Go to Post Since you have to undo all the connections anyway in order to swap them, you might as well take advantage of the opportunity to do some simple and straightforward troubleshooting. - Alan Anderson [more]
Unread 03-12-2005, 14:14
Umm Errr...
I broke my inventor 10 CD!
The case that houses the inventor 10 CDs is difficult to remove CDs from. While trying to remove CD 1, I cracked it!!! Not only is the case too strong, these CDs seem to be made of an atypical plastic that is very brittle. Normally, you can bend a CD almost a complete 180 degrees without them snapping although they will be permanently deformed. Be very careful!
If anybody would be willing to help me out by say supplying me an ISO, this would be GREATLY appreciated. As far as i know, this does not violate the liscencing agreement.
1139 Alumni
Unread 03-12-2005, 15:58
Beth Sweet's Avatar
Beth Sweet Beth Sweet is offline
is getting lost in her new home
FRC #0116 (Epsilon Delta), #1504 (alum), #67 (alum)
Beth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond repute
Re: I broke my inventor 10 CD!
Did you try calling or emailing them? I'm sure if the product was defective (which it sounds like it was as it was their case that caused the break) that they would send you a new one
This season, I was a part of a great team, with great kids who were really inspired, and who inspired me back. That's my brag, what's yours?
Unread 03-12-2005, 19:45
teamtestbot's Avatar
teamtestbot teamtestbot is offline
Prophet of ROFLCOPTER
AKA: charles
FRC #1771 (NGHS Robotics)
teamtestbot is a jewel in the roughteamtestbot is a jewel in the roughteamtestbot is a jewel in the roughteamtestbot is a jewel in the rough
Send a message via AIM to teamtestbot
That's what I thought when I first opened the cases. You'd think the button they put in the middle does something to those little teeth, but it doesn't, and to prevent flexing the CDs too much I actually squeezed them with pliers first!
Unread 03-12-2005, 20:42
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Very surprising. I've had a lot of experience hacking apart CDs (drilling, cutting, etc) and they seem pretty flexible actually. Drilling will crack it if you go in too fast, but a CD cracking from taking it out of the case - I've never heard of that one.
Unread 03-12-2005, 21:21
Andrew Blair's Avatar
FRC #0306 (CRT)
Yeah, it is important to squeeze all the teeth with your fingers at once. The little flap with cd's 3 and 4 is even worse, because it's difficult to press down the shorter teeth which grip the cd all too well.
-Sir Francis Bacon
-Albert Einstein
Unread 03-12-2005, 22:18
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Any pictures of the case and cd?
I would like to see!
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 04-12-2005, 01:40
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
E-mail FIRST team support about it.
The same thing happened to us a few days ago, and we sent them an e-mail. They got back to us within a few hours and told us a new copy was en route.
It seems as if a lot of teams have been having this problem.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 04-12-2005, 03:06
Umm Errr...
What is FIRST team support? How do i contact them?
1139 Alumni
Unread 04-12-2005, 10:42
Circuit Breaker
Just send an email explaining your problem to frcteams@usfirst.org. They will in turn ask Autodesk to send you another copy.
Patrick Fairbank
patfairbank.com
Unread 04-12-2005, 14:03
Umm Errr...
I emailed them. I will let all you CD people know what the outcome is. I think a FIRST email Blast cautioning against these CD cases might be in order.
1139 Alumni
Unread 09-12-2005, 18:23
vVigglEs vVigglEs is offline
Matt Pietkevich
AKA: Mad CADer
FRC #0177 (Bobcat Robotics)
vVigglEs is an unknown quantity at this point
Send a message via AIM to vVigglEs
guess what.. team 177 CD snapped two
I'm really disappointed
Unread 12-12-2005, 18:49
jrmarenda jrmarenda is offline
AKA: Jason Marenda
FRC #1887 (Russet Robotix)
jrmarenda will become famous soon enough
The same thing happened to our team. Email your mailing address to: Kelly.Stanphill@autodesk.com. and Autodesk will send you a replacement.
Unread 14-12-2005, 20:54
Goaliexam Goaliexam is offline
AKA: Max
FRC #1656 (Haverford Robotics)
Goaliexam is a jewel in the roughGoaliexam is a jewel in the roughGoaliexam is a jewel in the rough
Send a message via AIM to Goaliexam Send a message via MSN to Goaliexam
That happened to us too, and our replacement copy is already on its way. You would think that a huge company like Autodesk would do some decent QA (Quality Assurance) testing before releasing a professional product.
Unread 14-12-2005, 21:23
Umm Errr...
wow! This really is a widespread problem
1139 Alumni
Unread 15-12-2005, 13:09
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
we looked at ours yesterday (actually, i opened the box and decided to try to install it). I took it out and I thought it came out clean, and there was a loud noise, but i thought that that was just a new cd coming out of the case for the first time. When it went into the computer, though, it didn't register. I took it out again to look at it, and the cd had a nice craack all of the way through one side. SO ... we're hoping that the Autodesk people can send us another one quickly. grr...
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
RC Power Spade Broke dan1120 Control System 8 01-03-2005 22:38
pic: Oops.. We broke it. CD47-Bot Extra Discussion 8 22-10-2004 18:23
Dean Kamen Broke Our Robot!! Carlo General Forum 14 28-04-2003 15:46
HELP! We broke a weld. Anyone have aluminum capabilities? archiver 2000 0 23-06-2002 23:01
I broke 100!! archiver 1999 1 23-06-2002 22:56
