Go to Post Problem with microprocessors: they do exactly what you tell them to do - KenWittlief [more]
Unread 17-11-2005, 16:25
loomisman loomisman is offline
FRC #0141 (WOBOT)
loomisman is an unknown quantity at this point
Lift on cart
Teams using pneumatic lifts, how is your lift system designed? Our team is adding a lift to our cart and I could use some ideas.
Unread 17-11-2005, 18:54
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
Re: Lift on cart
IM me and i will give you some good tips. I work for a medical company (Stryker) as an design engineer for the test lab. We make hospital beds and stretchers and EMS cots. They are hydraulic, but I use pnumatic components every day. Hit me up.
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 17-11-2005, 19:11
Timmyd's Avatar
Timmyd Timmyd is offline
HAHA...i like pi
AKA: Tim
FRC #0022 (Double Deuce)
Timmyd is just really niceTimmyd is just really niceTimmyd is just really niceTimmyd is just really nice
Send a message via AIM to Timmyd
Re: Lift on cart
i was actually designing one that had a scissor lift and you could raise and lower it with ether a drill motor or this old sowing machine motor i have haven't finished the design yet but once i do ill get you the inventor files
[center]Our robot's name is HOMER, it stands for Human Operated Mechanicaly Engineered Robot
Our team name is Double Duece 22
If all else fails... blame the PROGRAMER
Unread 17-11-2005, 22:16
Re: Lift on cart
I need to advise you that pnuematics are a bad idea for robot carts. They carry a fast response and little control for such a large and heavy object in such a small and confined space as a pit at competition. I know of teams that were asked to disable a pnuematic cart during a competition due to the danger to team members and other pits.
Unread 17-11-2005, 22:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Lift on cart
If you put in some good flow rate control, I think it could make quite a fine system.
Unread 21-11-2005, 14:42
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: Lift on cart
Team #388 uses a lift cart from HarborFreight that has been modified with a new suspensiopn and wheels, this provides us with 660lb lift capacity up to around 40" or so.. waay more than we need. The advantage of this is the hydrolics are all preengineered and reliable, we can carry pretty much anything we want on our cart includeing our crate 2 years ago, and its very controllable with an handwheel that opens the lowering valve and it will up to a maximum speed which is very safe. I dont have any pics of our cart at the moment but will post some if I can rember also check out the cart pics on this site, many good ideas. Also I think the HOT team (cant rember the number) uses an linear screw actuator system with a sissor lift however I think the weight limit is very low
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 21-11-2005, 14:59
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Lift on cart
A scissor-lift cart may seem like a good idea but there is always one disadvantage - weight. Even if the lift works fine, a heavy cart is usually a bad idea. Last year, our team tried to make a scissor-lift cart, but it ended up weighing around 80 pounds, so we scrapped it for a simple one. Remember, if your cart weighs 80 pounds + 130 pound robot + extra batteries = Way too heavy! If your team is going to the Championships, and you have to push a 200+ pound cart back and forth the quarter mile or so from the pits to the Georgia Dome for each match, you will really want a lighter cart after its over. Going with a minimalist approach to cart building is best.
Art Dutra IV
世上无难事,只怕有心人.
Unread 21-11-2005, 15:35
Foss@Team176 Foss@Team176 is offline
AKA: Zac
FRC #0176
Team Role: Student
Foss@Team176 is a jewel in the roughFoss@Team176 is a jewel in the roughFoss@Team176 is a jewel in the rough
Send a message via AIM to Foss@Team176
Re: Lift on cart
in my opinion your options are either,(1)build a heavy cart with a sissor lift, (2)get a cheap dolly, or (3)attempt to make something new that no one has come up with yet. currenty myself and some other team members are working on option three, and have explored many options. Instead of a lift maybe consider making a table/cart... we might show our designs latter, if not you could always check it out when its done at our regionals. Currently i know we are going to the UTC.
Unread 21-11-2005, 16:03
Jason Kixmiller's Avatar
Jason Kixmiller Jason Kixmiller is offline
IWIWAB
FRC #1747 (Harrison Boiler Robotics)
Jason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to behold
Send a message via AIM to Jason Kixmiller
Re: Lift on cart
If you have a pre-existing cart that works well, several hardware stores carry folding table legs (much like on folding tables, etc.) that are easily attached and require little to no technological know-how.
Unread 21-11-2005, 16:13
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Re: Lift on cart
I agree with the KISS method - Keep it Simple.
Instead of raising the robot, can you lower your chairs to sit while working on it? Maybe make some wooden rectangles with casters as chairs?
We have had one excess in the past - the robot stand on the cart is a lazy-susan from the hardware store. Let's you rotate the robot while working on it or loading/unloading.
Brian Graham
Robot Cart Questions from a rookie team Alex Minot Technical Discussion 36 06-03-2006 09:20
Shopping cart wrangler bot? Taylor_Ratliff Chit-Chat 4 10-10-2005 15:31
SnugTop Lid Power Lift Kit?????? Mejinez Pneumatics 1 07-10-2005 01:48
Robot Pit Lift Burg Pneumatics 19 14-03-2005 19:38
Extension lift mechanics Steve Compton Technical Discussion 8 25-01-2005 15:47
