Go to Post Such reasonableness will not be tolerated! This is teh interwebz! - pfreivald [more]
Unread 16-11-2005, 00:01
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
Pros and cons of electronics boards/boxes
I'm investigating the pros and cons of electronoics boards and boxes. I'm in charge of 1351's control systems and I'd like to have a good idea of how to organize the electronics before build season starts. I've read most of the threads and seen the pictures of other teams boxes. (especially this thread)
However, will somebody please follow up and say how these "awesome" boxes and boards actually worked in competition? What were their flaws? Benefits? What is the advantage of having a box/board as opposed to simply mounting all the electronics the bottom of the chassis in an organized pattern?
I realize these questions are vague, and I apologize. A list of pros and cons for a specific idea, (comparing it to other ideas too) would be good.
Thank you!
~Stephanie
Team 1351
Control Systems Leader
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 16-11-2005, 00:46
Billfred's Avatar
Billfred Billfred is offline
Re: Pros and cons of electronics boards/boxes
This year, 1293 had a board on Ockham for electronics. Imagine a big piece of aluminum bent 90 degrees. The RC and breaker panel were mounted vertically, with the Victors (no Spikes) on the bottom. Throw in some nifty water jetting to save weight, and you've got a right purdy electronics board.
The one problem I've experienced with it is that it's sometimes hard to get into there to work on the Victors, as we put it nice and deep inside the robot. (If you look at this picture, it's between the tower with the van door motor and our arm covers. The triangular hole is from a piece that both anchors our arm and shields the electronics.) If I could do it all again, I'd try to remove some more weight, and perhaps come up with some other mounting scheme, probably a bit more exposed with protection.
However, it does allow you to get everything out easily enough, once you disconnect the wires. We've never had to do it, though--clean living, I suppose. I'll try to get a picture of it this weekend.
Unread 16-11-2005, 01:19
REVving up for a new season
FRC #2848 (All-sparks)
in my opinion the electronics should be:
*protected
*easily serviceable/ removable
*visible
*placed centrally to minimize wire runs
other then that it really is the sky's the limit with creativity, although it seems that alot of the time the electronics are an after thought.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 16-11-2005, 09:49
the benefit of having your electronics enclosed is protection from arms and other metal parts of other robots intruding into your robot, and shorting out your control systems, or burning up your wiring. A short circuit during a match can destroy your electronics, and you only have so much time between matches to replace them, esp in the final rounds.
the downside is this makes it more difficult to access the components, and you need to make sure you have adequate airflow for your Victors (cooling).
Unread 16-11-2005, 14:07
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Others have already mentioned the advantages for an enclosure. You must also remember that the space available for you box may be limited by your robot design and function. So, that nifty box that you spent hours designing with quick disconnects and extra components gets scraped the night before shipping because it does not fit or weighs too much.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 16-11-2005, 14:10
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
This leads me to question what industrial machines do. I suspect that the "brains" are centralized. But, what about drivers and other low level control systems?
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 16-11-2005, 14:17
ttedrow's Avatar
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
The answer to this takes a lifetime to learn and is continuously changing.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
Yes, Chute Door!!!
Unread 16-11-2005, 15:12
one answer: pop the hood on your car. Check out the fuse box, the ignition control, the sensors, the wiring harnesses.
many electronics are potted in epoxy or silicon.
Unread 16-11-2005, 16:06
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Hey Stephanie,
I'll share our experiences with 188's "Trap Door." Every year, several things go wrong with the robot, and inevitably you have to do some troubleshooting, or some rewiring. We had to add a spike to our setup because we had to switch some single solenoids over to double solenoids in Pittsburgh.
We probably couldn't have done this without missing a match if it wasn't for the trap door accessibility.
There are always improvements that can be made however:
1) Both the top and bottom layers were made of wood. This was really light, made mounting components easy, but by the end of the season, our bottom board was smashed up pretty good. We'll probably use lexan for the bottom board this year.
2) Disconnects to every motor.
3) Better wiring diagram, right on the board.
Unread 16-11-2005, 17:51
I'd say it really depends on the system you feel will fit the best come build time.
Example: Our base is made of wood. It would be a waste of space and weight to make a seperate box for electronics when we can easily mount them right to the wood.
Unread 16-11-2005, 20:30
in between teams
AKA: Luke Van Oort
We had a wood board between the framerails to mount everything to. We just stuck the RC directly on it, and mounted the breaker panel at a 90 degree angle to it. Ours was safe from everything except our arm, which we stuck a microswitch on to protect the boards. I also saw a team at VCU that had their Victors on the underside of the robot, upsidedown. We though they'd have dust problems, but it seemed to work fine.
Team 1219: 2009 - Mentor
Unread 16-11-2005, 21:46
sciencenerd's Avatar
sciencenerd sciencenerd is offline
ooh, what does this button do?
AKA: Kyle
FRC #1318 (the IRS (Issaquah Robotics Society))
sciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud of
Team 1318 decided to go with a wooden board mounted a little below the main chassis, attached to the bottom of brackets. That way, when we needed to access it, all we had to do was disconnect everything plugged into it, take out four bolts, and (carefully) lower the board to the ground. Maybe not as ingenious as, say, team 116's box, but it was easy to access, and all the electronics were right there when you pulled it out. The only problem was our arm, if a driver pushed it too far the prong for lancing tetras could hit the RC. Luckily that never happened, but in retrospect, it would have been better if we would have put a clear plastic sheet over the board in that part to make it a little more robust.
Unread 17-11-2005, 08:08
Gdeaver Gdeaver is offline
FRC #1640
No matter what the design, I would put protection first followed by access and service. In any design consider how fast a vector, pwm cable or other part can be replaced. In back to back matches you may have not more than 5 minutes to accomplish these tasks.
Unread 17-11-2005, 14:54
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
A few years ago on our robot we haev the electronics all on one board in the middle of the robot( the game with the bins) and they were impossible to get to, until you found out that if you turned the robot on the side the whole board had a hinge on it so you could flip it out the bottom to service it. If you do something like that make sure you have enough wires so that you dont have to disconnect them when you fold it out.
Unread 17-11-2005, 17:49
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
One thing our Team(422) has done is a modular Circuit board that can be easily removed in about five minutes. This was for mechanical issues and at the VCU regional this year it allowed us to get to our motors and save a gear bfore it died.
For a box i would recomend looking at pictures of the insides of computers and looking at how they are set up:
-Bundled wires are your friends for organization
-logical placement and no wiretangling is a must
-COOLING chips create heat, motor controllers create heat, LET IT GO SOMEWHERE, FIRST gives you muffin fans use them! if you don't cool a box your victors may shut down on you because they got too hot during a match.
And if u have some extra wieght make a water cooling system and cooling blocks, I'm trying to get my team to do this but its still a no go
KK4KQO
http://voltair.us
Motor Placement Pros and Cons Pattie Motors 17 24-01-2005 15:40
Practicing after Ship - pros & cons Natchez General Forum 24 18-01-2005 23:06
Timing belts pros and cons!!!! archiver 2001 3 24-06-2002 00:33
Buckeye Regional PROS and cons emilywll Regional Competitions 14 18-03-2002 10:04
