Go to Post So yeah, everyone please remember that lathes are one of the most dangerous machine tools you'll encounter. And keep your hand on the chuck key whenever it's in the chuck. If you never let it go till it's out of the chuck, it's stupendously less likely to take flight. - Kevin Sevcik [more]
Unread 03-11-2005, 13:10
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
Re: Oscillating a pnuematics valve?
I like this - I have attempted to get a cylinder to run from two single solinoid valves as a multi-positioner, and it is hard to do, until you figure out how to do it. I no longer have the setup, though, but I believe that the exhaust of the first valve had to be routed through the input of the second, and the second had to have one output blocked and be set to it as default. Then, the system backpressures itself (probably above 60 psi, so this probably is not competition legal) until the arm stops whereever it is. The way you described it would seem to be a much easier (wiring and tubing wise) way to get this done, and it has a much higher likelihood of being competition legal.
Originally Posted by KenWittlief
The idea of having an arm that is moved by pneumatics, and locked in place anywhere within its range of motion - thats very clever! I dont think I have ever seen it done on a FIRST robot
you dont need to get fancy with the valves, simply use the flow restrictors to limit the speed at which the arm will move
and to get precise control, use feedback. Instead of having the operator release the clutch and move the arm up or down, and then engage the clutch at the right position, have something like a potentiometer on the arm reporting position. the operator would move the joystick up or down, and the system will sense the arm is not where the joystick says it should be, unlocks the clutch, pressurizes the cylinder in the right direction, and engages the clutch when the feedback sensor = the joystick setting.
I really like this idea. You could have a very light, very simple, multiple axis or multiple elbow articulated arm, with very precise control of its motion - using nothing but pnuematics!
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
Unread 07-11-2005, 22:24
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
last year we used multi positioning on 2 pneumatic cylinders and needed a total of 2 double solenoids and 2 single solenoids
http://www.chiefdelphi.com/forums/sh...ad.php?t=33258
has a good description as to what needs to be done for it to work
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 07-11-2005, 23:22
the problem with using two valves to create a multiposition system is that the arm is balanced by the pressure in the cylinders. If you pulled or pushed on the arm at any given position, the arm would move (for example, if you dropped a tetra, the arm would rise up on its own).
using a locking mechanism, or clutch, would make the arm stiff in all positions.
Unread 14-11-2005, 15:00
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
yeah thats what the potentiometer is for you make pregramming increase or decrease the pressure until the arm is within like 1 or 2 degrees of where the joystick is its very logical and a really great idea
What would happen is the arm would move due to the pressure change of shifting wieght but would automatically readjust itself to wherever it is supposed to be.
KK4KQO
http://voltair.us
Unread 20-11-2005, 09:47
DonRotolo's Avatar
Back to humble
FRC #0832
Team 1676 tried that last year, but we had mixed results. The feedback loop (including the valves, movement of the air, etc.) wasn't fast enough to hold a position pneumatically when faced with variable loading. The problem is that air compresses, and so changes in load made the arm move: We hung a tetra on the arm and it drooped down. Also, the operator cannot expect instant response - we had something like a 1/2 second delay, and that was hard on the operator. We used a double-solenoid valve (3-way), no fooling with modulating exhausts and whatnot.
In short: Pneumatics are excellent for endpoint positioning, but awful for precision or intermediate positioning. Not that it can't be done - we did it - just that motors are a FAR better choice.
My advice would be to abandon ideas of variable mid-point positioning using pneumatics.
On the other hand, pneumatics were excellent for our gripping claw - open/closed.
Don
Unread 20-11-2005, 10:16
I think you missed part of the description.
you include a clutch or locking mechanism on the joint, so once the arm is in the proper location, the clutch locks, holding the arm rigid. Unless you add enough weight to the end of the arm to overpower the clutch, its not going to move
and with this approach you dont try to control the pressure in the cylinder, or to apply pressure to both ends - you use the cylinder in the normal configuration, with the little flow restrictors to slow down their movement.
The clutch is in the feedback loop, not the valves. Once the arm has moved to the right position (up or down) the clutch locks and holds it against the pnuematic pressure, and against any added weight to the end of the arm.
Unread 20-11-2005, 13:18
Umm Errr...
I have tried this and it works! There are nifty off the shelf cylinders with pneumatic cluthes built in for exactly this application but they are of course not FIRST legal.
It might still be nifty to use a closed center valve in addition to a locking mechanism. By pulsing it on and off at different duty cycles, you could move at different speeds. Another strategy is to use more than one valve to control a cylinder. Each valve has it's flow restricted to a different extent.
1139 Alumni
Single vs double solenoid valve operation Scott358 Pneumatics 0 29-01-2005 11:47
Need the number for the Norgren Pressure relief valve Jack21 Pneumatics 0 23-01-2004 16:32
Dump valve and pressure gage's tareyton Pneumatics 3 06-02-2003 21:13
Dismantle Solenoid valve? archiver 2001 2 23-06-2002 23:34
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
