Go to Post Not winning is different than being a loser. - seanwitte [more]
Unread 05-12-2005, 15:33
Shlomi32's Avatar
Shlomi32 Shlomi32 is offline
AKA: Shlomi
FRC #1577 (SteamPunk)
Team Role: Driver
Shlomi32 will become famous soon enoughShlomi32 will become famous soon enough
Send a message via ICQ to Shlomi32 Send a message via MSN to Shlomi32
communication between the robot controller and the interface
Hello....
how can we change the frequency signals of the transmitter?
so i can activate 2 robots with different signals at the same time...
Team 1577 "Steampunk", 'Aviv' high school, Israel
Visit Our Site : http://www.avivrobotics.net
Unread 05-12-2005, 15:43
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: communication between the robot controller and the interface
Is this for VEX or FRC?
Unread 05-12-2005, 15:48
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
I'm assuming this is for FRC.
Check out pages 16-17 of this document for information on how to enable and set the additional channels.
Basically you have to set the leftmost bit of the TEAM NUMBER dipswitch on the OI, connect the tether to set the robot to the same team number, and choose the channel with the CHANNEL dipswitch.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 05-12-2005, 15:50
Eric L Eric L is offline
FRC #1114 (Simbotics)
Team Role: Electrical
Eric L has a spectacular aura aboutEric L has a spectacular aura aboutEric L has a spectacular aura about
if it is the FRC controllers you must tether both interfaces, power them up, then change the dip switches that are marked as "Team Number" these switches are set in binary. After you change the team number then you can unhook the tether cord and use your radios. In order to run 2 robots you will need 2 R/C radios and controllers, as well as 2 O/I's.
If it is a VEX robot then you will need to remote controls, 2 receivers that are plugged in to your controller(s) and 2 different radio crystals (radio channels/frequencies)
2006 GLR Winners
2006 Waterloo Winners and Chairman's Award Winners
2006 GTR Winners
2004 Canadian Regional and Pitsburg Finalists
www.niagarafirst.org
Unread 05-12-2005, 16:53
Shlomi32's Avatar
AKA: Shlomi
Team Role: Driver
thank you all!!! it works!!!!
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Can We Use A N64 Controller To Control The Robot pobots Electrical 25 18-04-2003 12:48
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
So what happened at the FIRST forum Todd Derbyshire General Forum 57 05-08-2002 22:18
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
