Go to Post There is almost always more than one solution to any engineering problem. One part of elegant design is picking the one that makes the most sense for a particular design problem, even if that means "breaking" some normally established "rules". - Jeff Pahl [more]
Unread 13-10-2005, 01:47
114gopher's Avatar
114gopher 114gopher is offline
Co-Captain
AKA: Adam Garcia
FRC #0114 (Eagle Strike)
Team Role: Student
114gopher will become famous soon enough114gopher will become famous soon enough
Send a message via AIM to 114gopher
DARPA Sensors
After hearing about the DARPA competition and success of many of the robots, I've decided that I would like to build a smaller one of my own. I want to start off small and just have it be able to travel about 100 feet, so it will most likely be an RC car sized robot, which means no giant sensors hanging from the bumper. I was wondering if anyone knew what sensors the teams used, and where they can be purchased. Hopefully I am not going in over my head, and if you have any advice, I'd love to hear it!
Unread 13-10-2005, 08:13
patTeam241 patTeam241 is offline
College Student
AKA: Pat Cleary
patTeam241 will become famous soon enoughpatTeam241 will become famous soon enough
Send a message via AIM to patTeam241
Re: DARPA Sensors
If you're interested in what sensor's different teams used, look at www.grandchallenge.org, which is the competition's website, or at the individual teams websites. I remember looking briefly last year at the wide variety of devices used. They ranged from gps systems to complex (I assume) laser scanning systems and radar systems. I don't know what you're capable of, but some of this stuff would be well over my head I know.
That said, if you're interested, supposedly you can get GPS to work with a simple microcontroller. I know this was covered at least briefly in one issue of Servo Magazine if that helps. Besides GPS, there are sensors that won't break the bank and are small enough to fit on a r/c car that will accomplish the same goals. Infrared and ultrasonic sensors both can serve to tell you if there's anything in front of the car, and accelerometers, gyroscopes, and digital compasses can provide some idea of how your robot is oriented and are available online at many robotics sites. I would suggest looking at www.parallax.com.
Good luck, building an autonomous robot is an interesting problem, nad has applications that would serve a FIRST team well.
Unread 13-10-2005, 08:52
REVving up for a new season
FRC #2848 (All-sparks)
Re: DARPA Sensors
Most teams used the following:
Differential GPS: gps with a land based correction signal for accuracy of inches instead of 10-15 ft (like the garmen ones you can buy)
~$3,000 + cost of correction service
LADAR: Laser distance and range finder. A single beam laser that spins along a spectrum at 180 degrees to map terrain in front of vehicle. (most teams used ones made by SICK)
~$6,000
Stereo optic camera set up: allows the computer to sense distance just like your eyes (uses at least 2 cameras)
~$500 per camera
Other sensors used:
Encoders - ~$50 a piece
Radar - no idea we didn't use one
Laser point sensors - no idea we didn't use any
The darpa challenge was extremely expensive to compete in, Stanford had a $500,000 budget and CMU was close to $10,000,000. What I am trying to say is don't get discouraged. There are other ways to do obstacle avoidance and stay on track. For your project I would say you are going to need a GPS and probably at least a sonar/radar system to work well.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 13-10-2005, 09:19
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: DARPA Sensors
Three words: FIRST Grand Challenge
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 13-10-2005, 09:52
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Thumbs up Re: DARPA Sensors
Many teams also used inertial navigation for times when GPS went out. These can also be used for sensing tilt angle. I compete in a competition called IGVC (intelligent ground vehicle competition) which is a very close thing to darpa, but our robots have a minimum length of 3 feet and the course is only 10 feet wide at the widest parts. You may be able to find some info here http://www.igvc.org/deploy/ We use Sick LMS (laser measurement system) now, however in the past we used an array of 8 sonar units from Polaroid cameras.
BTW our darpa vehicle can be found here
http://team.cartlink.org/
I hope to post some news about igvc soon, also igvc was mentioned in a post by Jack Jones
http://www.chiefdelphi.com/forums/showthread.php?t=38640&highlight=igvc and yes I am proud to be the member he spoke of.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 13-10-2005, 10:20
Re: DARPA Sensors
http://www.chiefdelphi.com/forums/fo...c&daysprune=-1
and our team can be found here. http://gcart.rit.edu
Unread 13-10-2005, 10:46
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: DARPA Sensors
I can see ith now....Autonomous Segways must complete a 25 mile course through city streets during rush hour
Unread 13-10-2005, 12:06
Re: DARPA Sensors
for that i would defiantly use one of these
http://segway.com/segway/rmp/
Unread 13-10-2005, 14:19
Greg Young Greg Young is offline
Science Enabler
FRC #0587 (Hedgehogs)
Greg Young has a spectacular aura aboutGreg Young has a spectacular aura about
Re: DARPA Sensors
Check out Robo-Magellan. The robots are less than 50 pounds and must fit in a 4 foot cube. The straight line distance from start to finish is less than 300 feet, although it is not possible to follow a straight line due to obstacles. This sounds like what you're interested in.
As I recall the original rules came from the Seattle Robotics Society . They ran a competition last weekend at Robothon in Seattle. The Portland Area Robotics Society also ran a competition at PDXBOT back in April. The PDXBOT site has a number of pictures. Several of the entrants look to be based on RC trucks. Several of the PARTS members participate in Robo-Magellan and there has been some Robo-Magellan traffic on the PARTS mailing list recently. I'm sure the folks there would be happy to offer advice.
Greg
Unread 13-10-2005, 16:24
occra 23.
AKA: ryo
None #1481
Re: DARPA Sensors
if you have a mindstorms kit or two around, play around with sending the IR signals from the rcx and then use the light sensor (or multiple light sensor) to have an IR "radar" thingy.. i havent really worked too hard on this as im not much of a programmer but i have tried it enough to prove that it does work. obviously it works better on whit walls and not so well on skinny obstacles.. but if you worked hard its definitly a way to have a lego robot capable of avoiding obstacles without having to come in contact with anything. makes for faster running..
Unread 23-10-2005, 14:09
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: DARPA Sensors
I always thought it would be fun to make a robot that can autonomously traverse the W&OD bicycle trail.
  • Traffic is fairly slow and attentive (compared to me )
  • It has a variety of slopes (enought to be challenging)
  • Problems like crossing the street and avoiding cyclists/joggers would prove... interesting
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 24-10-2005, 00:16
buss buss is offline
AKA: Steven
FRC #0180 (S.P.A.M. Robotics)
buss has a spectacular aura aboutbuss has a spectacular aura about
Send a message via AIM to buss
Re: DARPA Sensors
A great site for assorted electronics bits is Marlin P. Jones & Associates. I buy a bunch of things I can't find at radioshack (Like N-connectors for wifi projects) from them.
Steven Buss
"Far and away the best prize that life offers is the chance to work hard at work worth doing."
-- Teddy Roosevelt
Unread 13-11-2005, 22:13
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: DARPA Sensors
I can think of a few things you can do, I will also b trying these as soon as I get my rc car built from the chainsaw motor sitting on my garage floor and the 24 feet of steel tubing in my basement.
--Use an IR or RF beacon in stead of GPS if you are on a tight budget.
--Parallax has a article on their website about serially interfacing a $100 GPS with a BASIC Stamp
--Accelerometers and gyros to autonomously navigate terrain, along with distance sensors.
Bumper sensors jeffmorris FIRST Tech Challenge 1 02-10-2005 16:20
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
Getting Fancy with Sensors FadyS. Programming 30 10-03-2004 15:02
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
what type of sensors are good and convenient magical hands Programming 7 04-01-2004 23:04
