Go to Post I guess this is where theory vs reality comes into play. - PhilBot [more]
Unread 13-11-2005, 00:23
Zoheb N Zoheb N is offline
Captain
FRC #0118 (Robonauts)
Zoheb N is just really niceZoheb N is just really niceZoheb N is just really niceZoheb N is just really nice
Send a message via AIM to Zoheb N
Attatching an axel to a wheel
I know the tile sounds a little childish, but I was wondering how do you guys attach your axels to your wheels so that the axel isn't free moving?
2004 Lone Star Engineering Inspiration
2005 Denver Regional Winner
2005 Denver Radio Shack Innovation in Control Winner
2005 Lone Star General Motors Industrial Design Winner
2005 Lone Star Regional Winner
2005 Lone Star Regional Chairman's Winner
Unread 13-11-2005, 00:24
Re: Attatching an axel to a wheel
best way is with a slotted axel and a key.
Dont even think of using a set screw!
Unread 13-11-2005, 00:28
Timmyd's Avatar
Timmyd Timmyd is offline
HAHA...i like pi
AKA: Tim
FRC #0022 (Double Deuce)
Timmyd is just really niceTimmyd is just really niceTimmyd is just really niceTimmyd is just really nice
Send a message via AIM to Timmyd
unless it holds the key stock in place
[center]Our robot's name is HOMER, it stands for Human Operated Mechanicaly Engineered Robot
Our team name is Double Duece 22
If all else fails... blame the PROGRAMER
Unread 13-11-2005, 03:53
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Exactly. Set screws can be quite good if used properly.
696 has always keyed the axle (and bore of the wheel) with a standard straight key/keyway. A few teams use a hex shaft and matching hex bore in the wheel. Other teams allow the wheel to free spin on the the shaft and affix a sprocket or whatever directly to the wheel.
Shaft collars, flanged bearings, e-clips, and whatnot are all good ways to keep a wheel from moving linearly along the shaft too.
Let me know if you have any more questions.
Unread 13-11-2005, 11:54
Jason Kixmiller's Avatar
Jason Kixmiller Jason Kixmiller is offline
IWIWAB
FRC #1747 (Harrison Boiler Robotics)
Jason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to behold
Send a message via AIM to Jason Kixmiller
According to Mr. Bill (team Hammond, 71), if you don't want it to move, weld it. While this may be difficult due to the material the wheel hub is made of, some teams will weld the sprocket to the axle and then bolt the wheel to the welded sprocket.
This is an extremely robust method of attachment, though if anything breaks, the whole axle must be replaced including the sprocket.
Unread 13-11-2005, 12:34
Rod's Avatar
Rod Rod is offline
Rod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to behold
Send a message via AIM to Rod
If you want to avoid broaching a slot a round pin can be used. Examples can be seen Here.
Check out 2006 Robot CAD. Look at the wheel and shaft.
-Rod-
Team 662
Colorado Springs, CO
Unread 13-11-2005, 12:41
Pins are one of the weakest ways to go. Its difficult to calculate the impact shear forces a pin will see, in a collision for example.
Ive seen many axel pins break, and Ive seen a 0.5" diameter axel break where the pin was located, due to the reduction in cross sectional area the hole produces in the shaft.
BTW, they use pins on the props for small outboard motors - and they call them shear pins - they are intended to break if the prop hits a rock - saves the prop
A robot with failed drive train, motors spinning and bot going nowhere, is one of the most common failures you see at FIRST competitions.
Unread 13-11-2005, 15:13
Rod's Avatar
Rod Rod is offline
Ken,
Are you are speaking of a pin located perpendicular to a shaft, as is the case of a prop shear pin, or a pin located parallel to the shaft, as the drawings show? I do not disagree with you, just want a clarification.
-Rod-
Team 662
Unread 13-11-2005, 15:21
Ken,
I was referring to perpendicular pins that take all the torque applied to the wheel. I have spent many hours replaceing those at competitions.
I clicked into the drawings and I think I found what you are talking about. The pin is wedged between the wheel and the shaft, to hold the key tight on the opposite side?
Why not tap the shaft and put a small bolt with a large washer on the end, to keep the key from slideing out? that would make it easier to remove / replace the wheel.
Unread 13-11-2005, 15:42
Rod's Avatar
Rod Rod is offline
Ken,
The shaft is tapped and there is a bolt on the wheel to hold it on.
Look again.
-Rod-
Team 662
Unread 13-11-2005, 17:49
Ken,
Look again.
so whats the purpose of the pin then?
Unread 13-11-2005, 20:30
Timmyd's Avatar
HAHA...i like pi
AKA: Tim
we actually had to drill and tap hole at comp so $@#$@#$@# to keep the wheel from coming off the c clip channel was not deep enough and our wheel had about an 1/8" from falling off
Unread 13-11-2005, 20:36
Rod's Avatar
Rod Rod is offline
This should make things clear as mud.
-Rod-
Team 662
Unread 13-11-2005, 20:40
Timmyd's Avatar
HAHA...i like pi
AKA: Tim
what did i say i must have typing turrets
Unread 13-11-2005, 20:51
Smrtman5's Avatar
Smrtman5 Smrtman5 is offline
Dr. Bridgeport
AKA: Jon H
FRC #0041 (Robo-wariors)
Smrtman5 is on a distinguished road
Send a message via AIM to Smrtman5
Is there any reason a pin such as that would be used over a keyway? Or would it just be used if you didnt have the correct broach?
Art is just an excuse for poor craftsmanship.
- Jon H
Team 41
Rowan University '10 Mechanical Engineering
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
Steering wheel issues jgannon Programming 5 15-12-2004 10:14
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
