Go to Post I guess this is where theory vs reality comes into play. - PhilBot [more]
Unread 06-12-2005, 08:27
button boy 1100's Avatar
button boy 1100 button boy 1100 is offline
AKA: Baker
FRC #1100 (algonquin tomahawks (T-Hawks))
button boy 1100 is an unknown quantity at this point
Send a message via AIM to button boy 1100
robot cart
my team needs new ideas for a multi purpose cart for our robot... multi purpose being we can move it to and from field, and we can use it to work on the robot... any ideas?
Unread 06-12-2005, 08:51
MChapman MChapman is offline
AKA: Mellie
FRC #0176 (Aces High)
MChapman is just really niceMChapman is just really niceMChapman is just really niceMChapman is just really niceMChapman is just really nice
Re: robot cart
My team just came up with a new cart desgin for this year, and it's muti-purposful. I can put you in contact with the student who designed the cart, if you would like some ideas. PM at foss@team176. His name is justin and is one of our top design students. Wish you luck.
Unread 06-12-2005, 10:51
CraigHickman
Posts: n/a
Re: robot cart
Some teams have a pneumatic lift for their bot, but ours just went simple. The arms that we use to steer our cart can be swung all the way down, effectively turning the cart into a table. It does (in effect) the same thing as a pneumatic lift, but is much simpler.
One note for if/when you make your own is to make it out of aluminum, because hauling around a steel monster is not fun. Steel is much too heavy for the task.
Unread 06-12-2005, 19:29
LittleBush's Avatar
LittleBush LittleBush is offline
AKA: Travis Bush
FRC #0173 (RAGE)
LittleBush is an unknown quantity at this point
Send a message via AIM to LittleBush
Re: robot cart
My team also went simple. We use a wooden platform with four pegs that screw into the top to set the robot on and has a set of clapsable legs that are taken from a clapsable bankuet table. It also has an steel handle that is removable and has a fold-down board to put our control board on, and because the robot is raised off the platform we can put tools and bateries on it.
Unread 06-12-2005, 19:36
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: robot cart
We have been using an extruded and HDPE cart for awhile, but it's probably better that we're going to get a decent cart from Tractor Supply. Actually, steel tube carts are very cheap, as much as if you'd make one. And they're plantly big enough to add onto. But they are heavy.
-Sir Francis Bacon
-Albert Einstein
Unread 06-12-2005, 20:03
slickguy2007 slickguy2007 is offline
Copioli is the man!!!
FRC #1403 (Cougar Robotics)
slickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond repute
Send a message via AIM to slickguy2007
Re: robot cart
This may help you out:
http://www.chiefdelphi.com/forums/sh...ighlight=carts
GO 1403!!!
Team 1403 is Proudly Sponsored By:
Unread 06-12-2005, 21:39
Macdaddy549 Macdaddy549 is offline
Mr. Mac
#0549 (DevilDawgs)
Macdaddy549 is infamous around these partsMacdaddy549 is infamous around these partsMacdaddy549 is infamous around these partsMacdaddy549 is infamous around these partsMacdaddy549 is infamous around these partsMacdaddy549 is infamous around these parts
Re: robot cart
My advice to your team is to design a cart that is LIGHT WEIGHT. Y u ask? Because soon as you put tools and spare parts in it it will get mighty heavy!!! Also one that has a door or doors that is big enough to put spare parts in. One BIG piece of advice is that it fits through any door in your school. Are doors at school are 35 inches wide. Are cart is 34. Also how are you going to bring it to the events? Make sure its not to tall and can fit in a van for transportation to and from. Good luck.
Unread 06-12-2005, 22:25
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: robot cart
whatever you do don't make it a hovercraft . I have always wanted a robot cart with like side walls that re tool shelves, and mini drawers that hold tools and important parts. JUST MAKE IT LIGHT because it's a pain to move them around.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Winning Robot or Quality Robot? Eric Bareiss General Forum 30 09-02-2006 13:19
Robot Cart Suggestions Alex Minot Technical Discussion 46 11-10-2005 20:08
Honda Motor Co's humanoid robot Mirza95vx Math and Science 26 10-04-2005 12:42
pic: Team 326 Robot Cart Mr.G Robot Showcase 1 09-04-2005 08:30
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
