Go to Post We're 3 pounds over. Drill until the hole saw is too hot to touch, then go find something else to cut off while you wait for it to cool down. - Richard Wallace [more]
Unread 17-11-2005, 18:41
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
Arrow 3 Encoders
Hello,
I was wondering if anyone has a modified version of Kevin's encoder code with support for 3 (or more) quadrature encoders. If you do I'd be quite thankful . My Email address is "slinkydeath@sbcglobal.net" if you're willing to share your code. Thank you very much,
Stephen
Unread 17-11-2005, 18:59
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: 3 Encoders
As far I am informed we only have two (available) hardware interrupts to use for the encoders, which would seem to indicate that we can only use 2 encoders.
However I also said nobody would hang last year
Matt Krass
Unread 17-11-2005, 19:06
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: 3 Encoders
Without knowing the details of the code or of the implementation, could you use an auxillary processor to take encoder information (from several sources), then pass it back to the RC processor as a package, using one (RC) interrupt?
Unread 17-11-2005, 19:11
Re: 3 Encoders
I think I heard of someone actually designing something to do this. Wow if one device could somehow keep track of those values and send it to the RC, that would be pretty sweet.
If I remember right, I thought that digitals 3-6 support interrupting, it's just they're banned together somehow.
Unread 17-11-2005, 19:16
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: 3 Encoders
Originally Posted by stephenthe1
Hello,
Stephen
Stephen,
Last year we used 2 encoders plus a gear-tooth counter. All three devices were driven by interrupts. I've attached the encoder.c file showing the initialization, and interrupt service routines. I've also included user_routines_fast.c which shows the handler InterruptHandlerLow ().
In short, interrupts are available in digital inputs 1-6. The caveat is inputs 3-6 can only be enabled or disabled as an entire block. You either get all or none. This also means that we chose to modify Kevin's code further, and move the phase B encoder signals to inputs 7 and 8. Leaving them on 5 and 6 would have caused unnecessary interrupts (this was done in encoder.h).
-SlimBoJones...
Unread 17-11-2005, 19:21
Re: 3 Encoders
Thank you very much! I'm going to get going and start working with this. thanks everyone for the help!
Testing and Cause of Failure for Encoders and Hall Effect sensors ChrisH Electrical 28 19-09-2005 01:07
encoders stephenthe1 Programming 61 09-02-2005 15:05
Mechanical Wheel Encoders? Jaine Perotti Electrical 15 04-12-2004 22:46
Who used wheel encoders CyberWolf_22 Technical Discussion 12 04-05-2003 15:37
