Go to Post This is the weird precipice between insane and innovative. - CalTran [more]
Unread 06-12-2005, 16:17
fred's Avatar
fred fred is offline
More Grizzle
None #0341 (Daisy)
fred is on a distinguished road
Omnidrive Programming
Our team is thinking about using an omnidrive this year. No one on our programming team has really done this before, so if anyone has any quick pointers or suggestions or advice, it'd be greatly appreciated.
Thanks in advance.
"The distance between genius and insanity is measured only by success."
-Anonymous
Unread 06-12-2005, 16:34
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Omnidrive Programming
Which type of omnidrive? That term could refer to an omniwheel design, mecanum design, or crab-steering design (in addition to some other, unlikely things...).
Unread 06-12-2005, 16:48
Aren't you about a month early for making such decisions?
Anyway, the way I'd go about it is to do it in two steps. First, turn operator inputs into a conceptual trio of values: forward/backward velocity, left/right velocity, and rotation rate. The way you do that depends on what OI controls you use. Then, compute the individual motor speeds from the intermediate values. That conversion depends on what kind of wheels you use and how they're mounted.
Unread 06-12-2005, 17:17
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Mount the four wheels so that the axles are all perpendicular. Label them North, South, East, and West clockwise. The following formulas will drive the wheels, where x, y, and r are in the range -127 to 127.
x = (signed int)p1_x - 127;
y = (signed int)p1_y - 127;
r = (signed int)p2_x - 127;
North = x - r;
South = -x - r;
East = -y - r;
West = y - r;
A joystick connected to port 1 will control forward/backward and strafe left/right. The joystick on port 2 will control the rotation clockwise/anti-clockwise.
Unread 06-12-2005, 21:21
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
This previous post may be useful to you:
Holonomic Wheel Math
...and if you search, you will find others as well
Eric
Don't PANIC!
S. P. A. M.
Unread 05-02-2006, 11:45
CronosPrime1 CronosPrime1 is offline
FRC #0321
CronosPrime1 is an unknown quantity at this point
Well, I don't know about an actual omni-drive that uses omni-wheels (since an omni-wheel can only be powered in one direction of motion but move in two it gets confusing I suppose), but my team was designing a ball drive - a drive that has a ball at each corner that can move in two directions (left/right or up/down). Code can be found in this thread:
http://www.chiefdelphi.com/forums/sh...ad.php?t=43301
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
VEX programming Gene F Programming 14 08-08-2006 22:21
Organizing a programming team. scitobor 617 Programming 7 28-01-2005 19:18
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
