Go to Post "Simple" is about staying within boundaries. - dtengineering [more]
Unread 17-11-2005, 11:43
Issues Issues is offline
FRC #0525
Issues is on a distinguished road
tachometer mystery?
So I was driving to school one day, and was sitting at a red light when I thought to myself, what would happen to my RPM's if I turned my air conditioner on while I'm just sitting here. I hypothesized that they would go up because i figured the air conditioner would provide a greater load on the engine so it would need to spin faster to keep up. An amazing thing (to me) happened, they went down. I tested it out a few times, and sure enough if I turned the air conditioning on all the way the needle would pop down and if i turned it it off, it would pop back up. Why is it like this?
Unread 17-11-2005, 12:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: tachometer mystery?
What kind of car? I never really notice a difference with mine. Anyhow, an AC compressor places load on the engine, causing it to slow down. Just the same as if you there was friction in the drivetrain of your robot. It is a load, and would cause it to slow down. I am surprised you notice a difference though because for a big engine (like a car engine) and AC compressor shouldn't be too much of a load.
Unread 17-11-2005, 12:12
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Your ECM/PCM will probably open the throttle a little to compensate for the load if the RPM drops past a certain point, but if it's within the idle speed limits it will probably just rev a little lower.
In some smaller cars with 4-cylinders and low horsepower, you can notice the difference in acceleration when the A/C is on or off
Unread 17-11-2005, 12:22
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Originally Posted by Greg McCoy
In some smaller older cars with 4-cylinders and low horsepower, you can notice the difference in acceleration when the A/C is on or off
It doesn't matter the age of the car or the size of the engine, the AC will slow your acceleration. Some cars just have enough excess power that it isn't very noticeable. (The AC load robs the car of a smaller percentage of power to the wheels)
Wetzel
Viva Olancho!
Unread 17-11-2005, 15:38
occra 23.
AKA: ryo
None #1481
if you have an automatic, you can even see it drop more when you have the brakes on with the tranny in drive rather than neutral,
Unread 17-11-2005, 16:15
FRC #0525
that was my case, I have a 99 dodge intrepid (automatic) and I was sitting still w/ brakes on and in drive.
Unread 17-11-2005, 17:38
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Now what causes this:
On a car(gasoline engine anyway, i dont know much about deisels) the RPMs are adjusted by two different means depending upon whether u have Fuel Injection or Carbeuration:
FI- You adjust via the Go pedal how much air is allowed into the engine through a butterfly valve, the computer then determines how much fuel needs to be injected into the cylinders based on the pressure and amount of O2 in the air.
Carb- You adjust it via the go pedal but this time the butterfly valve and air are used to create a ventury(i think that is spelled right and this method is at least for all aoutomobile carbs that i have seen) which sucks the gasoline allong with the air into the cylinders.
When you add load to the engine it does not say to anything(at least not in most cars some fancy ones do this)"hey im underload gimme more powa'!!" instead the explosion in the chanber does not have enough force to continue at the same speed and the RPMs drop. More gas and Air = more Force explosion = faster RPMs.
Car Man ,
Cuog
KK4KQO
http://voltair.us
Unread 17-11-2005, 19:09
I dont agree entirely
I think every car on the US market has been fuel injected for some time now. The engine controller (computer) holds the engine at the idle RPM when you have your foot off the gas. It compensates for air temp, engine temp, air pressure, the load on the alternator, and keeps the engine at its proper idle speed.
the on/off button on the air conditioner is just another input to the engine controller.
also, on most cars, when you accelerate with the pedal all the way to the floor, the engine controller turns the A/C off, because you obviously want full power to the drive train (or you wouldnt be mashing the gas pedal).
My Saturn Vue has a electic gas pedal. There is no cable to the intake butterfly, its controlled by the engine computer. (and my Vue is by no means an expensive vehicle: $14,500 new).
Unread 17-11-2005, 19:28
in between teams
AKA: Luke Van Oort
Also, since I'm assuming the wheather was warm, your power production is probably down anyway, due to knock thresholds and density.
Team 1219: 2009 - Mentor
Unread 17-11-2005, 21:29
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
The air conditioner provides an additional load which slows down the engine. Many engines have an idle solenoid that will engage when the A/C is on. This solenoid will attempt increase the speed of the engine. Depending on how it is adjusted, it may or may not cause the engine to speed up.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 17-11-2005, 22:08
Ken's explanation is correct. Both the Honda's and the Dodge van I own have throttle positioners that are controlled by the computer. All of the various sensors on the engine are looking at idle speed, all of the environmentals (i.e. outside temp, engine temp, etc.) transmission selector, etc. When at idle, in gear or out of gear, lean or rich, cold or hot, the computer adjusts the idle setting based on the RPM sensor and whatever the software guys programmed in. The service manuals for the above cars specify that engine RPM when warm should not change more that 50 RPM as the lights are turned on, the A/C cycles, the brakes are applied (brake lights on) or the fan is set to high. There is some delay from one manufacturer to the next but they should all recover within a few seconds. If not, there is a good chance that the throttle positioner is loose or worn, the throttle plate is dirty, the mass air sensor is dirty or not up to temp, the injectors are dirty, the fuel pressure is not within spec, or you have a manifold leak. (Assuming you have kept to the maintenance schedule and have good plugs and clean filters) Most of these problems are minor and they result in a small loss in economy. There are a number of shops that are able to clean intake parts and I know of one shop that has equipment for cleaning the intake, injectors and fuel rail for a very reasonable price.If your RPM drops 200 or more (quite common with post '96 Dodge big V6 engines with dirty throttle parts) you might have a problem with engine stall in the future.
Unread 18-11-2005, 02:20
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
I noticed that mine likes to bounce. When there is a load, the tach drops. When the control system tries to recover, it overshoots. Then it realizes it went too high and comes back down. The A/C does this when it turns on. If I turn the bass on the radio up, it'll follow the music.
On a side note, I did notice that there's a certain temperature that my engine doesn't like. The problem is that it's a little above ambient for this time of year. When the engine's at this temperature (at start up), it revs really low. Every so often, it's so low that it feels like it's getting ready to stall. It's fine when I give it some gas, but it doesn't like to idle properly. Once the engine warms up, it's fine though.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 18-11-2005, 07:32
Phil,
The first one is easy, the music is too loud. It might be an engine response or it might just be accoustic coupling.
The second one is a prime suspect for a temp sensor gone bad. It probably works above a certain temp and is way off below that temp.
Unread 18-11-2005, 10:44
Electrical Engineer
AKA: Phil Baltar
FRC #1351
I was thinking that the music thing might be from extra power consumption. The electrical system is connected to the alternator which is connected to the engine.
As for the temp sensor, it just doesn't work at that temperature. When the engine is really cold or already warm, it's fine.
Version: 3.12
Unread 18-11-2005, 12:54
It's possible that you are drawing too much current through the dash power wiring. As the current goes up the voltage drop on the wire goes up. (just like the wiring to speed controllers and motors.)
I had the same problem with a normally aspirated engine years ago. The carb just didn't like wet weather between 32 and 45 when it was cold. Seemed that ice would form across the venturis as the air was accelerated.
pic: 930 Mystery Teaser Gamer930 Robot Showcase 3 14-02-2005 12:03
Tachometer ZACH P. Motors 11 08-11-2004 04:02
building a hand held tachometer Ben.V.293 Electrical 3 07-11-2004 18:48
mystery theater help hollieteam388 Chit-Chat 0 21-01-2004 17:45
R. Buckminster Fuller: THE HISTORY (and Mystery) OF THE UNIVERSE Ken Leung Math and Science 1 09-06-2003 01:41
