Go to Post teams that REALLY deserve to win will find ways to overcome a marginal officiating decision. Also, teams that REALLY deserved to win will try not to put themselves in that position. - Chris Hibner [more]
Unread 08-11-2005, 10:02
lgz108 lgz108 is offline
lgz108 is on a distinguished road
How to speed up the dc motor via BS2?
presently, i build a small surveillance robot with use of parallax basic stamp 2 microcontroller, when i plug my dc motor to it, i found that not enough faster the rotation of motor, got any idea to boost it up?
i suppose to modify the programming or add on a additional circuit?
Unread 08-11-2005, 13:04
Re: How to speed up the dc motor via BS2?
If you are attaching a motor directly to the BS2 than you will damage the BS2. You need to follow the BS2 with a motor driver of some sort. There are many applications on the Parallax website for this.
Unread 08-11-2005, 13:16
Billfred's Avatar
Billfred Billfred is online now
Just for reference, how big is the robot? Knowing what scale we're dealing with can do wonders.
Unread 08-11-2005, 15:33
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Are you using a servo modified for continuous rotation? Are you using a PULSOUT command? If so, what value is it at? You could always gear up the motor for extra speed but torque will be sacrificed.
Unread 09-11-2005, 03:35
really can damage the bs2, bcoz i am begineer to do that, i know parallax company provide many motor driver, but very costly, got other way to do that to save my cost...thank...
Unread 09-11-2005, 03:39
[quote=Billfred]Just for reference, how big is the robot? Knowing what scale we're dealing with can do wonders.[/QUOT
just very small acually,
http://www.parallax.com/detail.asp?product_id=30055
u can try to dload "The Boe-Bot Crawler in Action (.gif)" the sample inside, i get the idea from that concept...hope can help u
Unread 09-11-2005, 03:42
no, i direct buy a continuous rotation, can u give me more detail abot the programming code to speed up the rotation ro where have a relevant information to reference...thanks...
Unread 09-11-2005, 07:25
IGZ,
The BS2 cannot drive motor current, it must be followed by a motor driver. Sorry for the bad news. The BS2 outputs can only supply a few milliamps of current at a maximum of 5 volts. The motor will need much more than that even if it is a 5 volt motor. If you are only driving the motor in one direction, you may be able to get away with a power darlington transistor feeding the motor. Can you give us more specifics about the motor and your application? In the meantime, don't drive the motor with BS2 so you can save yourself the cost of replacing that item.
Unread 14-11-2005, 14:26
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
robotroom.com
http://robotroom.com/HBridge.html is the exact link for u
on this site somewhere is a link on how to make your own motor controllers, for smaller scale robots i would recomend this site, i have read the site autor's book and it makes everything very simple, a must for smaller scale robots
KK4KQO
http://voltair.us
Electronic Speed Controllers for DC Motor Spindle Robotics Education and Curriculum 12 23-04-2005 09:18
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
