Go to Post ..this is the first robot we've built that succeeded at everything we wanted it to. It was simple. It was low maintenance. It scored effectively. It had an autonomous that worked. Its look caught attention. And it was finished on schedule. - Donut [more]
  #31   Spotlight this post!
Unread 04-12-2005, 12:12
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: new from IFI
Originally Posted by Andrew Blair
Yeah, but remember, whatever is in the KOP is multiplied by a thousand.
Last year alone:
$150 for the CMU
$300 for two gearboxes (estimation)
$100 for the kit frame
+____________________
As an aside, those items almost certainly cost less. Im not sure about the CMU cam, since they may have had to pay for them all, and didn't get them donated, but it surely can't cost $300 for the transmissions and $100 for the frame, because IFI wouldn't be selling them at cost to us as aftermarket parts.
I can't see this ending up as a positive if they're put in the kit. If Team A gets 4" wheels, they'll complain since they want 6". If Team B gets 6" wheels, they'll complain that they wanted 4". Team C will complain that they wanted the 1/2" bore, not 3/8" Team D will complain that there's only two of them. Team E will complain that their robot can't turn because of IFI.
If these were "one size fits all", I could see them sending them out in the kit, but why send out a wheel that has so many different options? 4" 6" 8" roughtop or wedgetop 3/8" or 1/2" bore. 1" 1.5" or 2" width.
2001-2004: Team 100
2006-Present: Team 254
  #32   Spotlight this post!
Unread 04-12-2005, 12:45
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: new from IFI
Why?
So if they send out 8'' wheels in the KOP and you want a low center of gravity you will go out and buy their 6'' or 4'' wheels.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
  #33   Spotlight this post!
Unread 04-12-2005, 15:01
Winged Globe Winged Globe is offline
Don't Panic
AKA: Xiao-Yu Fu
FRC #0481 (The Hitchhikers)
Winged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of light
Send a message via AIM to Winged Globe
Re: new from IFI
Teams complain about everything (We want 4 wheel drive! The chassis is flimsy! etc. etc.). How would this be new?
Why do they send out any wheels at all in the KOP? And yet, they still do each year. Every KOP gets the same type of wheel, and, if going by last year's example, you can pop then on the kitbot frame and have a working drivetrain. If teams don't like it, they go make their own or buy different versions, just like it's always been with Skyway. Again, how would this be new?
That said, the thought of an ordering system a la pneumatic cylinders crossed my mind, but if these end up in the KOP, I just expect everyone to get the same 2 or 4 wheels. And if we don't, I'm still getting them.
Team 2B0
~O~
  #34   Spotlight this post!
Unread 04-12-2005, 21:11
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: new from IFI
As has been said above, noone will complain more than about anything else, and if they do, as usual, they can shove it in their pie holes. The fact is, First just has to say, the frame takes 3/8" standard. So thats what you get. The skyways are 6" wheels, so you get six inch wheels. We think wedgetop wears better ( just an example!), so you get wedgetop. End of story. If you want something different, get it yourself, or buy it from us.
And the costs lower, but still close to as high for the kit bot as I said. At IFI,
http://www.ifirobotics.com/kitbot.shtml, the price for the kitbot frame is $190.
Revision 1, the frame should cost IFI $95 to make. I was a little high.
I was however, astronomically high for the gearboxes. IFI retails 'em for $150, so they're prolly about 60-80 dollars to make. Should've done my homework there dang'it. Sooo....a revision is in order.
$150 for the CMU
$150 for two gearboxes (estimation)
$ 95for the kit frame
$395 added on by FIRST to the cost of the kit. At least. So, $40, which would be a 10.13% increase in the kitbot's cost this year still seems like a walk in the park. My argument remains:IFI will try to improve their platform in the kit this year. The wheels are where to start.
-Sir Francis Bacon
-Albert Einstein
  #35   Spotlight this post!
Unread 06-12-2005, 20:24
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: new from IFI
All,
Yes, I designed them.
IFI will begin selling mechanical products for the 2006 FIRST season. These wheels & aluminum sprockets will be one of our flagship products.
We will be posting them for sale, ASAP. Definitely before Christmas.
There will also be more details posted shortly including weight, cost, & CAD drawings.
Non-Quantitative Answer:
(They are light as a feather, and strong as a brick.)
The tread is riveted in place with 1/8" aluminum rivets or held on with screws (no hardware for attaching tread is included). This is the same method used by 229 (and many other teams) in the 2005 season.
Each of the side plates extendes beyond the wheel-rim a small amount (.08") to provide reinforcement against side-loads on the tread.
#35 Aluminum sprockets will be 1/8" thick, in a variety of tooth counts (ranging from 22 to 96).
The contents of the 2006 kit will not be released until January 7th. No information can be released until that date.
"This is how we roll..."
-JV
  #36   Spotlight this post!
Unread 06-12-2005, 20:29
Cory's Avatar
AKA: Cory McBride
Re: new from IFI
-JV
Continuing the trend of reading way too far into anything posted by someone who may or may not have insider info...
Clearly John is trying to say IFI will be producing Omni wheels
2001-2004: Team 100
  #37   Spotlight this post!
Unread 06-12-2005, 20:34
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: new from IFI
-JV
A set o' wheels for Christmas! What a nice present for any team to receive!
Richard Wallace
since 2003
  #38   Spotlight this post!
Unread 06-12-2005, 20:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: new from IFI
Is it just me or does anyone else see IFI eventually turnining into an all-out robot parts supplier with motors, gearboxes, drive components, etc sort of like RobotMarketplace (robotcombat.com)? That would be awesome!
  #39   Spotlight this post!
Unread 06-12-2005, 21:41
FRC #0306 (CRT)
Re: new from IFI
Ha, I have the sinking feeling that I lose this debate, regardless of my argument... Still, I look forward to being able to have some more robotics suppliers dedicated mostly to FIRST.
-Sir Francis Bacon
-Albert Einstein
  #40   Spotlight this post!
Unread 06-12-2005, 22:30
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: new from IFI
This isn't battlebots (robotcombat.com), but I love these new wheels, you have less chances of tiping over too since it's so wide.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
  #41   Spotlight this post!
Unread 06-12-2005, 23:31
Re: new from IFI
Those two things have less to do with each other than you may realize.
  #42   Spotlight this post!
Unread 06-12-2005, 23:57
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Re: new from IFI
Hmm.. well now that I think more in depth, depends more on the shape of the robot, plus it's still has a fulcrum point.
Callsign: N6ARA
  #43   Spotlight this post!
Unread 07-12-2005, 10:12
the_short1's Avatar
the_short1 the_short1 is offline
Head of Electronics
AKA: Kevin F.
FRC #1596 (Twin Saults International Instigators)
Team Role: Electrical
the_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to all
Send a message via MSN to the_short1
Re: new from IFI
hmmm well, if the title was 2006 kit of parts it would be very ovious giveaway and people would be looking for 2006 stuff on websites
i think maybe we have to push heavy boxes up a hill or something this year.. we all know its gona be squares.
2005 GLR: 12th/58 Seed, Aliance: 1596, 910, 1447 (Semi Finalists) Website, Rookie All Star, Highest Rookie Seed, and 2 Peer Awards, my BIG thank you thread, PLEASE READ
2005 GTR: 11th/66 Seed, Aliance: 703, 1596, 1680 (Semi Finalists) Highest Rookie Seed & 1 Peer Awards
2005 Championship (Galileo): 36th/86 Seed Highest Galileo Match Score: 123:7 Thanks 447 and 121
2006 Website (Totally Revamped):Instigators1596.com
2006 GLR: 31st/61 Seed, Aliance: 835, 1213, 1596 (Quarter Finalists) Spirit & 3 peer awards, THX!
2006 Waterloo: 7th/31 Seed, Aliance: 1219, 1596, 912 (Semi Finalists) Spirit & 2 peer awards, THX!
2006 Waterloo: Aliance: 1596, 1680, 1114 Higest Match Score: (Q22) 128|32
  #44   Spotlight this post!
Unread 07-12-2005, 12:24
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: new from IFI
-JV
Did John just drop a hint????!!
Yippee! Someone else that can have their every word over-analyzed, mis-read, inverted, converted, perverted, misinterpreted, reverted, and garbled besides just me!
OK, now on three, everyone go back through every post John has made in the last seventeen months, and you will find clues to at least half of the upcoming game. Ready - 1 - 2 - 3!!!
-dave
  #45   Spotlight this post!
Unread 07-12-2005, 12:36
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: new from IFI
??? The wheels are delivered without the tread attached?
IFI Loader Reloaded sciguy125 Programming 26 07-08-2007 00:07
IFI Loader usually hangs midway thru load gnormhurst Programming 4 04-02-2004 11:40
IFI Loader Problems BrendaB Programming 3 24-01-2004 22:45
IFI Loader Doc's Raven_Writer Programming 0 21-01-2004 17:53
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
