Go to Post And let's face it their junk is our robot! - jrgrim12 [more]
Unread 05-12-2005, 18:33
Chris's Avatar
Chris Chris is offline
So apparently it hangs......
AKA: Chris Carnevale
FRC #0177
Chris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond repute
pic: IFI's new wheels on Denominator
Chris C.
Team 151 | Alumni | 2000-2002 | Nashua High School
Team 229 | Alumni | 2003-2006 | Clarkson University
Team 148 | Alumni | 2007 | RackSolutions.com
Team 177 | Engineer | 2008-? |
Unread 05-12-2005, 18:41
Chris's Avatar
FRC #0177
Re: pic: IFI's new wheels on Denominator
Due to JVN's connection to 229 we were allowed to be the beta testers for the new IFI traction wheels, as you can see from the picture these were mere prototypes that we ran on a bushings just to get the testing done.
Let me just say we were all very amazed. With an aluminum sprocket they are almost exactly half the weight of the wheels that we used during the competition season last year.
We did a lot of testing, driving around and smashing the robot into walls. After being unable to fail a wheel through normal robot usage, we flipped poor denominator on her back and started hitting the wheels with hammers while they were spinning (videos to follow) Lets just say it took someone with more muscle than me to finally dent one of the wheels. After that we drove the robot around with the dented wheel and it still functioned. I was skeptical at first but ended up very impressed, we are currently planning on using these (4 inch ones) during the 2006 season.
Chris C.
Team 229
Unread 05-12-2005, 19:50
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Do you have any information if this wheel will be included in this years KOP? Also my team 610 is very interested in using this wheel anyways if it is not included in this years KOP. We have used this type of tread in the past, but never in this thickness of the wheel, I was wondering if this wheel affects turning speed of the robot, obviously due to the added friction? Thanks.
Unread 05-12-2005, 19:54
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
I am anxiously awaiting these videos....
Unread 05-12-2005, 20:45
slickguy2007 slickguy2007 is offline
Copioli is the man!!!
FRC #1403 (Cougar Robotics)
slickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond repute
Send a message via AIM to slickguy2007
What is the coefficient of friction for these wheels and how often do you have to change the treads (if at all)? How much do they weigh btw, the website did not indicate. These wheels look great!!
GO 1403!!!
Team 1403 is Proudly Sponsored By:
Unread 05-12-2005, 21:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I too am interested in the weight. I couldn't afford anything more than probably .65 lbs per wheel assembled.
For tread wear, they are so wide that your ground pressure becomes pretty low and so does the wear. Unless you are spinning for the entire match, I think they should last at least a regional, if not two.
Unread 05-12-2005, 21:59
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
GO 1403!!!
1.2-1.3 ish.
2001-2004: Team 100
2006-Present: Team 254
Unread 06-12-2005, 11:55
Adrienne E. Adrienne E. is offline
New Yorker turned Texan
FRC #0148 (Robowranglers)
Adrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond repute
Here is one of the videos that we took during testing.
http://www.vexlabs.com/video/IFI-Wheel_test.wmv
Adrienne Emerson
191 Alumni 2000-2002
229 Alumni 2003-2006
148 2009-Present
Unread 06-12-2005, 15:03
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Chris,
I like the spacers you used to locate the wheels on the axle...good stuff.
rob
Unread 07-12-2005, 12:19
davelu davelu is offline
AKA: fffff
#0123 (fff)
davelu is infamous around these partsdavelu is infamous around these parts
Hey, we had a similar desgin last year.
here's apicture of it
pic: Easy to make mecanum wheels mechanicalbrain Extra Discussion 15 06-10-2005 21:37
pic: IFI's New Vex Robot JVN Extra Discussion 18 20-07-2005 23:24
Programming a 2nd PIC ImmortalAres Programming 8 16-06-2005 12:13
pic: 222's wheels CD47-Bot Robot Showcase 14 11-12-2003 08:14
wheels ! Martin Technical Discussion 2 09-01-2002 16:08
