Go to Post Surely any group of rational human beings (which FIRST seems to attract) can work this out. - Billfred [more]
Unread 09-11-2005, 21:20
vVigglEs vVigglEs is offline
Matt Pietkevich
AKA: Mad CADer
FRC #0177 (Bobcat Robotics)
vVigglEs is an unknown quantity at this point
Send a message via AIM to vVigglEs
CAM - Computer Aided Manufacturing
Currently my team 177, well me and a group of 2 people, are experimenting with cam(mastercam 9.1). One issues that we face is when we make mill cut hole cuts or square cuts we always get errors when we try to run it on are CNC.
If i remember right error had to with over lapping. when i make the cut i click main menu/operations/pocket/chain then select the hole... also i have tried main menu/operations/pocket/area
is there any CAM 9.1 pro's out there that would be able to give me some assistance?
and is there any free tutorials for mastercam X. we have a copy of it but have no tutorials to learn it.
Thanks.
Matthew Pietkevich
Team 177
Unread 09-11-2005, 22:00
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Re: CAM - Computer Aided Manufacturing
you may be using the wrong post processing (i think thats what its called) when you make the code to send to the CNC. i dont use the program much but that may be part of your problem
MechWarriors 573
Unread 09-11-2005, 22:06
Matt Pietkevich
AKA: Mad CADer
thanks but i kn i have the right post processing... my drawing files will still cut.(the outside of a part, drill holes, yadda yadda yadda) jest the larger holes where you have to mill out using a pocket. don't worry i have double checked my post.
Unread 09-11-2005, 22:35
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Is it giving you trouble when you are creating the tool path or not until you try to run it on the machine?
Are you able to successfully run through backplotting before you post the file?
I'm not familiar with mastercam 9, I've actually been working on mastercam X at school the last couple weeks. I ran into a little trouble today on backplots overlapping on a part, all I did was delete and recreate the toolpath and it worked, I don't know why.
As far as learning mastercam X - I had never used any mastercam until a few weeks ago. I'm quite familiar with autocad, so it was mostly just learning how to find and use the appropriate commands in mastercam.
The manual that comes with mastercam X has two tutorials with it that you can run through to get a little familiarity with it, I mostly learned how to use it by messing around on it until i figured out how ot accomplish what I was after.
I also worked with a tutorial book for mastercam 7, the actual commands don't seem much different - just exactly where to find them and how to use them is a little different.
Unread 10-11-2005, 08:41
Matt Pietkevich
AKA: Mad CADer
so i go to a black plot and it will draw the part. if i remember right there was some kind of overlapping error.
when i get a chance i will try to post the part on the forum.
but its hard for me to remember to the part seeing how I'm in class right now lol..
and are team only has one computer with the program, and I'm not allowed to go and work in the room if I'm alone.
are mastercam x only came with a tutorial for (9.1 Mill) and (lathe mastercam x)
i want the masterX Mill Tutorial
Unread 10-11-2005, 21:17
AKA: Bill Hancock
Sry i coulndt be of any help. I have never really used the program for anything. Whenever i try to use it i always end up more confused than when i started 3 hours ago. and to show how little the "program" knows i was trying to mill out the parts for something and im still not really to add all the tools in the tool list to the active project but anyways MasterCam decided it was going to MILL the whole shape out with a 1/2in center drill much to my dissapointment. I never got to try this "brillient" idea on a CNC but "If MasterCAM says it will work, it must work".
The preceding was a joke. I do not actully intend to attempt to possibly ruin a CNC and center drill.
MechWarriors 573
Unread 12-11-2005, 12:08
Jim Schaddelee's Avatar
Jim Schaddelee Jim Schaddelee is offline
Team 107 Holland Christian / Metal
None #0107 (Team Robotics)
Jim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud ofJim Schaddelee has much to be proud of
Matthew
I have been a mastercam used since ver 3 (Dos version)so if you have any questions regarding mastercam I can help.One thing you can try to do to help with your problem is don't pick chain ,pick single also try to delete multiple entities. sometime that can help.Also if your are still having problems ,please post the part and i can contact you and walk you through how to program it .
Jim schaddelee
team 107 mentor
Team 107 Holland Christian / Metal Flow
2005 Midwest semi finalist
2005 Johnson & Johnson sportsmanship (midwest)
2005 West michigan Champs with 93 and 66
2005 Johnson & Johnson sportsmanship (west michigan)
2005 web site award
Unread 15-11-2005, 16:59
Matt Pietkevich
AKA: Mad CADer
Originally Posted by Jim Schaddelee
Matthew
Jim schaddelee
team 107 mentor
thanks jim i will sure to do that
Unread 15-11-2005, 18:12
cmaccoy's Avatar
cmaccoy cmaccoy is offline
FRC #0173 (R.A.G.E.)
Team Role: Student
cmaccoy is on a distinguished road
Send a message via AIM to cmaccoy Send a message via Yahoo to cmaccoy
I too can offer some assistance. I'm the chair to the CNC Committee on my robotics team. I'm also working on a booklet but if you want you can use my old website which a few things no longer work but it is still informative with making practice parts. The site is for 9.1 but i'm writing a booklet for X. Good luck.
~cmaccoy
F.I.R.S.T. My anti-drug
Computer Horror Stories Pat McCarthy Chit-Chat 24 29-11-2005 13:46
Computer Stupidity sanddrag Chit-Chat 1 10-07-2005 17:50
Who's on FIRST: An ode to triple play Daniel Brim General Forum 8 13-04-2005 17:51
Bad and Good news for Computer Science AIBob Math and Science 8 31-01-2005 18:59
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
