Go to Post There is no such thing as "un-GP." - Tetraman [more]
Unread 07-11-2005, 23:01
Brian Lesser's Avatar
Brian Lesser Brian Lesser is offline
Bankai!
Brian Lesser is a splendid one to beholdBrian Lesser is a splendid one to beholdBrian Lesser is a splendid one to beholdBrian Lesser is a splendid one to beholdBrian Lesser is a splendid one to beholdBrian Lesser is a splendid one to beholdBrian Lesser is a splendid one to behold
Send a message via AIM to Brian Lesser
Re: my comp is not working right and i need help
This is definately a memory error. Definately identifiable since it gives you the memory address as part of the error...
Some causes for this could be the hardware itself. Reason being is because the memory may creep out of its slot sometimes.
One thing I would suggest is taking out the memory sticks and putting them back in. If that doesn't work, then go with Mike AA's suggestion and swap them out to determine which one is causing the problem.
Hi
First Day is the easiest RIGHT?!?! MattK Chit-Chat 17 03-09-2003 22:11
pic: Right Side view CD47-Bot Robot Showcase 2 03-03-2003 15:26
What's 'Right' with this world archiver 2000 2 23-06-2002 22:37
Brian & Justin are Right archiver 1999 1 23-06-2002 22:15
IS THIS RIGHT?!?!? RebAl General Forum 22 31-03-2002 00:07
