Go to Post The bottom line is, what works best for YOUR team is what the best solution is. - EricH [more]
Unread 01-12-2005, 19:37
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Inventor Licensing
Arrrgh! I foolishly installed a visual studio beta, then uninstalled, and now the .net framework to run autodesk will not install!!! I've seen a fix, here
http://blogs.msdn.com/astebner/archi...27/444085.aspx
But it doesn't work. Does anyone else have a solution???
-------------------Edit------------------------
Aha! To anyone needing a fix, here it is. I was beginning to hate Microsoft, but there is a silver lining to every software bug...
http://blogs.msdn.com/astebner/archi...21/410573.aspx
-Sir Francis Bacon
-Albert Einstein
