Go to Post The rule is the rule because it is the rule. - dtengineering [more]
Unread 04-12-2005, 15:22
Umm Errr...
Re: Use a USB Joystick - "FORCE FEEDBACK 2"
To create a converter would take an intimate knowlegdge of USB HID standard, microconrollers and a way to decipher the proprietary protocol used for the force feedback. Then, you are still faced with the problem of how to power it. I have the gameport version of this joystick and it uses 1.5 amps!! This is NOT the way to go. You would also have to ahve digital to analog conversion circuirty. Even if you surmount all the above obstacles you still have to figure out a way to get data to the thing to control the force feedback. Trust me. Its a bigger task than you think.
1139 Alumni
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Force Feedback Andrew Blair Control System 67 12-12-2005 18:40
USB Joystick to DB15 team1307 Control System 7 21-01-2005 11:58
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
