Go to Post If it wasn't for 47, none of us would be here. - Taylor [more]
Unread 02-12-2005, 15:22
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
Possible to do multi-speed transmission with v-belt?
We at 617 here have come upon an idea that uses loose v-belts to do a multi-speed transmission (we hope), but i am not sure that it will work. Does anyone see any problems with this? (refer to attached jpg)
hopefully, one belt will be kept tensioned by the 2pulley assembly being pushed downwards far enough to keep friction between the 2 pulleys that the belt is running over, and the other belt (there are two, one for each gear reduction) is kept loose so that it is not affecting the driven speed.
thanks for your input!
Name:	v-belt&pulley transmission.JPG
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
Unread 02-12-2005, 15:49
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Re: Possible to do multi-speed transmission with v-belt?
Team 151 (my hs team) tried this idea...and having no luck at all. Theoretically, yes the theory is good, but it's a hassle to always keep each belt in tension (to a degree) to keep it working, and the belts ALWAYS slipped. My question is why do you want to go this route? Seems to me a geared box would be smaller and more effiecient, with what you give up in cost you make up for in robustness. Just my $.02 worth of experience
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 02-12-2005, 16:06
I dont see any reason why this would not work. My 1961 riding lawnmower has V-belt drive for the drive wheels and the cutter (and it has a ten HP engine).
My only observation is that it takes a LOT of tension on the belts to keep them from slipping - more than you would intuitively think.
If you are thinking of engaging the tension with a pnuematic cylinder you will need to use quite a bit of leverage to pull the tension wheel tight against the belt.
Unread 02-12-2005, 16:18
Matt Matt is offline
Matt is on a distinguished road
Team 1212 two years ago used V belts for its drive train. The belts will work but it requires a tensioner to keep them taught. This is because the belts will stretch over time because of wear and tear.
We never used a transmission of v belts but as a pulley reduction. I can not seem to find a picture of our robot anywhere sorry about that.
Unread 02-12-2005, 16:38
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
There is no reason why this sort of design cannot work. It would require that you gather data about what amount of belt tension is required, either experimentally or mathematically, as well as belt lengthening over time.
Where within a drivetrain did you anticipate placing this? Early in the reduction, you're transmitting far less torque along the belt and thus require less tension to keep everything spinning together, but by placing it later in the reduction -- or even as an output stage -- you can use larger materials and things, mitigating the need for precision.
Can anyone share some anecdotal information about what sort of tension might be required to keep the belts and pulleys in synchronization? Someone who works with cars may have a good idea.
--Madison--
...down at the Ozdust!
Unread 02-12-2005, 16:50
AKA: Mongo
I never said this design WOULD'NT work, all I was saying was that I have had experience with a two speed belt tranny, and it was pointless. We had no torque, because all that energy was now going into belt slippage, gears are soooo the way to go.
Not to completely bash your idea, if you were looking at it as a way to teach kids about reduction, or even on a practice bot, the idea is logical.
Unread 02-12-2005, 17:04
on a car, to get the alternator belt tight, you normally have to pry the alternator with a crow bar, and put a significant amount of force on it.
BTW, modern Vbelts dont streach like they use to. I have not needed to adjust a Vbelt tension in the last 10 years.
The reason why belts are still around after all these years is they can perform 3 functions at the same time:
1. gear reduction
2. power transmission (from one pulley to another)
3. clutch mechanism. Its pretty tricky to get a gear or chain to engage under load smoothly :^)
and one other advantage to belts, they can be very quiet compaired to gears or chains!
Unread 02-12-2005, 18:55
Derek Bessette's Avatar Unsung FIRST Hero
Derek Bessette Derek Bessette is offline
FRC #4976 (Rebels)
Derek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond repute
There is an idea very similar to this that will work. It has been proven with much higher torques that those seen on a FIRST robot. It is called a CVT (Continuously Variable-Transmission). There are many types of CVT's but the style you are looking at is used on snowmobiles and go-karts.
Here is a thread that shows you what I am talking about.
CVT Thread
Here is a place where you can buy a CVT in the range a FIRST robot would use.
www.hi-lo.com
It would be difficult to build one of these on your own but it definitely can be done. The trick behind these CVTs is that the more torque you apply to the tighter the secondary will squeeze on the belt. This creates more belt tension.
Hope this helps.
Derek Bessette
Team 4976 - GDHS Rebels
(Formerly Team 1114 and 3571)
Unread 02-12-2005, 19:49
Madison's Avatar
FRC #0488 (Xbot)
Here's a sketch of something that might work, assuming that you can get can get enough force out of a small cylinder combined with a reasonable lever arm -- say, 3:1 or 4:1 or 60 or 80 lbf.
--Madison--
Unread 02-12-2005, 20:08
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
team 694 used this method to turn the kit bot into a two speed drive train. there's a thread, but all the links are broken. i do have one of their promo videos, which shows the bot shifting, but its too large to upload.
they modified the frame to run 6 wheels, and all the wheels on one side a connected using belts. the front and back wheels are also connected to the kit gearbox, but the gear ratio is different for the front and back wheels, and the gearbox moves back and forth, tensioning one belt and loosening the other when its moved in one direction by a pneumatic cylinder, and vice versa when its moved the other. a very simple and elegant drive train; one of my favorites.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 02-12-2005, 20:36
DonRotolo's Avatar
Back to humble
FRC #0832
In order for any belt transmission to work, the entire belt must be in tension. Modern cars use a belt tensioner to compensate for stretch, think of a pulley on a spring arm. The idea from M. Krass is one good way of doing it.
The tension needs to be so high that a 12" unsupported belt segment will deflect less than 1/2" with about 10 lbs pushing on it (assuming a 5/8" V-Belt or 19 mm Poly (flat) belt) to keep it taut. If the other belt is fairly loose, it will slip enough to be insignificant - BUT it will have a tendency to fall off the pulley.
Dayton or Grainger probably have belt transmission formulae on their web sites, how many HP a given belt can transmit. If one Horsepower is about 746 watts, and a CIM motor draws 20 Amps at 13 volts, you have about 1/3 HP, and most any belt will handle that happily.
There are different belts with different amounts of grip. My snowblower uses a belt to drive the auger, and it has a clutch. If I use too grippy of a belt, the clutch never releases. The 'wrong' belt has 'not for clutching applications' written right on the 'box'. I say this because the loose belt will still have some grip, and that can be a problem with the wrong belt.
What you propose will work, but I recommend building a prototype and a lot of testing, especially long-time testing to gauge durability. Hook up a motor and let a belt slip a bit (and the other grip a bit) for a week, see what happens.
Don
Unread 02-12-2005, 22:13
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Hope this helps.
When I was in college our Mini-Baja team used this sort of thing. It worked pretty well for that. Depending on how the tensioning happens you have to make sure your shafts are in the right speed range, but you know how to do that right?
Christopher H Husmann, PE
"Who is John Galt?"
Unread 02-12-2005, 23:07
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Another data point that this kind of system will work. When I was a kid, my father built a go-kart for me that was two speed. There was a pair of v-belts that could be selectively tensioned by the "gear shift".
Unread 04-12-2005, 19:52
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
As said above my garden tractor actually uses a belt as the clutch and it works very well in the 10 years we've had it the belt has never brokem or popped off, and this one has a 21 HP engine with lots o torque(for a small briggs anyway)
I would use 2 pneumatic pistons driving an "idler" sproket onto the pulley you want operable. what you may want to do it have pots on the oi that controll how much pressure is applied to the cylinders and the pulley so that there is enough tension but you dont snap belts,
also with 2 pistons you can cntrol them individually so that one is not dependent upon the other in case a belt does come off you just stay in the other gear.
To keep the belt from jumping off the track, make the track too tall for this to happen by adding a plate that is about and inch larger than the pulley and if the belt pops off then you have other issues
Also something that ensures the belt stays in its track like pins that it will rub against and keep it inline for the match untill the misalignment can be addressed
I have seen all of these methods used successfully in various applications with the exception of the dual cylinders that is merely my own creation
KK4KQO
http://voltair.us
Unread 13-12-2005, 14:29
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
Is it possible a belt system would be significantly lighter than chain or gears?
My first thought is probably not, but i dont know how much chain weight compares to belt weight.
White Paper Discuss: Team 33 Four Speed Transmission CD47-Bot Extra Discussion 10 19-04-2013 14:22
The perfect 2 speed Transmission..... features... Salik Syed Technical Discussion 28 20-10-2004 11:44
White Paper Discuss: 222's 3 Speed Shift-On-The-Fly Transmission CD47-Bot Extra Discussion 4 14-07-2004 15:43
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
322 Three speed transmission. dkeith Robot Showcase 8 10-06-2002 22:33
