Go to Post Sometimes it's not what you know going into a battle, but who you know. - Elgin Clock [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 21-10-2005, 20:32
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
New Layout
I just uploaded the new layout for our website a few days ago. I'm not sure it works well on all browsers/settings though, so if all of you could give it a try and tell me if anything weird happens, that'd be awesome.
http://www.team358.org/
I'm gonna attach what its supposed to look like, but basically its:
|   FIRST                        Hauppauge  |
|   |  |   | Content                        |
|   |  |   |       Copyright stuff          |
Thanks!
(By the way - if any of you use my FIRST Team Search, looks like FIRST doesn't have all the data up on their pages yet, so I haven't been able to update yet, but it looks like theres 1816 teams registered at the moment).
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 28-10-2005, 13:10
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Re: New Layout
It looks fine on IE for windows. I it looks like it might be hard to see much without scrolling a lot on lower resolutions.
I would suggest a couple minor things. The images at the top take up too much vertical space, so they could be made a little smaller. The copyright info is a little hard to read with the lighter background on the left. Also, if the window isn't wide enough, the images get pushed down below the menu.
It doesn't look different from the general shape you posted above.
Unread 28-10-2005, 16:07
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: New Layout
Under electronics I can't open the Substitute RC power supply pdf. I get a vDeck error.
Unread 28-10-2005, 16:48
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: New Layout
http://www.team358.org/images/misc/team_sbpli.jpg is about 15pixels too wide for no horizontal scrollbar in Firefox 1.0.7 at 800x600.
It might be worth trimming it down.
Unread 29-10-2005, 09:33
Running Riot
AKA: Patrick Cloke
Re: New Layout
Thanks, I'm trying to figure out what to do with the copyright info, putting a graybox behind it is the easiest thing to do, but it doesn't look too nice.
Fixed, thanks!
Thanks.
FIRSTsearch
Unread 07-11-2005, 17:02
robot180's Avatar
robot180 robot180 is offline
Webmaster, spamrobotics.com
AKA: Jon
FRC #0180 (S.P.A.M.)
robot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to all
Send a message via AIM to robot180
Re: New Layout
I learned in one of my website aesthetic design classes that from a marketing perspective, it is best not to underline anything except links. Users naturally tend to wonder if the underlined text is a link and want to click it or move the mouse over it to see. This disrupts the flow of reading the text and gives a less professional feel. Instead of underlining things, try using other methods of seperating headings, such as using different font sizes, colors, and letter spacing/italics. This will give a more professional look and make it easier to read without being distracted by underlined text.
Again, hyperlinks are exceptions. The underlining can be used to show what text is a link. Another exception might be in menus, such as your menu to the left. I would suggest trying to make those menu items look more unique from other websites. Underlining of links is not needed in a menu because it is assumed that text in menus are links. Your upcoming events list is an example of where underlining is not needed.
Hope this tip helps. Also, I think forum should have an "s" at the end in the left menu, but I could be wrong.
-Jon
Computer Science Major
Georgia Tech
Former Team Leader
FRC Team 180
Unread 16-11-2005, 22:35
Running Riot
AKA: Patrick Cloke
Re: New Layout
Thanks, but I don't really agree. Menu text is not assumed to be links, and under lining doesn't necessarily mean links - different colors are assumed to be links.
What do you mean by making it look more "unique"?
It depends if you consider your message board as multiply "forums" for discussion or one unified "forum" for discussion, so I've seen it both ways.
FIRSTsearch
Unread 17-11-2005, 22:47
robot180's Avatar
AKA: Jon
Re: New Layout
What I meant about your links is that they look like they use all default settings (except color). Try making the font size for links slightly smaller. Also, see if it looks good having the underlining disappear when the mouse moves over them. See if any of that makes it look even better.
Most of my comments come from books and classes where they always say that all tips are general guidelines. Every situation is different and every guideline has many exceptions, so you may not agree, but in a different context you might. Anyways, hope this helps, but I just think the one thing least unique about your site is the look of the links; that's my opinion.
-Jon
Georgia Tech
Former Team Leader
FRC Team 180
Unread 24-11-2005, 23:36
Running Riot
AKA: Patrick Cloke
Re: New Layout
I thought it would be obvious enough that they are in a pane by themself that they are navigation links. I'll try to think of another way to make them 'unique.' I'll have to see what I can do with them. Though the upcoming events page I did notice I overused underlining...but I haven't had a chance to fix it yet.
I tend not to trust books on advice like that - I look at other sites to see what looks nice or just use my personal opinion. There are just too many variables that go into the overall view of a site.
FIRSTsearch
joystick pin layout fred Control System 1 29-01-2005 14:02
[OCCRA]: Looking for the field layout Alex Golec OCCRA 3 28-09-2004 21:35
Another layout design question Raven_Writer Chit-Chat 3 08-12-2003 16:50
Championship layout Marc P. Championship Event 23 04-04-2003 21:49
