Go to Post .. if no one gets ahead no one gets left behind. - Koko Ed [more]
Unread 06-11-2005, 16:43
DustinB_3 DustinB_3 is offline
FRC #0935 (Railerobotics)
DustinB_3 is an unknown quantity at this point
Electronic Speed Control Problems
Whenever I try and calibrate the speed controls they spark. Now everytime I turn on the robot they spark. Anybody had the same problem? Any Ideas?
Unread 06-11-2005, 16:54
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: Electronic Speed Control Problems
Have you checked for metal shavings or other debries? Also in retrospect check the power running into the victors with a multimeter. Are the motors still functioning normally?
Unread 06-11-2005, 18:00
where did the sparks come from - under the fan? by the wire terminals?
you might have a frayed wire shorting across the input terminals.
Unread 06-11-2005, 18:20
Sparks are bad! It is not something you usually can come back from, they are not self healing. Sparks are usually caused by one of two things, overcurrent in the controller (ala tank treads and hard turning or a shorted motor) and/or metal shavings. Since there is only one device on the controller designed to emit light, replace it and try again.
Unread 08-11-2005, 21:16
I blew out the speed controls with an air compressor so there are no metal shavings and the sparks are located under the fan. When the speed controls started to spark the motors would spin irratically. Starting and stopping in wierd incriments.
Unread 08-11-2005, 21:23
Umm Errr...
Unless there is some sort of conductive debris in the FETS(the components under the fan) I do not see how it is physically possibly for them to spark. Is there any way you can post a pic of the sparks or your electrical setup?
1139 Alumni
Unread 08-11-2005, 23:51
occra 23.
AKA: ryo
None #1481
how casn you be sure you blew them all out? unless you actually voided the warrenty and took the casing off to blow it off, you cant be sure. and for the sparks being under the fan, the more likely you got shavings in there. and erratic movement... shorting? or interference to the radio.... which i dont think happens very often... im suprised after all these sparks you speak of it still functions somewhat...
Unread 09-11-2005, 07:20
For all,
Once the FETs have become comprimised it is possible for them to spark for a while before total destruction. The initial damage will blow the case open showering molten semiconductor inside the case. The sparks are always accompanied by a really bad burning smell. It is a smell you will never forget, the death throes of a power FET and it's melting case.
This is not a survivable event, replace the controller.
Unread 09-11-2005, 23:36
Thanks for your help. I think it was metal shavings or they could of been bad speed controls from earlier years that someone forgot to throw away.
Unread 09-11-2005, 23:42
occra 23.
AKA: ryo
None #1481
i odnt think they just "go bad" so it could be metal shavings from recent or metal shavings from a while ago
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Detroit Electronic Expo Raven_Writer Off-Season Events 10 07-11-2003 15:29
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
speed control punarhero Technical Discussion 11 24-01-2002 18:03
Speed Controller/PWM problems.... Clark Gilbert Technical Discussion 8 08-01-2002 00:14
