Go to Post Each match is a learning experiance - the only thing you can do is get better. - SuperJake [more]
Unread 04-11-2005, 09:40
Re: Molten Metal
sciguy,
your analysis is excellent (esp for an electrical engineer :^)
the only point that doesnt sit right with me is you used the mass of your whole finger (1cm thickness) and if I understand the equation you used then which part of the finger is rasied to 120ºF? the surface of the side in contact with the metal, or the entire mass?
While the finger is in contact with the metal, there will be a temperature gradiant from the contact side to the back side, with the mass of the finger drawing heat away from the contact area.
The reason I ask is your answer seems pretty long - 66mS is only 1/15th of a second. My intuitive basis for this comes from experience, like licking your finger and tapping an clothes iron to see if its hot.
The other question is, what temp can we endure without being burned? 120ºF seems low. Tap water is usually 160 - 180ºF.
Unread 04-11-2005, 11:33
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: Molten Metal
I'm assuming that the whole finger is rasied to 120F. There was a couple issues that I couldn't easily resolve. First off, I wasn't sure how to model the heat transfer within the finger. I suspect that if I worked on this long enough, I could probably come up with some differential equation that'll do it. We'd need an equation that describes the rate of temperature rise in the finger at some distance from the surface. I doubt that it would be a very pretty one though. But hey, computers can solve anything.
The other issue was blood. Because it's flowing, it's essentially acting as a coolant. Although, because of the short time, I'm not sure how much it actually does.
Well, I was going off of cooking temperatures. For beef (which I'm assuming is the closest animal to human), medium-rare is 130F. And through the wonder that is Google, here is a handy dandy chart.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 04-11-2005, 11:41
Re: Molten Metal
the answers to these questions (heat transfer) are learned in college Thermodynamics classes
Its normally taken by mechanical engineering students, after taking 4 semesters of calc and one semester of differential equations, and in many university's its one of the 'weed-out' courses (where D is for Diploma :^)
Unread 04-11-2005, 11:52
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: Molten Metal
D isn't for diploma anymore.
It's now C for continuation.
Wetzel
Viva Olancho!
Unread 04-11-2005, 12:19
Electrical Engineer
AKA: Phil Baltar
FRC #1351
Re: Molten Metal
Yup, I'm taking ME113 (Thermodynamics). I don't need it for EE, but I needed some extra units and it looked interesting. It covers topics more along the lines of power generation from heat engines. However, it looks like heat transfer is covered in the other two thermo classes ("heat transfer in electronics" and "thermal engineering"). They both cover heat transfer, but the one I have to take has an emphasis on heat transfer applications in electronics rather than engines and whatnot.
As for math, thermo's prereq is the last semester of calc. The heat transfer classes need differential equations though.
And, according to the course catalog, ME majors need a C- or better in their thermo classes.
Version: 3.12
Unread 08-02-2006, 17:35
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Re: Molten Metal
This vid is so very obiously fake, lookclosely when he put his hand thru, the video skips from right in front of the metal to the back, not very real
MechWarriors 573
Unread 08-02-2006, 18:28
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
Re: Molten Metal
I saw the skipping too. i call fake. metal is ALOT hotter than water or fire or whatever you got.
Originally Posted by EricH
The theory is that if you wet your finger (foot, hand, whatever) before you do something like this, the water will take most of the heat until it is gone, so if you are quick, you can get away with it.
not with water, it won't. water is a very good conductor of heat. i know from personal experience. long story short, if you have a choice between a wet rag and a dry rag to use as a hot-mitt, go for the dry. avoid burning. and blisters.
water will actually speed up heat transfer in most cases. which, coincidentally, is why water cooling for cars and computers is so much more effective than air. air is an insulater.
Unread 08-02-2006, 18:45
Re: Molten Metal
I think its real. When you have worked in a place like that for 20 years you learn things instinctively.
it would have been easy for them to experiment, taking a metal rod and hitting the hot flow, and seeing if got warm to the touch.
Heat cannot transfer instantiously, there must be sufficient contact time for the energy to transfer from one material (the molten metal) to the other (flesh).
That being said, I would never try it. Maybe after working with the stuff for 20 years?
Unread 08-02-2006, 18:58
Jimbo5051's Avatar
Jimbo5051 Jimbo5051 is offline
Rep' da Goat
AKA: Jimmie Nickerson
FRC #0829 (The Digital Goats)
Team Role: Electrical
Jimbo5051 is an unknown quantity at this point
Send a message via MSN to Jimbo5051
Re: Molten Metal
I think it was fake but it could be real if he used kevlar... And yes kevlar is used in bulletproof vest but it is also used in firemens suits and cand stand up to 3200 degrees.
2007 St. Louis Regional Winners
Unread 08-02-2006, 20:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Molten Metal
Why wait 20 years to lose a hand? If you plan on losing your hand, the sooner you do it, the more time you'll have to learn how to live without it.
Unread 08-02-2006, 22:04
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: Molten Metal
Right, Water absorbs heat about 240 times faster than air.
Rules on metal casters stevo2k Rules/Strategy 16 08-02-2005 14:16
Electronics mounted on metal Nitroxextreme Control System 3 01-02-2005 22:42
Tetra connectors metal or plastic? sanddrag Technical Discussion 10 10-01-2005 22:38
Is this a valid technique? (Color application to metal) Elgin Clock Technical Discussion 8 09-06-2004 21:33
