Go to Post Never, Never tell a prospective mentor what the actual job description is. You need to get them hooked first. :D - BJT [more]
Unread 16-11-2005, 11:07
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Re: spherical positioning
Originally Posted by Cuog
a good gyro does 2 axis(left right forward backward) so u would only need 2 placed perpendiularly
Well, not quite. A gyro (or actually an Angular Rate Sensor) measures speed of rotation, not translational acceleration, so a 2 axis accelerometer would measure pitch and roll, yaw and pitch, or yaw and roll.
no matter what u use it will be effected by acceleration because down and gravity is an acceleration(9.8m/s/s)
it is infact this acceleration that makes the gyro work just remember that
Umm, no. The gyros measure just your rate of rotation, using a tiny tuning-fork like device and the Coreolis effect. They are not affected in any way by gravity, and would work just as well in a zero-g environment.
Back to the original poster, a 3-axis gyro array would give you only orientation, not position. However, as you said, there is some drift (although over short periods of time, it's not too bad). 190s 2k5 robot used a rate gyro so that we could have field-oriented controls, and the drift over the 2 minute match was minimal. However, using a 3-axis accelerometer array in tandem with the gyro array would give you the ability to recalibrate which way is down while you are standing still.
Zan Hecht
Programming multi positioning doyler Programming 11 26-02-2005 21:03
Absolute Positioning System Help Tom Bottiglieri Programming 5 05-02-2005 10:32
White Paper Discuss: Code and Walkthrough for Global Positioning System using IR Sensors CD47-Bot Extra Discussion 2 20-05-2004 21:22
banner sensor positioning and times bob1million Programming 4 16-02-2004 13:40
Wheel slippage w/ positioning systems Jay Lundy Electrical 3 12-12-2003 03:08
