Go to Post I find this ironic. In English class our teacher's tell us how there is symbolism and such, and we don't understand it or think its there. Then FIRSTer's get a Game Hit, and we think EVERYTHING is a symbol and has some significance. - akoscielski3 [more]
Unread 26-11-2005, 12:46
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
Re: White Paper Discuss: Eclipse for Robotics
I followed your instructuons but when I went to start a new project, the Microchip option was not on the dropdown for Project Type.
Unread 26-11-2005, 18:02
Umm Errr...
Props. now if only i could get eclipse to open without crashing my system. I'm using Fedora 4 x86_64. Any ideas?
1139 Alumni
Unread 27-11-2005, 16:32
prograid's Avatar
prograid prograid is offline
AKA: Ben Cherian
prograid will become famous soon enough
Please read this!
The plugin posted with the whitepaper will not work. It' the wrong version.
Use the attached jar file instead. (Just change the zip extension to jar.)
Sorry.
Does anyone know if there is a way for me to edit the whitepaper?
Thanks
File Type: zip org.eclipse.cdt.mcc18.toolchain_1.2.0.zip (2.9 KB, 180 views)
Unread 30-11-2005, 17:56
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Question Re: White Paper Discuss: Eclipse for Robotics
Even after I downloaded the updated file, it still doesn't work for me.
I look at the "Plug-in Details" dialog from the About dialog, and the Plug-in IDs go straight from "org.eclipse.cdt.managedbuilder.ui" to "org.eclipse.cdt.refactoring".
Extracting it into a folder doesn't help. (The dir has since been removed.)
Eclipse:
Version: 3.1.0
Build id: I20050627-1435
The only error in the error log I can find is this:
!ENTRY org.eclipse.update.configurator 2005-11-30 17:45:06.320
!MESSAGE Could not install bundle plugins/org.eclipse.cdt.mcc18.toolchain_1.2.0/   Bundle "org.eclipse.cdt.mcc18.toolchain" version "1.2.0" has already been installed from: update@plugins/org.eclipse.cdt.mcc18.toolchain_1.2.0.jar
In the configuration details, I see:
org.eclipse.cdt.mcc18.toolchain (1.2.0) "Microchip C18 Compiler Tool Suite Managed Make Extension" [Installed]
  file:/d:/Program Files/Eclipse/plugins/org.eclipse.cdt.mcc18.toolchain_1.2.0.jar
What the heck is going on?
Unread 01-12-2005, 19:11
prograid's Avatar
AKA: Ben Cherian
Eclipse:
Version: 3.1.0
Very odd.
I've never actually read the error messages. (It always worked for me, so I'm not sure what they mean.)
Try starting eclipse with the option -clean.
Are you sure that you're CDT installation worked?
Becauser there should be plugins like org.eclipse.cdt.core, etc.
In other words can you create a GNU C/C++ Project?
If not, then delete all the files in the plugin directory that have org.eclipse.cdt.*
and anything related to CDT in the features directory.
Then download CDT from CDT's download site. An unzip the file and copy the appropriate files to your plugin and features directory. Then start eclipse with the clean option again.
If this doesn't work I'll try posting this problem in CDT's newsgroup.
Unread 01-12-2005, 19:16
AKA: Jamie Bliss
Talking Re: White Paper Discuss: Eclipse for Robotics
Originally Posted by prograid
Very odd.
That did it. Thank you.
Unread 01-12-2005, 19:22
AKA: Jamie Bliss
Bug: Include paths wrong
Ok, new bug.
You don't use the enviroment variable MCC_INCLUDE. You appear to hard-code C:/mcc18/h. (A false assumption; I have mine installed to D:\mcc18\h)
I also can't find an option to change it.
Unread 01-12-2005, 22:55
prograid's Avatar
AKA: Ben Cherian
Re: Bug: Include paths wrong
Ok, new bug.
Thank you for telling me that, I didn't know about MCC_INCLUDE, but you still can change it. Go to project properties C/C++ Build Settings. Look at Compilation Information, under the C18 Compiler heading of the Tool Settings tab, Change the Include path from C:\mcc18\h to D:\mcc18\h.
Unread 03-12-2005, 17:00
AKA: Jamie Bliss
I've now discovered something else.
If you use the MinGW make, it will mung the command, so that it calls:
mplink ..\18F8520user.lkr w:/ m:/ FRCMapfile.map D:/msys/1.0/odefault_2005.hex ./ifi_startup.o ./ifi_utilities.o ./main.o ./printf_lib.o ./user_SerialDrv.o ./user_routines.o ./user_routines_fast.o /lD:/mcc18/lib ..\FRC_Library.lib
Cygwin's make does not exhibit this behavior.
Unread 06-12-2005, 21:50
prograid's Avatar
AKA: Ben Cherian
Sorry, about taking so long to reply.
It could be because you have both make programs installed.
I'm using MinGW's make and I have the following output (using Eclipse 3.1.1 and CDT 3.0.1)
mplink "..\18F8520user.lkr" /a INHX32 /w /m FRCMapfile.map /oRoboticsCode.hex  ./254_arm.o ./254_drive.o ./254_encoder.o ./254_gyro.o ./254_interrupts.o ./254_timers.o ./254_utilities.o ./eeprom.o ./ifi_startup.o ./ifi_utilities.o ./main.o ./user_SerialDrv.o ./user_camera.o ./user_routines.o ./user_routines_fast.o   /l"C:\mcc18\lib" "..\FRC_Library.lib"
Unread 06-12-2005, 22:06
AKA: Jamie Bliss
I actually had to grab that by some script hooks (so it would show me the command).
The output is something like "invalid input: m:\". It still prints the command it's supposed to send. It's munging on make's part. (I looked at the generated file. The command was correct.)
Unread 31-12-2005, 14:34
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Steve, Have you had any luck fixing this? I've tried the same thing with an Ubuntu linux distro and I have the same problem.
Thanks
Eric
Don't PANIC!
S. P. A. M.
Unread 31-12-2005, 14:56
AKA: Jamie Bliss
Thanks
Eric
run eclipse with the -clean option, then try it.
Unread 02-01-2006, 17:00
FRC #0180 (SPAM)
no luck...
I am able to create a GNU c/c++ project, and GNU, GNU on windows and GNU on MAC OS X are available, but no microchip reference
btw, when I go to put the .jar file in a plugins directory, I find
/usr/share/eclipse/plugins
/usr/local/share/eclipse/plugins
/usr/lib/eclipse/plugins
/usr/local/lib/eclipse/plugins
so which one? I copied the .jar to /usr/share/eclipse/plugins and soft-linked it elsewhere
any ideas?
Thanks
Eric
Don't PANIC!
S. P. A. M.
Unread 05-01-2006, 22:14
FRC #0180 (SPAM)
no luck...
any ideas?
Eric
OK...re-read Using Eclipse thread and figured it out...
Don't PANIC!
S. P. A. M.
White Paper Discuss: NEMO White Paper: 25 Ways Sponsors Can Help Your Team Jessica Boucher Extra Discussion 1 20-11-2005 20:01
White Paper Discuss: 2005 IRI - Everything You Need to Know (or at least most of it) Chris Fultz Off-Season Events 3 17-05-2005 20:14
White Paper Discuss: Sponsor Care Presentation Chris Fultz Extra Discussion 0 25-04-2005 12:51
White Paper Discuss: Joystick Sensitivity Demystified - Version 2 marccenter Extra Discussion 0 28-02-2005 16:54
White Paper Discuss: Comparison Paper for Teacher Involvement CD47-Bot Extra Discussion 1 13-11-2004 00:09
