Go to Post Programming team motto: If it doesn't work, use a bigger hammer. - WizenedEE [more]
Unread 11-11-2005, 01:30
varcsscotty varcsscotty is offline
Programmer
FRC #1571 (Braughtswurst)
varcsscotty is an unknown quantity at this point
Lightbulb Nintendo Style Speed Booster
ok so we've all played the classic nintendo racing game where you hit the "Z" button and you get a booster, or whatever. What if this could be implemented in a robot.
Say I have a 'dead-band' around my joystick inputs so that they can only go so fast for extra control. But there are those times when you want to get across the field as fast as possible. Alas, The Speed Booster!
Quite simple actually to program, but it may be hard on the machine, I dunno. The program would just include the dead-band code but with a variable for the top joystick input. When the button is pushed, max out the variable. Simple, eh?
Basically the joystick would have some sort of desensitizing function on it but when the button is pressed it is undesensitized...that's not a word is it...
PS I don't know if there is another thread about this topic because the javascript pop-up menus appear to be broken for FF.
Unread 11-11-2005, 01:43
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Nintendo Style Speed Booster
People do this all the time.
If you had a super fast robot and wanted to slow it down for precise movement, I could see using it.
It seems like a waste to limit the power of your motors when using this option as if it were a psuedo 2 speed transmission, however.
2001-2004: Team 100
2006-Present: Team 254
Unread 11-11-2005, 02:04
Hieb Hieb is offline
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
While it may be a waste, for teams with limited resources (money or experience) it is sometimes the only way to achieve 2 speeds.
During our rookie season, we had no driver practice prior to shipping, so it was during our first practice round that we discovered that it was very difficult to control while turning. We used software to scale down our top speed to 1/3 during normal operation, and tied the thumb button on the joystick to full speed while travelling straight. Very inefficient, yes, but given the time constraints and lack of experience I think it was a good solution to the problem. And it was kind of fun to see the robot just kind of crawling along, and then suddenly take off at full speed.
Unread 11-11-2005, 06:26
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
We actually had a total mechanism for this. If you look on our robot its 4 wheel drive but with a twist. There is a mechanism that is controlled by a motor that pushes a pair of castors onto the ground at the front, thus enabling much more manourveablility, at the expense of power. The idea was that you use 4wd to get the tetra to the goal and use the castors to align it more accurately. However the welds got smashed off during a nasty bump in one of the later rounds.
This pic is the best i can find.
If you look there there is a V shaped piece, which was later attached to the black motor. We then added a little flag that went up when the castors were down.
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 11-11-2005, 07:21
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
For our 2005 robot, it was crazy fast and jerky when trying to get the precision needed to cap well. So we made the trigger button on the joystick decrease the robot's top speed by 2/3 or so.
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 11-11-2005, 07:47
REVving up for a new season
FRC #2848 (All-sparks)
it really isn't limiting the power of the motors. since the IFI setup uses pwm(pulse width modulation) the motors are still receiving maximum voltage, it is just the pulse length that is shorter. and since
Torque(transmitted to the shaft) = (Horsepower*63000)/rpm
and since 1 HP = 745.699872 watts
and watts= voltage^2/ohms <--constant in this case because resistance of the motor doesn't change and neither does the voltage.
the total torque transmitted at a given rpm is the same, all that is being changed is your speed. This is the same thing that happens when you push the joysticks only a little bit forward.
we did this this past year and it works very well for precise movements on the field.
although to make a "speed boost" button you would have to be limiting your pwm the whole time except when you want to boost, which would be a waste.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 11-11-2005, 07:52
Gdeaver Gdeaver is offline
FRC #1640
While not the same as programing 2 response curves, you could use an exponential response function to give a larger low speed area on the joy stick. Thats what our team did last year.
Unread 11-11-2005, 09:43
Dave Scheck's Avatar
Dave Scheck Dave Scheck is online now
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
First off, shame on you for making me feel old ...classic nintendo turbo will always be the "B" Button
We've actually been using such a system for years. We usually use the top button on the joystick as our "turbo" button. The trick is that when the button is not pressed, we scale the full range of the joystick so that it maps to +- half speed. When the button is pressed, we take this scaling away and the full joystick maps to the full output.
Unread 11-11-2005, 10:49
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
This is wrong but I don't think I should delete it, just didn't want anyone to pay attention to it:
No they're not. To control the speed of a DC motor, you vary the voltage applied to it. PWM is used solely as a communication mechanism between the RC and the speed controller. It's not used for controlling the actual motor (you'd probably break the motor if you tried). The actual inside of the speed controller consists of an H-Bridge which allows for variable voltage control. So, by limiting the speed, you're also limiting the torque output from the motor. However, you may want to do this as it can allow finer grained control over the robot.
Matt
Unread 11-11-2005, 11:15
The Victor speed controllers do use pulse width modulation of the power to the motor. The H-switch inside them is a digital device, either completely off or completely on in one direction or the other. The average voltage to the motors is controlled in approximately 1% steps, but the peak is always full battery voltage.
Unread 11-11-2005, 11:36
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
lol I was going to say the same thing. "classic" stuff doesn't have "Z". However, you might be able to make a case that they may have A, B, X, Y, L, and R.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 11-11-2005, 11:43
Go back one more generation and you only have A and B...ahh, those were the days.
Unread 11-11-2005, 11:44
You're right about the PWM control although I'd say the H-bridge is also an analog device but that's beside the point. I really need to think through before I post.
While peak-voltage is still the same, the voltage changes over time. What that means is that the power is changing over time. But it's happening fast enough that it's really not noticable. Instead, you'd be looking at the average voltage for power calculations, not peak power.
Matt
Unread 11-11-2005, 12:11
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
First, you should check your formulas. "Watts" = Voltage^2/R (and note that "Watts" should really be Power) is the electrical power to the motor. Considering it is not perfect, there are lots of losses and the mechanical power available at the motor output is omega times torque. They're not the same and the electrical power (supplied) will always be higher.
Second, the PWM does change the voltage seen by the motor. Even though you are pulsing it between 12V and 0 V, the motor can be seen as an RL (resistor-inductor) series association and thus this pulsed voltage is smoothed and you get an average voltage that is proportional to the PWM duty cycle. I don't want to extend and there are lots of old posts about it, good information can be found there.
When you change the voltage to the motor, you can simply scale its speed/torque curve by a factor of (applied voltage/test voltage), so you are actually changing both its speed and torque (and power, as a consequence).
Concerning the speed boost, we used that one year. It sucked.
The only possible use I see is to make a very fast robot a bit more controllable, but then again your gearing is probably wrong and you are (again) wasting power.
To me, the "coolness factor" of this solution can really hinder your performance.
If your opponent is coming at you with 4 CIMs full power, why in the world would you want to get in a shoving match with your robot at 70%?
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 11-11-2005, 12:49
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Remember, however, that such software limitations in no way approximate the functionality of a multiple-speed, mechanical transmission. They're simply a convenient way of limiting your students' lead feet.
Our team met last night to implement 'follow-wheels' on our 2005 robot and did so with great success -- or so I'm told; I was busy doing something else. These unpowered wheels, coupled to encoders, remove from our drivers consideration any notion of voltage or power and instead make them concerned only with position. The joystick input no longer controls average voltage, but instead indicates desired position or speed. The feedback loops do the rest in making sure the robot does what it's meant to do.
--Madison--
...down at the Ozdust!
Electronic Speed Controllers for DC Motor Spindle Robotics Education and Curriculum 12 23-04-2005 09:18
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
Joining 2 dif. motors K.Shaw Motors 32 14-10-2004 19:40
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
