#15
Re: Restrictive Environment From School
- The county has been generous enough to provide each student with a laptop computer. In response, it is suggested that you abuse the implicit trust that has been granted, and try to break their systems. - The computers belong to the county, and are not the personal property of the students. The response? Recommend that the students remove the hard drives (not their property) and use them - illegally - in alternate computers. - Against the obvious design and use requirements implemented by the computer owners, we find the recommendation to purge the operating system and install a new one that is in conflict with the installed configuration. - Illegally obtain a backdoor password and use it to defeat the legitimately installed software system. - If all else fails, permanently overwrite the original configuration, rendering it unable to be utilized as intended by the system owner. But that's OK, because now you can use a computer that is not yours for a purpose for which the owner has not granted permission, for an activity that is acknowledged to be something that "they might not like." Normally, I might let something like this pass, or limit it to a background discussion. However, when such a blatant and irresponsible post is made, it cannot be left alone. What is being advocated here is a violation of trust, an abuse of privilege, a disreputable behavior, and a borderline criminal activity. It is just plain wrong. To let this go unchallenged - in a forum in which we all profess to support professional and responsible behaviors - would be wrong. The original question asked for constructive suggestions for dealing with what were felt to be onerous limitations on the use of provided resources. It is reasonable for us to expect that a community like this could come up with a set of reasonable options for "working within the system" to get the situation corrected (e.g. the suggestions from Sanddrag and 527Point). If such solutions cannot be articulated, then it might be reasonable to identify alternate resources to achieve the real end goal (access to an appropriate programming environment for robot code development). It is likewise reasonable to expect that all of these responses can and should be made with full consideration of the property and ownership rights of the suppliers of the computer. To see a reponse to this query that is so contrary to the values and principles of this community is disturbing. As an analogy, when a corporation provides funding and/or support for a team, it is incumbent upon the team to utilize those resources in a manner consistent with the constraints under which they were provided. If a sponsor provides several thousand dollars to fund a team, but states that the team can only use the funds to pay registration fees and procure materials, the team does NOT have the right to say "screw that, we are using this money to pay travel expenses so we can all go to the cool regional competition in Anchorage." If they did that, the sponsor would be entirely within their rights to demand a complete refund of all the provided funding, and urge that such an irresponsible team be terminated immediately. What is being advocated above is no less egregious a violation of trust than the analogous example. If the provided advice is followed, the county would be perfectly justified in shutting down the team and punishing the perpetrators appropriately. My purpose here is NOT to flame the author of this suggestion. Rather, I believe that this should be used as an example from which to learn. We all need to understand what professional behavior is all about. Occasionally, that also means that we have to understand when we have crossed over the line. This is just such an example. We need to expect better behavior from ourselves if this community is going to survive and thrive. And when we do cross over the line, we need to bring ourselves up short and correct the situation. -dave Last edited by dlavery : 08-11-2005 at 03:14. |
| What does your school do for FIRST? | Matt Goulart | General Forum | 37 | 19-05-2008 22:26 |
| School problems | JIN | Team Organization | 34 | 22-07-2005 07:52 |
| robotics trivia | kewlkid382 | Chit-Chat | 63 | 16-03-2004 09:50 |
| What does the Chairman’s Award have to do with a robot contest? | Ed Sparks | Chairman's Award | 32 | 15-02-2004 13:39 |
| Fall Fury Results! | DirtyBird213 | Off-Season Events | 4 | 16-10-2003 17:11 |
