Go to Post That's some sexy use of aluminium - Bharat Nain [more]
Unread 05-11-2005, 01:51
EGG0900 EGG0900 is offline
EGG0900 is an unknown quantity at this point
Exclamation SERAL INSTEAD OF DEBUG...
What would be a easy way of doing this debug example with serout?
DEBUG CR, "D ownload", CR
FOR DataSlot = 1 TO 15
STORE DataSlot
DEBUG CR, ? DataSlot
FOR RomLoc = 0 TO 2047
SERIN 16, 16468, Cont_Download, 1, Cont_Download, [Result]
Cont_Download:
IF Result = 27 THEN GOTO Start
READ RomLoc, RomVar
IF RomVar = "?" THEN DEBUG CR, "?"
IF RomVar = "a" THEN DEBUG "a"
IF RomVar = "b" THEN DEBUG "b"
IF RomVar = "c" THEN DEBUG "c"
IF RomVar = "d" THEN DEBUG "d"
IF RomVar = "e" THEN DEBUG "e"
IF RomVar = "f" THEN DEBUG "f"
IF RomVar = "g" THEN DEBUG "g"
IF RomVar = "h" THEN DEBUG "h"
IF RomVar = "i" THEN DEBUG "i"
IF RomVar = "j" THEN DEBUG "j"
IF RomVar = "k" THEN DEBUG "k"
IF RomVar = "l" THEN DEBUG "l"
IF RomVar = "m" THEN DEBUG "m"
IF RomVar = "n" THEN DEBUG "n"
NEXT
'STORE DataSlot
PAUSE 5000
NEXT
GOTO Main
Unread 05-11-2005, 11:35
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: SERAL INSTEAD OF DEBUG...
Well, to start you off this is a forum meant for FIRST Robotics. It was started by Team 47, Chief Delphi. We program primarily in C or Assembly.
What language is that? BASIC? What chip are you using? Could you provide a link to the datasheet for that chip?
Thanks.
http://www.mikesorrenti.com/
Unread 05-11-2005, 18:25
http://www.parallax.com/dl/docs/prod...DemoCschem.pdf
bs2pe i am useing it as a data logger and this is the section where i download the stored info to pc. i want to be able to do this in a serial out mannor.
IFI Dynamic Debug Tool fowlerm Programming 0 25-08-2005 16:18
variable? manodrum Programming 11 01-04-2003 17:20
RCU has bad Analog ports - what now? Icebreakers Programming 13 26-03-2003 07:27
basic stamp editor debug capture dave_l Programming 4 17-03-2003 19:35
Programming Port GreenDice Programming 12 10-01-2002 09:14
