Go to Post When was the last time you heard of someone on their death bed talking about a great movie they saw? I think it far more likely to hear of their accomplishments, something they did to make things better. Well that's what FIRST is all about. - DougHogg [more]
Unread 04-12-2005, 21:05
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: pic: Dual omni-wheel
Originally Posted by Stud Man Dan
We ended up milling the slots a bit larger in order to places washers in to keep the rubber wheels firm and sliding easier. ...
Good luck I'd love to see the finished product hopefully you'll post some pictures. I don't have any pictures of our modified wheels or our finished product but omni directional is deffinately a lot of fun.
Thanks for reviving the thread, Stud Man Dan.
I had been meaning to post some pictures. We did complete a holonomic drive train demonstrator, and used it as part of tutorials at St. Louis FRC Regional Fall Training Camp about a month ago. Total weight as driven was about 69 lb. Controllability on linoleum or carpet is excellent. Traction is not great, but may be adequate for a flat surface, offense-oriented game, and it should improve somewhat when weight is added.
I'll post some more pictures tonight. One shows the anti-binding washers (ersatz thrust bearings) that you described above -- we added them after I posted the picture that started this thread.
Richard Wallace
since 2003
Unread 04-12-2005, 22:35
Rohan_DHS Rohan_DHS is offline
AKA: Kayla's big bro...
FRC #1620 (Robolution)
Rohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of light
Send a message via MSN to Rohan_DHS
i gotta pretty newb-ish question...what is the advantage of an omni wheel over a regular wheel...is it traction?
Rohan K
2008: Alumni, Helper
2007: Webmaster, Alumni
2006: Team Captain, Driver, Electrical/Electronics Head
2005: Safety Captain
Unread 04-12-2005, 22:45
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
There's two basic ways in which omni-wheels can be used.
The first involves placing 3 or 4 omni-wheels at angles to each other. With proper motor control, this allows the robot to travel in any direction, regardless of it's orientation - this is referred to as a holonomic drivetrain.
The second method involves a regular 4- or 6-wheel-drive drivetrain, where some of the wheels are replaced with omni-wheels. The robot still maintains almost the same amount of traction and manoeuverability (as opposed to using casters) but turning is much easier since the omni-wheels can slip sideways.
Hope that answers your question.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 04-12-2005, 23:12
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I hope that you also meant to ask about the disadvantages...at least for holonomic systems.
Mainly, those revolve around the force components going off in strange directions, and cancelling each other out, in order to produce a desired motion. For example, a robot with omniwheels at the corners, each at 45° to the principal driving direction of the robot, can be modelled as having force components in the direction of travel, and the perpendicular direction. Due to the 45° angle, and the fact that the wheels are 90° apart, if you drive the robot forward, the motion will be provided by the forward components, and the sideways components will act against each other (left vs. right) and do no useful work.
ΣFy = 2 F sin(45°) + 2 F sin(135°) (Force in y-dir)
ΣFx = 2 F cos(45°) + 2 F cos(135°) (Force in x-dir)
ηy = ΣFy / 4 F (Efficiency in y-dir)
ηx = ΣFx / 4 F (Effiiciency in x-dir)
For the simple case of driving forward, you get an efficiency of around 70% in the driving direction, and (of course) 0% in the perpendicular direction. As the output to each wheel varies in a holonomic drive system, the components move, but in general, either the efficiency suffers, or the total power does (as in, two wheels fully forward, and two fully perpendicular—50% power, but 100% efficiency). The same goes for mecanum wheels, in a conventional configuration.
Last edited by Tristan Lall : 04-12-2005 at 23:22. Reason: Stupid vB can't handle line breaks, indentation!
Unread 04-12-2005, 23:48
Recently posted images. Top view, bottom view, and first test run.
Next we plan to try other roller materials, aiming for better traction than we obtained using polyurethane. Maybe gum rubber, as team222badbrad recommended earlier in this thread.
Richard Wallace
since 2003
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: Dual FP motors through a Dewalt XRP Andy A. Robot Showcase 5 18-02-2005 09:07
Steering wheel issues jgannon Programming 5 15-12-2004 10:14
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
