Go to Post "It was defense killed the beast." - Justin [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 10-11-2005, 18:26
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Quick question relating voltage across compacitor
Im doing a problem and I am slightly confused about the voltage across a compacitor. I know it is either:
(1/C)integral(i)+v(0)
or
(1/C)(integral(i)+v(0))
Which one is it?
Unread 10-11-2005, 18:30
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Re: Quick question relating voltage across compacitor
or
Which one is it?
The first one. The v(0) takes the place of the constant C that you get in generic integration. It's the initial voltage of the capacitor. In most cases, the initial voltage is zero.
Matt
Unread 11-11-2005, 19:39
Adam Y.'s Avatar
Adam Y.
no team (?????)
Matt
Yeah. That's what I copied down thanks. I just wanted to make sure I did not leave out a parenthesis because doing that results in two completely differnt problems.
Quick Simple Question ImmortalAres Programming 8 17-06-2005 13:08
a quick function question Kashi Chan Programming 3 06-03-2005 20:44
A quick IR sensor question PBoss Programming 7 28-03-2004 21:02
Quick question about the ramp archiver 2001 1 23-06-2002 22:51
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
