Go to Post "Please, please, please? Pretty please? I'll get you Mountain Dew..." - Karibou [more]
Unread 12-10-2005, 23:28
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: EEPROM Code
It risks getting caught in an infinite loop waiting for the queue and breaks the comm sync on the controller?
Matt Krass
Unread 12-10-2005, 23:29
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: EEPROM Code
Originally Posted by Kevin Watson
Ugh, I just realized this code will cause the red-light-of-death. Anyone care to venture a guess as to why it won't work? I'll post corrected code tomorrow-ish.
-Kevin
I'm not sure, but I don't like that while
// wait, if necessary, for a free slot on the circular queue
while(EEPROM_Queue_Free_Space() == 0);
Won't that keep looping until the queue is full (which it never will be if it never leaves that loop)?
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 12-10-2005, 23:31
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Re: EEPROM Code
Which is the ultimate result of what I mentioned (put more nicely).
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 13-10-2005, 09:52
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
Re: EEPROM Code
Kevin,
I haven't tried this, but from the PIC documentation, it looks like you only have to disable the interrupts during the period that you call "pre-write sequence" and "execute the write" in the EEPROM_Write_Handler routine. You should be able to re-enable the interrupts after these 3 lines (from the 39609b Microchip document, section 7.4) rather than waiting until the 2ms write is complete. This may also eliminate the code error by allowing the high priority interrupts to mostly go on schedule.
Mike
Unread 13-10-2005, 13:38
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: EEPROM Code
Yep, it's the while loop. I'm trying to write ninety-one bytes, but the queue only has sixteen slots. The code sits in the for loop and eventually EEPROM_Queue_Free_Space() returns zero forever because EEPROM_Write_Handler() isn't getting called to do the actual EEPROM write. The only way the code would work is if he queue size were changed to ninety-one slots. The trig table code seems like something that teams could use, so I'm writing a version that'll generate sin()/cos() and tan() tables in EEPROM. I'll also write the code to do the table lookup.
-Kevin
Kevin Watson
http://kevin.org
Unread 13-10-2005, 14:25
FRC #2429
Re: EEPROM Code
Originally Posted by Mike Bortfeldt
Kevin,
Thanks for the suggestion. I'd heard from another source that interrupts had to be disabled for the entire period to ensure a reliable write. As I wasn't sure what the answer was, I decided to err on the conservative side and disable interrupts globally for the entire period (at least on the first revision). When I get some time to work on it, I'll talk with the folks at Microchip to see what they say.
That isn't a problem because the high-priority interrupt never gets disabled (i.e., EEPROM_Write_Handler() never gets called). The problem is that getdata() and putdata() won't be called once the code gets stuck in the while() loop, which makes the master processor cranky. BTW, if EEPROM_Write Handler() gets called from Process_Data_From_Master_uP(), disabling the high-priority interrupt isn't a problem because it won't fire-off again until the next SPI packet arrives from the master processor in a period of time much greater than two milliseconds.
-Kevin
Kevin Watson
http://kevin.org
Unread 13-10-2005, 16:46
CJO's Avatar
CJO CJO is offline
Re: EEPROM Code
On a slightly different topic, does the addressing go from 0 to 1023 or 1 to 1024?
i.e. can I write to 0?
Unread 13-10-2005, 16:51
FRC #2429
Re: EEPROM Code
The range is 0 to 1023. I guess I should add that bit of information to the read me file.
-Kevin
Kevin Watson
http://kevin.org
Unread 13-10-2005, 16:59
CJO's Avatar
CJO CJO is offline
Re: EEPROM Code
Thanks, this makes it perfect for recording tables
If you want (say) a table with the five attributes in each row
0, 5, 10, . . . = attribute a
1, 6, 11, . . . = attribute b
2, 7, 12, . . . = attribute c
3, 8, 13, . . . = attribute d
4, 9, 14, . . . = attribute e
Then to find a specific row number, you would take the row number, multiply by 5 and subtract five, and then start reading values?
Unread 13-10-2005, 19:29
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: EEPROM Code
As a rule of thumb, software people always count starting with 0.
Unread 13-10-2005, 21:46
CJO's Avatar
CJO CJO is offline
Re: EEPROM Code
I have met one or two systems which did not, and not having a controller with me at the moment to test it out, I figured I might as well ask.
Unread 14-10-2005, 02:18
FRC #2429
Re: EEPROM Code
I just wrote and tested some quick-n-dirty trig table code. Grab a copy of the EEPROM code here and add the code below. I only create a table covering zero to ninety degrees because sin(x) in the other three quadrants can be derived using sin(x) data in quadrant one (exercise left to the student). I'll release a more polished version at a later time.
This code creates the table:
#include <math.h>
#include "printf_lib.h"
#include "eeprom.h"
* FUNCTION: Sine_Table()
* PURPOSE: Creates a sine table in EEPROM
* CALLED FROM:
* PARAMETERS: Unsigned int containing the address.
* RETURNS: 1 when finished creating table, 0 otherwise
* COMMENTS:
unsigned char Sine_Table(unsigned int address)
static unsigned char angle = 0;
static unsigned char done_flag = 0;
static unsigned char sine;
if(EEPROM_Queue_Free_Space() > 0 && done_flag == 0)
// calculate normalized sine value
sine = (unsigned char)255.0 * sin((float)angle * 3.14159265 / 180.0);
// write the angle and sine value to EEPROM
EEPROM_Write(address + angle, sine);
// send diagnostic information to the terminal
printf("writing x=%u sin(x)=%u\r", (unsigned int)angle, (unsigned int)sine);
// are we done?
if(angle == 90)
done_flag = 1;
printf("Finished!\r\n");
else
angle++;
return(done_flag);
This code verifies that EEPROM was written correctly:
* FUNCTION: Verify_Sine_Table()
* CALLED FROM:
* COMMENTS:
unsigned char Verify_Sine_Table(unsigned int address)
if(done_flag == 0)
if(EEPROM_Read(address+angle) == (unsigned char)(255.0 * sin((float)angle * 3.14159265 / 180.0)))
printf("angle=%u verified\r", (unsigned int)angle);
else
printf("angle=%u failed\r\n", (unsigned int)angle);
if(angle == 90)
done_flag = 1;
printf("Finished!\r");
else
angle++;
return(done_flag);
This code goes into Process_Data_From_Master_uP():
if(Sine_Table(0) == 1)
Verify_Sine_Table(0);
EEPROM_Write_Handler();
-Kevin
Kevin Watson
http://kevin.org
Unread 09-11-2005, 14:11
kc8nod's Avatar
kc8nod kc8nod is offline
AKA: Ted Hansen
FRC #1216 (Knights)
kc8nod is on a distinguished road
Re: EEPROM Code
-Kevin
Hi Kevin,
I've got a question about EEPROM_Write().
unsigned char EEPROM_Write(unsigned int address, unsigned char data)
	unsigned char return_value;
	// return error flag if the queue is full
	if(eeprom_queue_full == FALSE)
		// put the byte and its address on their respective circular queues
		eeprom_queue_data[eeprom_queue_write_index] = data;
		eeprom_queue_address[eeprom_queue_write_index] = address;
		// increment the queue byte count
		eeprom_queue_count++;
The parameter address is an unsigned integer, but eeprom_queue_address is an array of unsigned chars. Aren't you chopping off two bits from the address? Or did you mean to define eeprom_queue_address as an unsigned int also?
Unread 09-11-2005, 15:09
FRC #2429
Re: EEPROM Code
Originally Posted by kc8nod
Hi Kevin,
Ugh, It may be a bug, but I won't have time to look at it until this evening.
-Kevin
Kevin Watson
http://kevin.org
Unread 09-11-2005, 18:36
FRC #2429
Re: EEPROM Code
Hi Kevin,
Yep, it certainly looks like a bug, an old bug. I'm not sure what happened, but the latest code isn't on the website. I'd added a EEPROM_Wipe( ) function and incorporated the change Mike Bortfeldt suggested (above), but for some reason the code never got uploaded. I guess I'll have to up the dosage on my brain fart medication <grin>. Thanks for catching this.
-Kevin
Kevin Watson
http://kevin.org
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Code suddenly fails to initialize miketwalker Programming 11 19-02-2005 15:23
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
