Go to Post Add a little more grease if you aren't sure exactly how much you need. - MrForbes [more]
Unread 05-12-2005, 20:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Where to get miniature hydraulics? OR...
Does anyone know of any places to get miniature hydraulic cylinders (like maybe in the range of 1/4" - 3/8" bore) ? Or, if not, can a small pneumatic cylinder be used for a low pressure hydraulic cylinder? Thanks.
Unread 05-12-2005, 22:45
occra 23.
AKA: ryo
None #1481
Re: Where to get miniature hydraulics? OR...
wherever you can find syringes.. multiple bore sizes, multiple stroke sizes, well no needle, just stick a tube over instead.... well a push return is gonna be hard... gonna have to either do an elastic return or find a way to "suck" the fluid out.
Unread 05-12-2005, 23:00
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Have you looked into model airplane retractable landing gear? Some of these systems use small pneumatic cylinders that might suit your needs.
Eric
Unread 06-12-2005, 07:19
kjhobin kjhobin is offline
AKA: Keith Hobin
FRC #3314 (Mechanical Mustangs)
kjhobin is a jewel in the roughkjhobin is a jewel in the roughkjhobin is a jewel in the rough
Send a message via AIM to kjhobin
if you need really small pneumatic cylinders you could try some of IFI's Vex products
http://www.vexlabs.com
-Keith
Montclair Robotics FIRST Team 555 Alumni
FIRST Volenteer
Unread 06-12-2005, 13:08
I know I posted in the pneumatic forum but I am looking for small hydraulics. If such a thing cannot be found, I do know where I can get small pneumatics.
However, I cannot use pneumatics because without some fancy tricks they are very fast and only two position. I need them to be rather slow and infinitely multiple position (like hydraulics).
If anyone knows if a pneumatic cylinder can be run with hydraulic oil, please let me know. I was afraid it might eat the seals or something.
It is for a steering setup on a 1:6th scale RC truck.
Now, I had another idea. Could I use a standard RC car oil filled shock, fill the holes in the shock piston (or make a piston without holes) and drill and tap a couple holes in the shock body for fittings? Or would the hydraulic oil get past the piston too easily and cause problems? (or would it eat the plastic piston?)
Unread 06-12-2005, 16:41
occra 23.
AKA: ryo
None #1481
i have no idea how edible the plastics are to the hydraulic fluid,, but i think rc shocks let out too much between the disk and shock body wall.
how about the lego ones? unless the plastic gets eaten, i think itll be fine with fluids. its fine with water i knwo that much. with air and nonofficial LEGO tubes, it holds air up to 60psi ish.. that i experimented myself... get some TIGHT fitting tubes or find a way to clamp it on... although for an rc truck it might be too fragile.... and slow... unless you widened the stock holes
Unread 07-12-2005, 00:44
CraigHickman
Posts: n/a
The use of a shock piston would not work, because of the holes present inside the cylinder. While in pneumatics or hydraulics there is a seal between the two chanbers, there are small holes in a shock absorber.
Unread 07-12-2005, 00:58
Originally Posted by sanddrag's post above
Could I use a standard RC car oil filled shock, fill the holes in the shock piston (or make a piston without holes)...
Unread 07-12-2005, 01:06
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
What about using a food-grade medium, like glycerine? That would very likely be safe for the seals in a standard aluminum & stainless piston. Or to be absolutely sure, use it with a food-grade piston, with nylon or delrin end caps and stainless body; those seals have to be especially nonreactive.
Unread 07-12-2005, 13:31
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
you could always find out what the seal in pneumatics is made of then see if the material is "edible" by the fluid
KK4KQO
http://voltair.us
Unread 08-12-2005, 02:44
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
This company has cylinders down to 3/8".
http://www.cylval.com/cylinder.htm
Unread 08-12-2005, 05:59
Mr.G Mr.G is offline
AKA: Kevin
FRC #0326 (Xtreme Eagles / Romulus High School / General Motors)
Mr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond repute
Send a message via AIM to Mr.G
Isn't small and hydraulics an oxymoron.
I work in a plant that has a lot of machinery with hydraulic to build engines, and every thing is big. Most hydraulic cylinders are rated for at least 3000 psi and up. In order to hold 3000 psi the cylinder wall has to be thick.
You are also working with a fluid that is not as safe as air. If the system developed a leak, (and yes they do - i think hydraulics and leak are next to each other in the dictionary) and the leak was in the form of a stream of fluid it can easily at 3000 psi get under the skin and be fatal. Not only that, with fluid spraying everywhere it can easily get in your eyes. We have systems with 10's of thousands of gallons of hydraulic fluid and pump that don't stop or run out of fluid. In the past few years we have had people make a mistake and had thousands of gallons on the floor and a soaked employee(there is no hiding that one - it like a terrorist making a bomb and having it exploding). Most of the time people think they shut everything down and they shut off the wrong part and then they try to remove a valve.
Unread 08-12-2005, 06:23
AKA: Kevin
In your investigations you may want to consider a thing called "air over oil". This way you don't need a hydraulic pump and all the other equipment. If you already have pneumatics on whatever you are building and only need 1 or 2 motions then air-over-oil may sound like the better option.
Here are some animations
In this one the cylinder on the left could be a pneumatic cylinder with air on top, or a pressure reservoir with air pressing directly on the fluid.
http://travel.howstuffworks.com/animation31.htm
Here is another variant.
http://www.airhydraulics.com/Product.../Animation.htm
Unread 08-12-2005, 10:54
Gdeaver Gdeaver is offline
FRC #1640
Brake cylinders are kind of small and the junk yard is full of them.
Miniature Innovation First RC System BSMFIRST Technical Discussion 13 27-07-2001 02:24
Miniature Robots David Kelly Technical Discussion 4 31-05-2001 22:06
