Go to Post Programmer's pride. FIRST needs some more. - Ben Margolis [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 06-11-2005, 17:51
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Design Ideas
Since there is no easy to quickly search through hundreds of CD photos of robots for ideas i was wondering how and what teams did for their chassis. I was stupid and did not take pictures of the different bots and nats last year and now i wish i had.
What did teams do for their chassis as far as; how did you build chassis-welded bolted or other? what type of wheeels did you use-if any? how did you power the wheels-chain belt gear box directly to wheel or other? what was your drive platform-4 wheel skid steer omni or other? pics would be greatly appreciated.
~Bill
MechWarriors 573
Unread 06-11-2005, 17:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Design Ideas
Here's our frame
We direct drove the front right and back left wheels by means of flex coupling from the gearbox. pic All the wheels on each side were linked together with #25 sprockets and chain.
Le me know if you have any questions.
EDIT: We used button head machine screws to secure the tread to the hub. Rivets are another good option.
Unread 06-11-2005, 18:04
AKA: Bill Hancock
Re: Design Ideas
I knew there was another question i was gonna ask. For the teams that make your own wheels- How do you glue the said "grippy material" for lack of a better word to the hub?
MechWarriors 573
Unread 06-11-2005, 18:51
Billfred's Avatar
Billfred Billfred is offline
Re: Design Ideas
This year, 1293 used the Kitbot in the low-rider configuration, all bolted up. Nothing terribly original, but it got us through Palmetto, two parades, and miscellaneous bouncing through the USC campus.
The year before, we used the aluminum in the KOP to weld together a monstrosity of a frame. I don't think anyone weighed it by itself, but it had to have weighed 15-20 pounds. (We were rookies.)
Unread 06-11-2005, 19:08
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
Re: Design Ideas
This year team 836 used a 3/16" thick aluminum plate, and boxed aluminum for the chassis and frame.
Ok here is the logic behind the plate. For one it is very hard to break, second you don't have to keep adding braces to make it sturdy and or add braces to mount stuff on, third if you need to lose weight drill some holes, but alot of holes. The most any other robot has done to the plate is a small nick, but to those who hit us at high speed i would kinda think twice, that plate isn't going to budge.
Unread 06-11-2005, 20:40
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: Design Ideas
Team 662
- 6 wheel tank steering
- gearbox drives middle wheels and chains drive the front and back
- bolted frame with riveted pan
- custom wheels
- used contact cement and rivets for the tread
http://www.chiefdelphi.com/forums/pi...&quiet=Verbose
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 06-11-2005, 20:57
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: Design Ideas
We just epoxy it to the hub, then put a few screws through (relatively deeply because of the "no metal touching the ground" rule) for good measure.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 06-11-2005, 21:11
Jay Trzaskos's Avatar
Jay Trzaskos Jay Trzaskos is offline
Jay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond repute
Re: Design Ideas
229 welded the KOP chassis in a 6-wheel drive configuration with custom 4 inch wheels, and a custom 2-speed shift on the fly gearbox. We were very happy with how we designed and built our base. It got through FLR, Buckeye, the Championships, and RaChaCha Ruckus.
When it came to the wheels we just riveted the tread to the wheels. An adhesive will hold, but it is much harder to take and replace a tread if it becomes worn down. Not that rivets are much better, they can be ripped out of the tread and create problems such as getting the tread jammed between the chain and sprocket.
JT
229
Our custom 4 inch wheels
The beginning of our gearboxes
Our gearbox plates on robot weightwatchers
Jay Trzaskos
Product Design Engineer
University at Buffalo - MAE 2012
Alumnus - Theta Tau, Mu Gamma Chapter
Unread 06-11-2005, 21:48
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Design Ideas
Originally Posted by Bcahn836
This year team 836 used a 3/8" thick aluminum plate, and boxed aluminum for the chassis and frame.
3/8" Al Plate!! That would weigh almost 20 lbs by itself. That's seems a bit overkill, are you sure you don't mean 3/16"?
Last we used a real simple low design for the chassis out of 3/4" x 1.5" rectangular Alumin tubing in the front and back, and then 3/4" x 1.75" C channel Alumin down the lengths to support the wheels. We welded it all up and used 6 wheel design with the kit transmissions linked up with #35 chain. We used nylon sprockets attached to our wheels which was simple since our custom 6" wheels had no hub.
I attached a few simple pics.
ID:	3657  Click image for larger version
Unread 06-11-2005, 22:16
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: Design Ideas
Here's an archive of various FIRST drivetrains, frames and wheels from 1999-2004.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 07-11-2005, 17:20
AKA: Bill Hancock
Re: Design Ideas
I may have just found my new favorite design idea site
When making your own wheels with a CNC how do you go about putting a key slot in the hub.
MechWarriors 573
Unread 07-11-2005, 19:32
Re: Design Ideas
Keyways are usually put in with a broach, not on the CNC.
Unread 07-11-2005, 20:45
Smrtman5's Avatar
Smrtman5 Smrtman5 is offline
Dr. Bridgeport
AKA: Jon H
FRC #0041 (Robo-wariors)
Smrtman5 is on a distinguished road
Send a message via AIM to Smrtman5
Re: Design Ideas
Or a shaper! lol
...But who really uses those nowadays
Art is just an excuse for poor craftsmanship.
- Jon H
Team 41
Rowan University '10 Mechanical Engineering
[Official 2006 Game Design] OK, so YOU design the 2006 game... dlavery FRC Game Design 29 08-01-2006 00:21
#2 The Journey of a FIRST Graduate: Discoveries Ken Leung General Forum 3 06-11-2005 16:12
Collaborative Robot Design Project coreyjon General Forum 11 10-03-2005 16:00
Design Ideas with strategies DrShadowSML Rules/Strategy 1 12-01-2005 16:02
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
