Go to Post My only question is, Can your robot place tetras and deliver Krispy Kremes to team mentors in autonomous mode? - Rich Kressly [more]
Unread 06-11-2005, 22:36
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
spherical positioning
Let's say that I have a device that can suspend itself in the air. It's able to provide thrust in the x, y, and z axes, as well as the appropriate thrust to rotate about each axis. I want to be able to determine what direction is down.
I thought of using 3 accelerometers (one along each axis). You'd be able to calculate the direction of gravity by knowing the acceleration along each axis. The problem comes when you start to move. If you start to move in the +x direction, "gravity" will be biased toward the -x direction.
One thing I thought of was adding 3 gyros to the mix. If you determine gravity at start up, you can use the gyros thereafter. The problem with this is that there's no self-correction. After some time, there WILL be notable error in the measurements, so the system will have to be reoriented. So, how do you know that you're in a stationary state so that you can recalculate gravity?
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 15-11-2005, 20:19
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: spherical positioning
a good gyro does 2 axis(left right forward backward) so u would only need 2 placed perpendiularly
no matter what u use it will be effected by acceleration because down and gravity is an acceleration(9.8m/s/s)
it is infact this acceleration that makes the gyro work just remember that
Also what are you planning to build here that may help to decide what to do
KK4KQO
http://voltair.us
Unread 16-11-2005, 11:07
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Well, not quite. A gyro (or actually an Angular Rate Sensor) measures speed of rotation, not translational acceleration, so a 2 axis accelerometer would measure pitch and roll, yaw and pitch, or yaw and roll.
Umm, no. The gyros measure just your rate of rotation, using a tiny tuning-fork like device and the Coreolis effect. They are not affected in any way by gravity, and would work just as well in a zero-g environment.
Back to the original poster, a 3-axis gyro array would give you only orientation, not position. However, as you said, there is some drift (although over short periods of time, it's not too bad). 190s 2k5 robot used a rate gyro so that we could have field-oriented controls, and the drift over the 2 minute match was minimal. However, using a 3-axis accelerometer array in tandem with the gyro array would give you the ability to recalibrate which way is down while you are standing still.
Zan Hecht
Unread 16-11-2005, 11:44
I think we are getting lost in the terminology here.
Gyros: originally referred to mechanical devices that spin like a top, with very low friction bearings (gimbles). The gyros would be spun up with with the system on the ground, in a known orientation, and that was your reference point for the duration of the flight. From the angles on each gimble (or bearing axis) you could tell which way your vehicle was pointing, and by the change of those reading you could calculate rotational velocity and acceleration
For several years FIRST included yaw rate sensors in the kit of parts - referred to as 'solid state gyros'. This gets confusing because the yaw rate sensors measured the RATE at which you were turning on one given axis. To get the angle you have to integrate the reading over time, and to get the acceleration you had to measure the derivative (rate of change) of the sensor output.
Still with me?
There are also linear accelerometers available. These measure your acceleration in a linear direction. (thats why they are called accelerometers, they measure acceleration). To get velocity you have it integrate the reading over time, and to get position you have to integrate the velocity over time.
So an accelerometer will indicate gravity. But heres the problem with the original question. To find which way is up you must assume no other force is acting on the vehicle - no one is pushing you, there is no wind, and also, your vehicle is not spinning and causeing a centrifical force (that would feel like acceleration or artifical gravity).
Under a very limited set of conditions you could use a 'downward' pointing accelerometer to determine which way is up: very limited. If you are freefalling, or in orbit, or being moved by an outside force, or spinning, then you need much more information to know which way is up.
the amount of time it takes for your 'gimbal readings' to drift off was the measure of the quality of your navigation system. The error rate was measured in degrees per hour (drift). The better the system, the lower the drift rate.
For the Apollo missions the astronauts took periodic readings of stars, to measure the drift rates and zero out the accumulated error (drift).
Unread 16-11-2005, 13:53
Cuog's Avatar
AKA: Alex
FRC #0422
Ok i see what i thought was a gyro is an accelerometer then ok so kinda disregard what i said unless u wanna use an acceerometer
KK4KQO
http://voltair.us
Unread 16-11-2005, 14:05
Electrical Engineer
AKA: Phil Baltar
FRC #1351
I was just thinking up a helicopter-like device. I doubt that I'll actually make it, but I thought it was interesting.
My reasoning for the accelerometer array is that gravity is just a 3-d vector. If we had a device that could measure this vector, we'd know our orientation. But, again, this would only work if we were static. If we started to accelerate in any direction (by our own power), this second acceleration would be added to the gravity vector. This would make the measurement almost worthless.
If we had gyros (or some other sort of rotational sensors), we'd know our orientation referenced from our initial orientation. We assume that, at start up, we are on the ground, or otherwise not moving. We take a reading from the accelerometers and we can determine what direction is down. All readings from the gyros are referenced to this condition. When we start moving, we can use the gyros to determine our orientation and start using the accelerometers to determine our linear acceleration. However, we'd have to subtract gravity from the accelerometer readings. Because we know our orientation via the gryros, we know what direction gravity is. Subtract the gravity vector from the accelerometer readings and we have our linear acceleration. With our acceleration, we should be able to figure out where we are.
So, how do we compensate for drift because our initial reference point is gone?
A better way to phrase my question would be: If you were in a box and could have any instruments you wanted, how would you determine your position in space (as in your 3-d position)? I have a feeling that we'll run into some sort of Uncertainty Principle type of thing.
Version: 3.12
Unread 16-11-2005, 15:09
how would I do it?
simple: GPS! :^)
Unread 16-11-2005, 15:23
The easiest way I can think of to know that you're not moving would be to land.
Seriously, for this kind of application, I believe the best way to compensate for gyro drift is simply to eliminate it.
Unread 16-11-2005, 19:14
Kevin Watson's Avatar
La Cañada High School
FRC #2429
The best way to do this is with a Kalman filter, which takes in a bunch of noisy data from accels, gyros, GPS, etc., performs a bunch of black magic, including sensor fusion, and spits-out a state estimation.
-Kevin
Kevin Watson
http://kevin.org
Unread 16-11-2005, 20:37
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
So you're more or less trying to see if you can get the robot to tell if it is upside down or right side up, or anywhere in between-- Ok- here comes a mechanical brain idea, so it might make absolutely no sense at all- Take a weight (hunk of lead), and suspend it from a potentiometer or some other device that can measure angles. When the robot changes its attitude relative to the ground (gravity), the weight will still hang perpendicular to the ground. The potentiometer or other device can measure the angle that the weight is hanging relative to where the weight hung when the robot was parallel to the ground. You will always know what way is down-- the weight will always point that way. Make any sense at all??
Unread 16-11-2005, 20:40
ahecht's Avatar
'Luzer'
AKA: Zan
What you've basically built there is a two-axis accelerometer (albeit one capable of only telling direction, not magnitude). General Relativity states that there is no way of telling acceleration apart from gravity, so your "mechanical brain" would still be affected by any acceleration of the robot.
Zan Hecht
Unread 16-11-2005, 23:22
just want to point out, the idea presented in the first post of this thread is whats known as 'inertial navigation'.
its been around for many years, and hundreds of millions of dollars have been spent on research and development of these systems.
in other words, you are diving into some deep and challenging stuff here.
Programming multi positioning doyler Programming 11 26-02-2005 21:03
Absolute Positioning System Help Tom Bottiglieri Programming 5 05-02-2005 10:32
White Paper Discuss: Code and Walkthrough for Global Positioning System using IR Sensors CD47-Bot Extra Discussion 2 20-05-2004 21:22
banner sensor positioning and times bob1million Programming 4 16-02-2004 13:40
Wheel slippage w/ positioning systems Jay Lundy Electrical 3 12-12-2003 03:08
