Go to Post But here's the beautiful thing about FIRST: you are supposed to make mistakes. - RunawayEngineer [more]
Unread 07-11-2005, 13:22
Re: Bearings
Originally Posted by lukevanoort
The ones I'm thinking about don't need air supplied to them. They are fully enclosed, using air instead of balls, oil, etc. They are very low friction, but need insane rpms to work.
Define insane RPM. I think the CIM is the motor with the fastest free speed. It's about 5500 RPM (I think). Unless your definition of insane is insanely low, or you gear a CIM (or any other motor) up, you won't be going anywhere near fast enough to be able to use one on a robot.
Need help with gear box bearings JIN General Forum 9 21-03-2005 20:10
Need help with gear box bearings JIN Kit & Additional Hardware 1 21-03-2005 12:46
bearings evit General Forum 2 30-01-2004 12:46
A little tip about those drill transmissions and bearings archiver 2001 6 24-06-2002 00:22
Skyway wheels w/o bearings ahecht Technical Discussion 4 22-01-2002 01:25
