Go to Post My team is graduating yet another class of great kids who will go into the world capable and focused. And after a decade and a half of FIRST robotics those memories are as treasured as any trophies. - Wayne C. [more]
View Poll Results: Vote on your favorite kit sensors
Accelerometer 18 28.13%
Hall effect sensors 16 25.00%
CMU cam 24 37.50%
Rotary encoder (new in 2006) 42 65.63%
Pots (new in 2006) 28 43.75%
Banner sensors (old stuff) 13 20.31%
Gyro (old stuff) 21 32.81%
I/R beacon (old stuff) 7 10.94%
Multiple Choice Poll. Voters: 64. You may not vote on this poll
Unread 13-11-2005, 14:52
Re: Kit item request for 2006
Originally Posted by Bill_Hancoc
We thought of doing that and had plans to utilize one and were testing different mice until I realized, if you move the mouse forward it reads a forward movement; if you move the mouse backward it reads a backward movement; unless you have an omni bot which contiunssly has the same NSEW orientation to the field it wont work. ie If you go forward then turn the mouse 90 deg right adn then go forward again the mouse will still register forward movement. It doesnt reconize rotation.
Easy Fix:
Every program loop, use a gyro to measure your angle of rotation relative to the last loop. Take the distance measured by the mouse, and use trig to keep a running total of total distance traveled in each direction. (X, Y)
Unread 13-11-2005, 15:28
Gdeaver Gdeaver is offline
FRC #1640
As far as Ir sensors I've only see posts for the banner sensors. Sharp makes a series of IR analog distance sensors that are inexpensive and quite accurate in their range. Has anybody used them on a first robot before?
COTS parts that were in the kit? Dave Flowerday Rules/Strategy 13 03-03-2005 12:24
need standard kit gearbox Korbin Kit & Additional Hardware 0 15-11-2004 21:18
What Item Would You most Like to See in the Kit of Parts? Ragin_Kage Chit-Chat 15 14-03-2002 19:22
precision grade aluminum extrusion - item MB Kit Loren 930 Technical Discussion 2 11-01-2002 21:42
