Go to Post FIRST showed me how to succeed at one of the most difficult, yet important things: Life. - Jim McGeehin [more]
Unread 28-11-2005, 09:53
Re: Alternative to limit switches?
if you are not protecting your microswitches, then anything else you put on thats unprotected will get smashed as well.
You might consider a lever or spring that actuates the microswitch from a distance, so the switch doesnt need to be exposed to the parts of the bot that get bashed during a match.
An example is the power switch in most PCs. The switch is back by the power supply, but the on/off button is on the front panel, connected by a long push rod.
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
limit switches stephenthe1 Programming 28 11-05-2005 16:37
Common Ground on Limit Switches Gary Bonner Electrical 4 18-02-2005 13:24
Limit Switches help. Xufer Programming 9 21-04-2004 21:21
Team selector switches on ISAAC Lloyd Burns Robotics Education and Curriculum 0 17-12-2002 08:32
