Go to Post Baker, you're making my head hurt and it's only August!!!! - Rich Kressly [more]
Unread 19-11-2005, 12:30
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: Holonomic Drive Question
This thread is a couple of months dormant but I just began looking at this type of drive recently. Now I am very much intrigued by the cambered, four-corner design posted by Dave. I had been considering a four wheel design with two axles perpendicular. A "plus sign" design. I am worried that this makes the corners of the robot unstable. Adding caster wheels helps but then I conjured up an idea of taking the traditional tank steer set up for a 4 wheel system and just add the second dimension and have a total of 8 wheels on 4 motors and transmissions. I've attached a jpg created from a word drawing so it is rather crude. One motor / transmission would be used per side. It would be prudent to consider using #25 roller chain and sprockets to save weight. The new AndyMark plastic Omniwheels would also be a prudent choice once they become available for weight concerns likewise.
Any and all thoughts welcome.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Four wheel drive question haverfordfords General Forum 25 25-01-2005 23:24
Computer with multiple hard drives question. Elgin Clock Technical Discussion 2 03-12-2004 11:41
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
What is wrong with this code???? It won't Compile and I don't know why? Please Help CrashZero Programming 23 26-03-2004 09:44
