Go to Post FIRST - Breaking stereotypes everywhere - Sparks333 [more]
Unread 10-11-2005, 21:44
tyguy2021's Avatar
tyguy2021 tyguy2021 is offline
FRC #1839 (TechAttack)
Team Role: Webmaster
tyguy2021 will become famous soon enoughtyguy2021 will become famous soon enough
Question Led
Me and a freind were trying to make a led Ir light conect to a responder so when the light is picked up it turns on a small dc moter. for some reson it didn't seem to work. help
Unread 10-11-2005, 21:49
Re: Led
you have supplied no information on what parts you used, what sort of motor you are trying to power, the distance involved, power supplies or batteries available...
If you are learning this from scratch you might try one of the experimenter kits from Radio Shack, or stop at your library and pick up a book on the subject.
It would be very difficult for anyone on this forum to design your circuit for you, because we have no idea what you are trying to do.
Unread 10-11-2005, 22:33
tyguy2021's Avatar
Re: Led
first - i don't want my circuit designed for me
second -its just a small 3v moter from radio shack and we had the responder working as a switch and the current was going Though and powering the moter. We were trying to get it to turn off with the LED.
third - the battery for the moter circuit are 2 double A's the LED was being run off a triple a.
forth - they only need to be spaced .75 in apart
Unread 10-11-2005, 23:24
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: Led
First off, what's this responder you speak of? Is it some circuit you built or is it something you bought? We need some details on this.
I'm also not sure what exactly your problem is. You said that the motor is being powered. What's not working correctly?
You mentioned having two separate power supplies. This implies that you have two seperate circuits. I'm going to take a guess and say that you have some sort of transmitter and some sort of reciever. It sounds like your transmitter is some sort of IR LED circuit. And it sounds like your reciever is some sort of IR detector that turns a motor on when it sees the LED. Is this correct?
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 11-11-2005, 10:27
tyguy2021's Avatar
Re: Led
yes thats correct, we had the power running though then we where gong to try and have it pic the LED up and shut down the moter.
Unread 11-11-2005, 10:33
Re: Led
can you draw up your circuit and post it here as a pdf or jpg (free pdf conversion SW at www.pdf995.com) ?
include the part numbers of the LED and sensor you are using.
My psychic powers must be a little off today, I cannot see your circuit or prototype from here :^)
Unread 15-11-2005, 20:53
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: Led
If i am correct u have two circuits one with a AAA battery and an IR LED,
--------problem 1 i think there is not enough power for that IR LED from one AAA and if u didnt use a resistor the LED might be dead now, go find the starts for that LED and post what the current draw is.
For the receiver, i think i may know what u are talking about it is a thing that has two or three little posts coming out of it and it looks like a weird LED, a pinout for that would be useful as well as a wiring diagram so that we are sure that it is all hooked up and going to work like u are hoping.
KK4KQO
http://voltair.us
Unread 15-11-2005, 21:30
Re: Led
I am going to make an assumption that you just connected the IR LED to the battery and hoped that it would emit. A second assumption is that you connected the motor the receptor and the batteries in series. In this case the LED lighting the receptor would turn it "ON" causing the motor to turn. LEDs are strange little devices that cannot control themselves when connected to a power source. An LED requires 2 volts to turn on so a single battery will not light it. An LED also needs some current limiting to prevent damage so you need to make a calculation to set the current to about 25 ma or whatever the design current needs to be. As to the photoreceptor you can think of it as a transistor with no base lead if it only has two leads. It would work best if you tie the emitter to the negative lead of the battery, the collector to one lead of the motor and positive lead of the battery to the other motor lead. The emitter will act as a switch, turning on when illuminated by the LED.
Now things will get complicated. If you purchased an IR detector module it may need to have a modulated beam from the LED. The remote for your TV uses a modulated beam to prevent things like the sun and lamps from affecting the remote commands. We really need to know what you are using. Part numbers and source.
Running a LED on 6v? Chriszuma Electrical 23 15-03-2005 18:06
Making a beacon indicator LED burn its brightest without burning out DanL Electrical 7 26-01-2004 08:05
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
