Go to Post And like Woodie told us in his talk, all the bad stuff we anguished over will be replaced by the memories of the achievements and good time we had this year. - Wayne C. [more]
Unread 05-11-2005, 20:56
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
All GM-V engines look!
Haha - here is your complementary blown lower intake gasket! Both coolant passage gaskets are gone - and the lady kept on just adding coolant. She thought it was "normal."
Every GM V-style engine does this. My 1989 3.1 did it and this is from a 2000 3.4 Venture with only 60,xxx miles on it. Please - I urge you - if you have to add coolant/notice the coolant is getting low find out where it's leaking ASAP!! This engine WILL have to be replaced now due to the coolant mixing with the oil.
Happy driving...
That rug really tied the room together...
Unread 05-11-2005, 22:09
occra 23.
AKA: ryo
None #1481
Re: All GM-V engines look!
ew.....
Unread 06-11-2005, 09:57
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
That oil turned into a nice froth! Even if they just replaced the gaskets and changed the oil and flushed the cooling system that motors on borrowed time.
It's also very possible to hydro lock the engine if that got into the cylinders.
Last year 2 of our 3 Saturns (a 2000 SW2 with about 70k, and a 2002 SC2 with 40k) needed the intake gaskets replaced. We noticed every month we had to add coolant to them. The low coolant light would come on at several occasions.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 06-11-2005, 15:27
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Makes me proud to drive a Ford
Unread 06-11-2005, 18:26
Matt,
It would be cool to see some of the bearing surfaces if you get a chance to tear down. Camshaft and crank.
Thanks.
Unread 07-11-2005, 16:20
Elgin Clock's Avatar
Everything but the electrical problem inclined Focus eh? lol
As for the picture: intake gasket? Is that the head gasket?
Man.. I should really know more about cars at this stage in my life than I do, I have been around them for so long.
Unread 07-11-2005, 17:19
AKA: Jason Hartmann
If the head gasket was removed, which would mean the heads were also removed, then the cylinders and pistons would be visible.
With only the intake removed the push rods (top of photo) and rocker arms (bottom of photo) are visible. Also the intake passages (3 passages at top of photo) plus water passages (antifreeze visible) and oil return holes are showing.
and Matt, don't forget to retrieve your needle nose pliers from the motor!
Unread 07-11-2005, 19:22
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
could also happen to a ford, well everyting does usually happen to fords anyway.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 07-11-2005, 21:36
occra 23.
AKA: ryo
None #1481
^^HAHA^^ my gm is runnign strong with 187k miles on it
Unread 07-11-2005, 22:13
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
How often did she add coolant, daily, weekly, or monthly?
Just curious, also how much coolant should be lost over time in a car?
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 08-11-2005, 07:26
If you need to add fluids anytime you should find out where they went. In this case a quick check of the dipstick would have shown the color of the muck on top of the engine and it would have smelled like anti-freeze. Losing a few ounces over several months or year is not a lot. Over a couple of weeks is huge. Blown head gaskets manifest themselves in many ways, this is only one.
Unread 08-11-2005, 19:06
AKA: Maher Attallah
Originally Posted by Al Skierkiewicz
Matt,
Thanks.
I'd be dieing for a teardown also - but they just wanted to put in the intake gaskets and see what happens - and that got done - but guess what...
Due to Aluminum heads - ya' got a nicely warped head AND blown head gaskets (Due to overheating) The lady just wanted to save some $$ and not throw an engine at it - but we strongly recommend a Jasper engine or (lesser peferred) and good Junk Yard engine. She wants us to do the head gaskets now...so everything that I did has to come apart. Sometimes people love to beat around the bush...
When we replace the head gaskets - and it still isn't running right - than we will not to anymore work until she gets an engine - than i'll tear it down. I also really-really want to see the bearings too!!
(BTW - when was all said and done for the intake gaskets and started it - it had a nice knocking sound...and she still won't pay for an engine. She wants to put an engine in as a 'last resort.' Hey - fine by me, I still get paid how ever she wants... )
Unread 09-11-2005, 07:16
Knocking doesn't go away with a wish does it?!? What's it sound like to you, a cashed rod bearing or an oil pump?
Unread 28-11-2005, 11:09
kio_chan176 kio_chan176 is offline
Kio McKitty
FRC #0025 (Raider Robotix)
kio_chan176 is just really nicekio_chan176 is just really nicekio_chan176 is just really nicekio_chan176 is just really nicekio_chan176 is just really nice
Send a message via AIM to kio_chan176 Send a message via Yahoo to kio_chan176
my god, that is disgusting.
Proud to be a BMS Team
Unread 28-11-2005, 14:50
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
glad i dont have that problem in my Trans Am, I havent lost a drop of coolant since i soldered the small hole in my radiator.
KK4KQO
http://voltair.us
Lawnmower Engine Starting Tips?? sanddrag Technical Discussion 38 21-07-2005 23:55
Gas powered engine horsepower equivalent to electrical motor horsepower? Elgin Clock Motors 30 22-08-2004 20:44
Adding realism through plugins or alternate rendering engines anishthakkar 3D Animation and Competition 3 10-01-2004 17:26
pic: Next Years Drive Train CD47-Bot Extra Discussion 15 11-06-2003 21:32
Gas or Electric?? Clark Gilbert Chit-Chat 14 11-08-2001 12:16
