I've been programmed to love you.
Unread 22-11-2005, 21:15
cvhsrobotics's Avatar
cvhsrobotics cvhsrobotics is offline
AKA: Ara K.
None #0589 (Falcon)
Team Role: Student
cvhsrobotics is an unknown quantity at this point
Send a message via AIM to cvhsrobotics
USB I/O for macs?
Does anyone know of any I/O boards that are USB and work on mac? Something like a control board where you can hook it up program it and have it do things just like the Innovation FIRST ones?
TEAM 589~!
Crescenta Valley High School Robotics!
Unread 22-11-2005, 21:29
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: USB I/O for macs?
I guess the easy answer is a Handy Board, though I guess I am cheating a little in the sense that you require a USB IR transmitter.
Another easy answer is the LEGO Mindstorms RCX, but the same "cheat" applies with the IR tower (comes with the kit!).
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Ferazel2001 Ferazel2001 is offline
Mac Junkie
AKA: Devon
None #0599 (Robodox)
Ferazel2001 is on a distinguished road
Send a message via AIM to Ferazel2001 Send a message via MSN to Ferazel2001 Send a message via Yahoo to Ferazel2001
Rock on! Other Mac users!
Edit: Oops, Misread your post... You can use these steps to program the big robots, or if you want to you can go purchase any 9Pin board and use this in the same way.
I presume you are using VPC or something to that effect? If so, you can go down to frys and buy any USB -> 9Pin adapter that says MacOSx on the box (which is most of them). Install the software, plug in the adapter and configure the port in VPC.
VPC Configuration is as follows:
Under "Settings..." select USB.
If USB is disabled, Enable USB.
Select the USB Adapter in the list and click the Check box.
Then insert the CD again and install the software on your Virtual OS.
These steps enable both MacOSx and Windows to see the device (which is important).
Hope this helps,
-Devon
http://www.robodox.org/
Unread 22-11-2005, 21:41
AKA: Ara K.
None #0589 (Falcon)
Team Role: Student
Bah! Virtual PC sucks! I tryed it... it laged like hell. I don't like PC stuff, I need something that does mac. It's like either a "naked board" nothing like Lego mindstorm, or vex.
TEAM 589~!
Unread 22-11-2005, 23:28
Bruce Newendorp Bruce Newendorp is offline
Engineer
FRC #0525 (Swartdogs)
Bruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to behold
There are several USB data acquisition devices avaialble for Mac OS.
National Instrumements makes a full line of products. http://zone.ni.com/devzone/conceptd....701F007A8B40#1
If you only need digital inputs, check out the X-Keys USB Matrix board: http://www.xkeys.com/
Another to look into is the Phidgets products. I see they now have MacOS support in beta. http://www.phidgets.com/
Unread 22-11-2005, 23:52
AKA: Ara K.
None #0589 (Falcon)
Team Role: Student
HEY! Perfect! I like that http://zone.ni.com/devzone/conceptd...5701F007A8B40#1 If there are any more please say so anyone.
TEAM 589~!
USB I/O CJO Control System 2 15-10-2005 20:17
Addressing I/O in Sections astro1652 Programming 7 18-09-2005 19:28
Connect Playstation Controller to PC USB. kirov Control System 1 28-02-2005 08:24
USB Joystick to DB15 team1307 Control System 7 21-01-2005 11:58
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
