Go to Post Either way, FIRST works. You just have to keep the big picture in mind. - Lux [more]
Unread 05-11-2005, 16:56
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Hard Drive shock protection
I'm working on a project in which I will be mounting a desktop computer on a lawn mower to control it. I'm worried that I will be running the risk of damaging the hard drive from all of the vibration. Has anyone ever killed a hard drive from vibration? How long and intense can vibration be before there is serious damage? Also, what can be done to protect a hard drive from vibration, I've found a few ways but I want to know what others are out there.
This website has a description of how hard drives are normally damaged.
-Alan
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 05-11-2005, 17:24
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: Hard Drive shcok protection
A few questions before any real answers can be given:
1) What speed (in RPM) is your hard drive? Lower is better for this; SCSI is NOT A GOOD IDEA. Is flash media an option? Several different *nix distros can fit on a 2gb card, and vibrations wouldn't even bother the card.
2) How strong are the vibrations from the lawn mower?
3) How much would you be running this?
Unread 05-11-2005, 17:59
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: Hard Drive shock protection
egg shock protection
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 05-11-2005, 19:48
AKA: Alan Meekins
Well it is an IDE hard drive, I think 7200 RPM. Infact I will be running Linux on it but I have not considered flash storage. So far I've just been using parts that I could find laying around my house and school. I have a few old CDrom drives, maybe I could make a LiveCD. Maybe vibration would be less of an issue for a CD drive. How much do 2gb flash cards cost and where can I buy them?
I don't know how strong the vibrations are. How could I go about measuring it?
Well my end goal is to have this system cut my lawn autonomously (I've really gotten lazy about cutting the grass) so it will be run for about an hour at a time.
Unread 05-11-2005, 20:31
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
CDs would probably be more sensitive to vibrations, (think of a CD player without skip protection) but they won't actually get destroyed. Because it's likely that once the base system and the lawn cutting program load you won't need to be retrieving more data, it would probably work fine. (Esp. if the cdrom spins down after that.)
Interesting idea. I might try that too...
Unread 05-11-2005, 20:56
REVving up for a new season
FRC #2848 (All-sparks)
I had to do this on our DARPA grand challenge car. after much review we opted to go for solid state flash drives, although if that is not an option (cost, memory size) defiantly use laptop hard drives as they are much less affected by vibration.
edit: 1000th post
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 06-11-2005, 00:30
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Flash is definitely a good idea, in fact much better than a hard drive, for something like this. Think of read/write heads moving a couple thousandths of an inch above the surface of the platters, containing data which you need, and then think if you've ever seen a smooth-running lawnmower (or any smooth-running 1-cylinder engine, for that matter). It's similar with CDs; by getting my read heads out of alignment on one drive (I was adjusting it because it wouldn't read reliably), I managed to have it cut concentric rings in a disc, because the head was dragging on the surface. You will too, if you try to retrieve data from a CD, only they won't be so evenly spaced, as the drive seeks back and forth over the entire surface, and bounces wildly.
Windows 2000 fits on a 2 GB card too, provided that it's properly pruned down (to leave a couple hundred MB for swap space); you might need to install to a larger drive (which you have), delete extra stuff, then image it to a card. Then again, Linux works too, if you prefer.
In any event, any computer store will carry (or be able to get) the appropriate size of compactflash card; compactflash is pin-equivalent to ATA, but uses a smaller connector, so a simple pass-through adapter will allow it to be used with any common motherboard through the 40 pin connectors. See here for the card, and here for the adapter for example.
Also, I can't help but correct this: SCSI is a bus specification. It is not an indication of shock resistance. Modern SCSI drives are often built with high spindle speeds, but older ones can be had with much slower spindle speeds; I've worked with a 4.3 GB, 4200 rpm SCSI drive, and a brutally slow 200 MB SCSI drive from the mid 1990s. Though I agree that it seems sensible enough that peak spindle speed and vibration resistance may be linked, I'm not sure that the correlation is significant, especially compared to other characteristics of the drives' designs.
Originally Posted by Greg Needel
edit: 1000th post
On the ArsTechnica Forums, they have a procedure for dealing with people who brag about multiples of their thousandth post. Ask about the "DoD" in that forum's "The Lounge" section....
Unread 06-11-2005, 01:26
Electrical Engineer
AKA: Phil Baltar
FRC #1351
I realize that if your looking for vibration resistant media, flash would be your best bet. However, I'm a little weary about using flash as the primary storage on a computer. My concern is wearing out the cells. Flash can only go through a finite number of read/write cycles. For something like a camera, it's fine because you'll usually fill up the card before erasing it. A computer however, will be constantly changing data. A file that's rewritten very often (maybe a log), it would wear out the flash very quickly.
Version: 3.12
Unread 06-11-2005, 01:38
That's always been a concern with flash memory technology, but since he only intends to use it for an hour a week, and because most of the activity should be taking place in RAM anyway (since there's not really much need to page data in and out, except to load it the first time it's needed—and even that is only a read), I doubt that he'll see any trouble, unless he's writing huge amounts of data in his log files. His usage pattern is (presumably) so different from that of a normal computer, that usual caveat shouldn't really apply. In any event, flash memory tends to have at least a few hundred thousand rewrites per cell (on average), and some good-quality, modern cards are reputed to be capable of millions of rewrites.
Unread 06-11-2005, 02:13
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Do you really need a full computer? Or a full computer on the mower? what do you want to do with the mower and the program? Could you get away with something like a microcontroller? If that wouldnt be enough, you could take a linksys WRT 54G wireless router, which runs on linux and has many other 3rd party firmwares, and is open-source also. Add a SD card, and use the GPIO's on it to interface to the mower. http://kiel.kool.dk/
Plus then you have wifi built into it, and you could do neat stuff like call the mower in if the weather turns bad... etc..
EDIT: just to get you thinking... http://yasha.okshtein.net/wrt54g/
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Unread 06-11-2005, 02:23
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Would something like an iPod work?
Unread 06-11-2005, 02:41
Team Alumni
Do Ipod's really have that much protection around the drive? They didnt look like it from the things Ive seen online when they are opened up.
One thing to remember about shock absorbers, if you do decide to go the route of using a full computer, they need to absorb the shock, not convert it into oscillations. A lot of the things that I have seen online for hard drive shock absorbers involve rubber bands. They end up having the hard drive there oscillating after the bump, which is almost worse (if not, actually worse) than the initial bump. The shock absorbing mechanism in that video in the first post was amazing, the drive moved down and back up, once and stopped. That is what the shock absorber should do.
Unread 06-11-2005, 03:04
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Well the new nano is actually a flash drive and I seem to remember (can't place my finger on where) reading about someone rigging a Ipod to run an operating system. Anyways, have you actually tested if the vibrations will cause problems. As it was mentioned before, a hard drive probably wont be damaged by the vibration unless screws come undone (not likely). If it does start to skip on you you might want a foam. Try running your computer and see what a hard drive will take before it skips (I know Ive dropped computers while they were running and had no trouble but the constant vibration might be an issue).
Unread 06-11-2005, 09:15
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
http://digitalmedia.oreilly.com/pub/...ks.html?page=3
you mean this?
But I don't advise ueing an IPOD as a bootable drive becase those hard drives are only rated for 20,000 hours or so
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 06-11-2005, 09:42
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Flash is definitely the way to go - if you have a 512 meg usb flash and a motherboard that supports booting from it, you should be able to get linux running on that. As far as for windows, you would need at least a gig assuming a very small page file. I would avoid using a hard drive as much as possible in this situation.
Also, depending on your cost limit and the performance you need, you might want to consider an embedded system like a gumstix unit.
Agreed - and SCSI drives are built to much higher standards as they are usually run 24-7-365 unlike most IDE drives, and need to be reliable in the enterprise environment (and you don't have to tell me about how you run your pc's IDE drives that often, because they will fail - I've had my share of failed ide drives from various mfg's).
Drive Straight C Code using Encoders without PID? Chris_Elston Programming 17 15-02-2005 23:41
center-wheel drive Mercutio Technical Discussion 27 02-02-2004 21:19
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
How hard is it to pull a goal? Ken Leung General Forum 19 17-01-2002 20:09
