Go to Post Some people use Autodesk, some SolidWorks, some Pro-E, but 772 rose to the call of an unconventional CAD language, Minecraft. - Walter Deitzler [more]
Unread 27-11-2005, 18:02
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
Alternative to limit switches?
Hello,
Our team has been using limit switches for our past two years to see if our arm is fully extended, so if it is, then the software doesn't let the arm extend more. However, we've had some problems with the limit switches breaking, so is there an alternative to limit switches? Have any other teams tried something else? What about reed switches?
Thanks
~Stephanie
Control Systems Leader
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 27-11-2005, 18:11
Re: Alternative to limit switches?
Stephanie,
A good alternative is opto couplers. You can find them in the Digikey catalog under optoelectronics. Effectively they are an LED and a phototransistor. When the the light from the LED reaches the phototransitor a current flows. When the light path is blocked, no current flows. There are a variety of single package devices that work on reflective or direct light paths. I recommend an IR type so that regular light sources don't interfere with the device you are trying to sense. It then becomes a simple matter of mounting the device where it will be sensed by something moving on the arm and connect it to power and an RC sensor input. You can use the Banner sensors but they are an expensive alternative. If you have extras laying around the robot shop you can easily use them if you want.
Unread 27-11-2005, 19:56
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Team 662 used reed switches last year. We made hard stops put of HDPE and imbedded a reed switch and magnet into the two pieces of HDPE. The magnetic field was strong enough to trigger the reed switch before the hard stops made contact.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 27-11-2005, 20:10
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
I have a great story for this. My team used a limit switch to stop the arm when it it's fully retracted (we used an extruded aluminum extending arm). so during one match I tried to retract the arm after we got back for those extra 10 points it wouldn't retract!!. we tried everything at the pits to get it to retract. we could extend it but not retract it. So we formulated a plan so we weren't totally useless to our alliance. About 20 seconds before the next match started the Driver ken Yells out to our mentor "It's the limit switch!!" so our mentor runs from the driving station to the robot and rips out one of the wires on the limit switch. then of course it worked. They blame me for it, but then again i successfully turned an electronic stop, to a mechanical stop . so it's all good. I think you should go with the idea from Al Skierkiewicz. But another alternative is to use those sensors from house alarm systems, the kind you put on doors.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 27-11-2005, 20:28
REVving up for a new season
FRC #2848 (All-sparks)
i personally am a big fan of encoders. if you put an encoder on the motor driving the arm, or any other rotating shaft in the system; you can figure out the set number of rotations from start to your limit. I think this works well because at any given time you can change the location of your stop just by changing the number of rotations. You will still need a limit switch at the bottom of your arm movement to act as a "zero switch" so that the system re-calibrates itself when it comes in. Another advantage to this is you can make buttons that go to exact positions on the arm. since you know the number of rotations at any given height you could make a "center goal" button and not have to drive the arm manually to get there.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 27-11-2005, 20:42
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
The thing is, encoders only tell you where the system is supposed to be, not where it is. A limit switch (or the like) will tell you when the system is at its limit and should stop. If you only have an encoder you know that you're supposed to be somewhere, but if you have a loose cable or chain, you'll actually be somewhere else.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 27-11-2005, 21:00
Andrew Blair's Avatar
FRC #0306 (CRT)
I'm wondering about the use of pots. I know that they can be a degree or two off occasionally, and all the teams I've seen using them have a limit switch backup. Does anyone use pots exclusively?
-Sir Francis Bacon
-Albert Einstein
Unread 27-11-2005, 21:13
FRC #0306 (CRT)
Heres another option, the infrared beam breaking integrated into one piece, on the cheap. http://www.sparkfun.com/shop/index.p...=483346&cat=71& Its at the bottom of the page.
-Sir Francis Bacon
-Albert Einstein
Unread 27-11-2005, 21:18
CraigHickman
Posts: n/a
This year team 114 only used pots for our bot... Seemed to work perfectly on the arm (after a little tuning), and worked quite well on the wheels (we had one on the rotator chain of our swerve drive.
Unread 27-11-2005, 21:56
Umm Errr...
If your limit switches are breaking then its probably a design issue or you need some beefier limit switches. Do you have a pic of the assembly the keeps breaking. I have never once broken a limit switch and we always have limit switches everywhere on everything. If used properly they will not break.
1139 Alumni
Unread 27-11-2005, 22:09
Bharat Nain's Avatar
Originally Posted by RbtGal1351
Hello,
Thanks
~Stephanie
We had problems with the limit switch breaking all year. We made it as simple as possible to replace it(not that easy). And then we put a limit switch override button in programming. That way in competition if it did not work the operator could use his/her judgement and decide how far up/down the arm should go. The button came in really handy, especially at palmetto where we took finalist.
-Bharat
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 27-11-2005, 22:32
Gdeaver Gdeaver is offline
FRC #1640
There are many different grades of limit switches. If you look in a Mcmaster-Carr or Grainger catalog you will find some real beefy limit switches.
Unread 27-11-2005, 23:21
while this is true that they tell you in a theoretical world what your position is, if the system is decently designed and tested you should be abel to have them calibrated with little error. This is the reason for the calibration limit switch at the bottom, so each time you go to zero the calibration gets checked.
Unread 27-11-2005, 23:44
Electrical Engineer
AKA: Phil Baltar
FRC #1351
The main reason we use limit switches is to prevent damage. Despite my many warnings, people have, on occasion, decided to forego the implimentation of limit switches to save themselves some time. Needless to say, it usually ends badly. The limit sensor tells you when it's time to stop. Maybe something got jammed. Maybe something broke. Maybe there was a design oversight. It doesn't matter how the system got into that position, but going further could damage it.
Version: 3.12
Unread 28-11-2005, 00:05
there is absolutely no reason why a Cherry or SwitchCraft limit switch should ever break on your bot.
Im going to chance a guess here and bet you had the switch mounted so it was acting as a physical stop to the motion. A limit switch is suppose to actuate as a mechanical tripper slides PAST the switch lever, not INTO the lever from 90 degrees.
maybe I should sketch this out - thousand words and all that!
the red/black square is the moving arm tab that will engage the switch level. Note that it moves/ slides into the level and the lever closes the switch.
With the switch mounted like this there is no way its going to break, no matter what your SW does.
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
limit switches stephenthe1 Programming 28 11-05-2005 16:37
Common Ground on Limit Switches Gary Bonner Electrical 4 18-02-2005 13:24
Limit Switches help. Xufer Programming 9 21-04-2004 21:21
Team selector switches on ISAAC Lloyd Burns Robotics Education and Curriculum 0 17-12-2002 08:32
