Go to Post I always thought a trained bio mechanical monkey wrapped in aluminum foil would be the best robot, but every year my team says "No Pete, go sit down." - BuddyB309 [more]
Thread Tools Rating: Thread Rating: 7 votes, 4.43 average. Display Modes
Unread 05-12-2005, 20:54
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Re: What kind of car do you drive??
Originally Posted by greencactus3
hmm. unless theyhad a nice sugarwatercoated grippy ground with upgraded tires, i doubt they "just floored it" much less brake torqued it. half those trucks would not be going anywhere... just sitting there with one tire smoking. unless they used a truck with anything other than an open diff, the stock tires dont bite enough to send the truck forwards... no weight over the axle + lotsa torque = no traction.
The way to get the best time would vary depending upon the characteristics of each vehicle. Of these trucks, the Dakota, with its big displacement, mildly tuned V-8, you would need to modulate the throttle in order to control wheel spin. The same might be the case with the Nissan and Toyota's V-6's, but they would have less torque at low rpm. With the Colorado, you could probably "torque it up" at full throttle and not get too much wheel spin. With the Honda's full time four wheel drive, you could "torque up" at full throttle and not get wheel spin at all. The bottom line is that the enthusiast magazines experiment and use whatever technique gets the best times.
Team 1062, The Storm, 2003
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
What kind of car do you drive? Amber H. Chit-Chat 49 03-10-2002 21:20
