Go to Post Team 71: So good at Strategy they already have figured out next years game before the GDC has even met. - IKE [more]
Unread 29-11-2005, 07:52
or yaniv or yaniv is offline
or yaniv is an unknown quantity at this point
Use a USB Joystick - "FORCE FEEDBACK 2"
We think to use the "FORCE FEEDBACK 2" joistick to control our robot this year. But this joistick have a usb port.
Does anyone tried to convert the usb port to game port?
Does anyone tried to use this jostick?
thank you all,
yours: Or
Unread 29-11-2005, 14:21
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Use a usb jositck-"FORCE FEEDBACK 2"
Converting USB to gameport is not a simple task, and would require a lot of custom circuitry. You'd be better off opening up the joystick and seeing if there are potentiometers, which you can connect to the correct pins of a DB15 cable.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 29-11-2005, 15:21
There's no simple "conversion" possible.
The only two options are to rewire the joystick (assuming the potentiometer values are compatible) or to put a computer in the middle to talk to the USB device and simulate a gameport joystick. Competition rules have consistently forbidden connecting a computer to the joystick input.
Unread 29-11-2005, 20:50
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
I have to think it's something similar to this.
But then again, I'm just the mechanical guy. Yes... I am STILL trying to get our geek team to post the white paper.
Brian Graham
Unread 29-11-2005, 21:10
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: Use a USB Joystick - "FORCE FEEDBACK 2"
I am 99% sure that is a digital joystick unlike the analog ones we use for FIRST it is not possible to use any digital joystick to analog converter as ar as i am aware without breaking FIRST rules, it doesnt use the pinout of a normal joystick but uses a serialization technique like pwm but ot quite to comunicate with the computer.
KK4KQO
http://voltair.us
Unread 29-11-2005, 22:03
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
The joystick you have pictured also requires a separate power supply (the connector on the bottom left of that picture). The topic of a force feedback joystick is covered extensively in this thread:
http://www.chiefdelphi.com/forums/sh...ad.php?t=40486
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 04-12-2005, 15:15
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
I know it's possible to convert USB to serial. But maybe theres a way to convert from serial to the game port. I'm not sure but it's just an idea.
edit:
http://www.aggsoft.com/rs232-pinout-...b9-to-db15.htm
I don't know if this pinout will work, but i'm gunna take a nice little trip to radio shaq. and when i get back we'll find out.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 04-12-2005, 15:22
Umm Errr...
To create a converter would take an intimate knowlegdge of USB HID standard, microconrollers and a way to decipher the proprietary protocol used for the force feedback. Then, you are still faced with the problem of how to power it. I have the gameport version of this joystick and it uses 1.5 amps!! This is NOT the way to go. You would also have to ahve digital to analog conversion circuirty. Even if you surmount all the above obstacles you still have to figure out a way to get data to the thing to control the force feedback. Trust me. Its a bigger task than you think.
1139 Alumni
Unread 04-12-2005, 19:55
No, I don't think that'll help. You'll run into the same problem as trying to use USB in the first place, and you'll find that USB-to-serial converters work in the wrong direction for what you want.
The 15-pin connection in that document is a 15-pin high-density connector like a VGA video connector, and it's still RS-232 serial. It isn't compatible in any way with a 15-pin game port connector.
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Force Feedback Andrew Blair Control System 67 12-12-2005 18:40
USB Joystick to DB15 team1307 Control System 7 21-01-2005 11:58
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
