Go to Post You mean i can do something with the Kinect other than put large dents in wall with a robot? Rad.. - rachelholladay [more]
Unread 22-11-2005, 22:17
DonRotolo's Avatar
Back to humble
FRC #0832
Re: manual control of a victor?
Originally Posted by Rickertsen2
The control signal is very simple. All you need to do is supply it with the necessary voltage on the power lines and a 1-2 ms pulse periodically on the signal line. 1ms corresponds to full rev while 1.5ms is neutral and 2 is full forward.
That is correct for an R/C servo, but incorrect for a Victor or similar PWM motor control.
For a PWM motor control, the duty cycle of the signal varies from 0% to 100%, corresponding to full reverse and full forward, respectively, with 50% being neutral.
[EDIT:] I stand corrected, the Victor uses standard R/C type PWM control, which operates as described in the quote above. The circuit I have won't work here, but there was a circuit in SERVO (or maybe Nuts & Volts?) earlier this year that had such a circuit using a 556. When I find that I will post a reference to it. [/EDIT:]
I have a circuit somewhere that does exactly what he wants, uses a single 555 and a few passive components, and varies from about 3% ro 97% duty cycle. I'll post it when I find it.
Don
Unread 22-11-2005, 22:32
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
You're thinking of the output of said motor controller. The original poster was looking for a device to connect to the Victor input. This uses the same signal as R/C servos.
However, I recently finished a PIC based motor controller (for true motor control PWM). If anyone wants it, I'll send them the code. As for hardware, you just need a 12F683 (or similar) and the appropriate "glue" components to connect it to an h-bridge. I've got code to read a pot and the R/C PWM signal.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Victor Input / Motor Control Jack Electrical 5 01-12-2004 02:23
Manual override of compressor software control willross Pneumatics 15 18-02-2004 23:51
Autonomous to Manual control? Lint_Ninja Programming 5 16-02-2004 21:48
Non-variable Victor Control Madison Technical Discussion 16 31-01-2002 15:35
