be fighting against itself, not other robots. For example: tank steering with 6 rubber tires or tank treads, that takes full power just to turn, compaired to a bot with 6 omniwheels, that can spin around as easily as it can move forwards or backwards.
Looking for Official FRC Competition Field plans sanddrag General Forum 6 17-10-2005 07:58
Do the CIM motors emit a magnetic field? JulieB Motors 17 27-01-2005 12:59
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
How does one go about ordering more motors... Team852 General Forum 3 27-01-2003 14:37
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
