Go to Post By the looks, 1114 has already figured out both #1 and #2. They're still behind 71, who is just about done with their robot for the 2012 season, is getting driver practice for 2011, and is working on their robot designs for the 2013 water game. You're still way behind. - EricH [more]
Unread 23-11-2005, 21:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Aluminum Brazing Rods
Has anyone used Aluminum Brazing rods before? I picked up some cheap Bernz-O-Matic ones at my LHS just to play with. Since it has working temp of 700 degrees F, I was able to melt it with my propane torch. I tried putting together a small piece of 1/8" thick L channel onto some .090 plate and it seemed to work reasonably well. I was able to pull it apart with a couple pairs of pliers and not a whole lot of effort, but it did hold relatively well. I mean, when it was brazed all around, both the plate and the angle bent before I could get it apart.
Anyway, what has been the extent of your success with these. They seem to make the metal "stick" together more than they do "bond" together because you aren't melting the base metal at all.
What I'm getting at is, can an aluminum FRC robot frame be brazed together and hold reliably? Would you need to use a higher temperature rod and torch?
I don't have any experience with brazing, so if anyone else has, please share.
Unread 23-11-2005, 22:20
Rod's Avatar
Rod Rod is offline
Rod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to behold
Send a message via AIM to Rod
Re: Aluminum Brazing Rods
Yes you can braze Alum together. I have always used silver solder and brazing flux. The higher percent of silver in the rod the better. The more contact surface you have the stronger it will be as the silver solder will "Flow" where a weld will not. It is an easy way to join Alum., but is no replacement for a TIG torch. But if you have enough contact surface it will hold very well, sometimes better than a weld.
-Rod-
Team 662
Colorado Springs, CO
Unread 25-11-2005, 12:40
piotr_boch piotr_boch is offline
no team (Delphi Poland S.A Thermal& Interior)
piotr_boch is an unknown quantity at this point
What you want material join ( number alloys aluminium)?
If you want good join you must to heat aluminium to temperature about 577-580degrees C=1070-1086deg.F .
When I join pipe to pipe I use special wire AA4047 or AA4045 or nocolok flux( wet mixture to assist flame brazing).
If you have question please write.
A funny story involving 80/20 Aluminum! Rombus Chit-Chat 1 12-04-2005 00:44
Using Extruded Aluminum to telescope. LGuY Technical Discussion 21 07-02-2005 12:43
Free Samples of Welding stuff, brazing rods etc activemx General Forum 0 29-01-2005 02:17
Difference in aluminum archiver 2001 1 23-06-2002 23:49
Let's get some aluminum extrusions archiver 1999 3 23-06-2002 23:12
