Go to Post I'm excited. Probably too much, but eh, I'm a big geek. - Brandon Martus [more]
Unread 11-11-2005, 17:45
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
binary in C
Does anyone know if it's possible to use binary numbers in C? Of course, it's just to make it easier to read the source. I'm doing some bitwise operations and 218 or 0xDA just isn't as meaningful as 11011010.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 11-11-2005, 18:28
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: binary in C
I don't believe the C standards have any support for entering numbers in binary. Just use hex - it'll be awkward for a bit but after a while you'll be able to read hex and "see" the binary without any trouble. Binary becomes cumbersome when you start talking about 16 and 32 bit (and larger) numbers too.
Most people who write a lot of software will tell you that 0xDA is much easier to read than 11011010.
Unread 11-11-2005, 19:41
Electrical Engineer
Rookie Year: 1995
Re: binary in C
I'm 1200 miles from my K&R right now...
0b11011010
should be equivalent to
0xDA
N'est-ce pas?
Mike Betts
As easy as 355/113...
Unread 11-11-2005, 19:58
Software Engineer
Rookie Year: 1995
Re: binary in C
0b11011010
0xDA
That's what I thought at first too, but gcc didn't seem to like it, and I found several discussions on some C newsgroups that suggested that binary constants aren't officially part of the language. However, I just checked it and MCC18 seemed to take it...
My advice still applies though: get used to hex, it's what everyone else uses
Unread 11-11-2005, 20:07
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: binary in C
Originally Posted by K&R, page 37
"The value of an integer can be specified in octal or hexadecimal instead of decimal. A leading 0 (zero) on an integer constant means octal; a leading 0x or 0X means hexadecimal".
So apparently you can't, unless the C18 compiler is different in that aspect (it isn't a 100% ANSI C, after all) - assuming you are asking this about the Microchip compiler.
I agree with Dave that the hexadecimal form is much better once you get used to it.
You probably know it, but for the ones that do not, each hex symbol represents 4 bits. Once you realize that, it just isn't magic anymore.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 11-11-2005, 20:11
ghansel ghansel is offline
my amp goes to eleven
AKA: George H.
FRC #0019 (Big Red Robotics)
ghansel is infamous around these parts
Re: binary in C
0b should work. It's not ANSI C, but many compilers understand it. gcc compiles it fine. Dunno about C18 - I usually go out of my way to avoid binary.
http://refcards.com/refcards/c/c-refcard-letter.pdf
George
Unread 11-11-2005, 20:41
Electrical Engineer
AKA: Phil Baltar
FRC #1351
Re: binary in C
Well, I'm using SDCC. I'd use C18, but it doesn't work for the 16F series PICs. I just tried 0b and it didn't like it. I guess I'll have to stick to hex or decimal.
Version: 3.12
Unread 12-11-2005, 01:09
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: binary in C
The gcc port for Atmel AVRs supports it no questions asked, it's actually fairly used in the examples I saw so 0b works there.....
No support in SDCC? Darn I was gonna use it for this 16F I got sitting here. Oh well...
Matt Krass
Unread 13-11-2005, 15:39
JJG13's Avatar
JJG13 JJG13 is offline
Yoda
AKA: Joshua Graffman
None #0180 (SPAM)
JJG13 has a spectacular aura aboutJJG13 has a spectacular aura aboutJJG13 has a spectacular aura about
Re: binary in C
I sometimes use a calculator to convert from binary to hex and then write the binary equivalent in a comment by the hexadecimal value. For example:
int bit2mask = 0x04; //00000100b
Behold the power of SPAM.
Unread 13-11-2005, 22:12
Re: binary in C
#define b00000000 0x00
#define b00000001 0x01
#define b00000010 0x02
#define b00000011 0x03
#define b11111110 0xFE
#define b11111111 0xFF
Generate 256 lines once, then let the preprocessor take care of it for you from then on.
Binary in Rose is Rose MisterX Chit-Chat 8 11-02-2004 18:26
pic: Dawning of a New Age. CD47-Bot Extra Discussion 90 31-07-2003 22:04
Fun with sensors Team852 Technical Discussion 7 06-01-2003 00:07
A couple of noodle scratchers Cheese Head Programming 11 07-12-2002 09:59
delphi: binary sort archiver 2000 0 24-06-2002 00:30
